Atomic Superpi Scores V5
787 replies to this topic
#761 Rybags
Rybags
  • 35,648 posts
Posted 19 March 2017 - 10:36 AM
Re wPrime - you need to set the Properties (all users) to "Run as Admin...".  It should work OK once that's done.
If there's undue delay for startup, hold Shift.  You'll also probably need to set # of threads.
#762 Rybags
Rybags
  • 35,648 posts
Posted 19 March 2017 - 09:54 PM
Found my benches from the old Core2 Duo E8400.  This thing runs stock at 9*333 = 3 GHz but was another landmark legendary overclocker.
I've got 3 of them but only played around with one.  I managed to get it to about 4.293 GHz according to my notes.  This was from a session about 6 months ago on the watercooled machine I've got.  I have a bunch of DDR2 modules though not really any stuff aimed at extreme OCing though the Ram I used at the time would have been the fastest I had available.
At 4.293 (477*9, Ram @ 954-6-6-6-23) I got the following results:
CPUMk99 620
SuperPi 1M 10.998s
wPrime 32M 2T 18.94s
#763 mark84
mark84
  • 5,737 posts
Posted 19 March 2017 - 10:03 PM
Gave wPrime a try again.
Ryzen 7 1700X @ 4075MHz w/2400MHz RAM
wPrime 32M 16T 3.7s - 5.2s it wouldn't give me a consistent result. most were in the mid 4s
Ryzen 7 1700X @ 3950MHz
wPrime 1024M 16T 96.9s
Desktop: i7 6850K @ 4.3GHz | Titan X (Pascal) | 32GB RAM | 120GB + 500GB SSDs | 2x 5TB HDD in RAID1
Server: G3258 @4.6GHz | 120GB SSD | 2x 4TB RAID1 | 2x 6TB RAID1
Desktop build log | Firefox AtomicMPC Menu | The Truth About Graphics Power Requirements V2 | CPU bench league
www.atomicsimracing.net - The place for Atomicans who love motor sports and sim racing.
#764 sora3
sora3
  • 13,900 posts
Posted 20 March 2017 - 11:20 AM
I'll bench up with the 1700 to see if I can match anything there, Mark...
Main Rig: AMD Ryzen 7 1700 @ 3.9GHz/Asus X370 Prime/Corsair DDR4 3000 32GB @ 2667(!)/Sapphire RX Vega 64/WD Green M2 240GB/Bitfenix Shinobi/Noctua NH-D14/Corsair HX-750
Camera rig: Sony Alpha a77/Sony DT 16-50mm f2.8 SSM/Sony DT 16-105mm f3.5-5.6/Tammy 70-200mm f2.8/Sony DT 50mm f1.8/Sony HVL F42AM Flash
#765 Rybags
Rybags
  • 35,648 posts
Posted 20 March 2017 - 04:43 PM
Not too shabby score there.  wPrime just laps up extra cores and even hyperthreading can give a big improvement.
Actually, that's another thing worth trying - get comparitive scores with #threads set to <physical cores> vs the same run with <logical cores>
#766 mark84
mark84
  • 5,737 posts
Posted 20 March 2017 - 06:00 PM
Or better yet disable SMT. Something many tests have shown to work better with (because they don't know how to handle SMT properly, like hyper threading, which is the same but I understand implemented differently).
I can't do any more benches, had to hand the system back. A reviewers lament.
Was fun while I had it.
Look forward to seeing what you can cook up Sora! Especially with the higher rated RAM.
These CPUs really do need water cooling though. The air HSF I had couldn't really cope with the higher OCs with all cores enabled. Had to disable 6 as seen in my previous posts so I could push it to 4.25GHz to keep temps in check.
AMDs TDP does not equal Intel TDP ratings. Ryzen pulls as much as Broadwell-E at full tilt. Needs the cooling to match really.
#767 sora3
sora3
  • 13,900 posts
Posted 24 March 2017 - 12:08 PM
ATM, there's a new BIOS out which should increase RAM speeds as most users on reddit noted a significant improvement so I'll have to test that and check it out.
#768 gamble
gamble
  • 1,364 posts
Posted 25 March 2017 - 04:24 AM
Had to order some AM4 parts for my loop, should have some test up here in a week.  Look forward to seeing others results!
HAF 912 | Biostar x370GT7 | 1700x @ 4ghz | Asus Strix GTX 1080ti @ 1962c/12000m | EVGA RAM @ 2933mhz  | EK Watercooled CPU | EVGA G2 1300W
#769 sora3
sora3
  • 13,900 posts
Posted 28 March 2017 - 06:03 PM
Ryzen%20SuperPi%20Run_3.7_zpsilf4p3u4.jp
ATM, that's probably the limit given the cooler is almost running out of puff. I'll need to get the AM4 bracket for the Noctua NH-D14 in order to really push it.
EDIT:
Edited by sora3, 28 March 2017 - 06:36 PM.
#770 Rybags
Rybags
  • 35,648 posts
Posted 28 March 2017 - 06:44 PM
For what it's worth, the old Core2 Duo E8400 at a near frequency (with DDR2 Ram):
408x9 = 3,672 MHz  12.87s  with DDR2 @ 408/5-5-5-15
412x9 = 3,708 MHz  12.714s
Closest time for E8400 I have listed is 11.372s, to get that speed it was 406x9 = 4,230 MHz, I think the Ram was 406/6-7-7-23
I've probably got some first-gen Core i7 scores somewhere I could dig up, will look later.
#771 mark84
mark84
  • 5,737 posts
Posted 28 March 2017 - 10:42 PM
Nice one Sora. Yeah they need proper cooling to explore their potential fully.
What temps you currently getting?
vcore you can safely go up to 1.45v according to AMD people. You'll need to to get 4GHz+
I think 1.4125v was the sweet spot on mine for around 3.9GHz stable.
Pushing to 4.25GHz the one I tested started auto shutting down around the 90C point (after adjusting for +20C readings AMD admitted to on X models. Yes it was reading 110C lol). Not as good in that respect as Intel which'll let you hit 100C.
#772 sora3
sora3
  • 13,900 posts
Posted 29 March 2017 - 06:54 PM
@mark, temps is about 70C core temp at worst case scenario (IBT 3 hours worth) so I can push a little higher given the voltage. But the cooler is the limiting factor as the Spire doesn't have a lot of thermal headroom once you hit beyond 3.5GHz. I've already sent the invoice and proof to Noctua and we'll see when they'll ship.
#773 gamble
gamble
  • 1,364 posts
Posted 30 March 2017 - 01:05 PM
Quick update, screenshots later once I figure some setting out.  Have the OS loaded and most updates done.  Ran a few short Prime95 large for 5-10mins up to 4.1g, just ran out of time for the day.  Temp I guess I need to look at the Package but read that the X series has a +20c offset.  Running my core say at 1.5v only give around 1.37v.  Ill probably need to mess with LLC.
4.1g @ 1.5v(actual with load is 1.375v)
Ram:  2933mhz @ 16cl
SuperPI 1m gave:  10.158
Package is 73c and THRM 53c (These literally follow 20c apart in HWmonitor, Master shows Package temp)
Still running thru setting check stability but doubt that 4.1 @ 1.375(set at 1.5v) is going to be stable long term.
Edit: 4.1g failed prime95 screen black after Idk 10mins probably. Give a go after messing with llc tomorrow
Edit 2:
Broke into the 9's @ 4241ghz with 1.5v  :)
Looks like 4ghz is prime stable @ 1.375v, have the LLC @ lvl 1.  Need to explore pstates as load vs idle is quite different, possibly offset can be used too.  With my two rad fans at 1000rpm and pump at 2/3 speed, Im hitting 85c after an hour on Package, 65c on THRM.  When I load biostar GT, it shows the THRM for the cpu temp but Ryzen Master uses Package lol.
Edited by gamble, 31 March 2017 - 12:21 PM.
#774 mark84
mark84
  • 5,737 posts
Posted 05 April 2017 - 06:13 PM
Nice gamble! What speed ram u running it with/at?
I tried so hard to get sub 10s lol Definitely the RAM at regular 2400MHz speeds wasn't helping me.
#775 gamble
gamble
  • 1,364 posts
Posted 05 April 2017 - 09:44 PM
Thx,running ram @2933 16cl. Cant go over that yet, but maybe in a bios update I hope to get to the rated speed of 3200. Will revist when bios gets another update. But I'll do a few runs with the same clock 4ghz and different ram speed to see the difference it has
#776 Soulessdeath
Soulessdeath
    Learner
  • Quark
  • 51 posts
Posted 03 May 2017 - 12:15 AM
PC's, Cars, Marine communications  a Bit of everything in life.  Especially Gaming.
#777 Rybags
Rybags
  • 35,648 posts
Posted 03 May 2017 - 12:34 AM
Not tea-bag... what were the Ram timings on that?
I did some testing on my newer machine, i7-4790 before moving over to it.  It was running stock speed but Ram slightly faster than spec and I managed to get a couple under 9 sec.
All set up now and my 2x8 Gig Ram sticks are fairly lowly DDR3-1600 gear where earlier runs were with the 2x4 Gig Kingston HyperX 1866 on it's own with better latencies.  So, everything at the more conservative settings.  Can still get consistent low 9 second scores.  Current Ram timings are 1600 11-11-11-28, the HyperX is capable of 1866 11-11-10-29
For whatever reason the Bios on this thing isn't making the strapping options available otherwise I'd have done some overclocked runs with BClk = 133.
#778 Soulessdeath
Soulessdeath
    Learner
  • Quark
  • 51 posts
Posted 03 May 2017 - 12:53 AM
presuming you are talking to me, Here is a screenshot of CPUZ memory tab
I am using Trident Z 3200MHZ 2 x 8GB
And here is my Y crunch score
#779 Rybags
Rybags
  • 35,648 posts
Posted 03 May 2017 - 12:58 AM
I'd really have thought you'd get a better score than that... only about a second under my best and you have virtually double the Ram speed, better latencies and Skylake almost 10% faster than my Haswell.
I've played around with "little things" that can give advantage such as - set task priority in Task Manager up 1 or 2 positions.  Try setting CPU Affinity so it only executes on a single core, usually one other than 0, and also tick the box for the virtual LP to cover hyperthreading e.g. tick 2 and 6 on a quad-core CPU.  Get rid of much background processing as possible.  The strategy there being to ensure that other cores don't get busy and reduce the max multiplier available.
Another thing I've noticed - it can take a little time for the system to throttle up the CPU.  I've tried running another task that gets it turbo'd up, then try and start the bench run as soon as that finishes although it'd be way easier if it was an automated process.
#780 Soulessdeath
Soulessdeath
    Learner
  • Quark
  • 51 posts
Posted 03 May 2017 - 01:04 AM
Still learning to overclock, Will keep playing around and seeing what i can do, Always running these tests when i have 0-1% background cpu utilisation so should be no issue there, I do need to try and get my ram running better, But for me at the moment it is fine. Just thought id see what i could get as the pc is at the moment before i start playing alot.
