AMD Zen
370 replies to this topic
#141 Rybags
Rybags
  • 35,338 posts
Posted 17 March 2017 - 04:09 PM
Illegal, unsupported, legal.  Doesn't matter.  The point is that there's expected behaviours and if a CPU crashes or is able to be elevated to a privelage level it shouldn't be at then it's a big security hole, and especially for enterprise markets puts a big ding in your reputation.
#142 Jeruselem
Jeruselem
  • 14,473 posts
Posted 17 March 2017 - 07:00 PM
Ryzen 3 and 5 are like the ryzen 7 with a ccx between sets of cores
Ryzen 3: 2:2
Ryzen 5: 3:3
Ryzen 7: 4:4
Hence only 4, 6 and 8 cores CPUs for ryzen
DOWN DOWN, the Dow Jones is DOWN.
DOWN DOWN, the ASX is DOWN.
#143 sora3
sora3
  • 13,900 posts
Posted 20 March 2017 - 11:16 AM
That's true but not true at the same time. It is true that having a CPU doing something unexpected is not something your company wants to deal with. However, it is not true that ALL enterprise markets will be running the same configuration. Most if not all enterprise will be utilising custom-made software that is tailored to some degree to their work.
Anyway, I'll digress and get back to what's happened with the Ryzen. ATM, I've managed to boot the Hynix RAM sticks to 2400MHz but any further = board hang so it does seem like the AGESA isn't liking my RAM. BIOS updates is rather pathetic but given how Asus is prioritising the C6H, this does mean that the Prime does get some loving soon. Managed to O/C to 3.7GHz at 1.20v which is rather surprising and I probably can push further to 3.9GHz. Cooling might be a problem but it seems the stock cooler is still hanging in there. I did a burn test with XCOM2 which heats my system hard and the temps were hovering at 62C max. Not bad...
Main Rig: AMD Ryzen 7 1700 @ 3.9GHz/Asus X370 Prime/Corsair DDR4 3000 32GB @ 2667(!)/Sapphire RX Vega 64/WD Green M2 240GB/Bitfenix Shinobi/Noctua NH-D14/Corsair HX-750
Camera rig: Sony Alpha a77/Sony DT 16-50mm f2.8 SSM/Sony DT 16-105mm f3.5-5.6/Tammy 70-200mm f2.8/Sony DT 50mm f1.8/Sony HVL F42AM Flash
#144 Jeruselem
Jeruselem
  • 14,473 posts
Posted 20 March 2017 - 11:21 AM
I'm hearing Ryzen isn't compatible with a lot of RAM. Hope it's just buggy board BIOSes.
Edited by Jeruselem, 20 March 2017 - 11:21 AM.
#145 sora3
sora3
  • 13,900 posts
Posted 20 March 2017 - 11:33 AM
Most of the RAM can boot at standard JEDEC 2133MHz speed and timings. But it is the higher speed that is the problem since the InfinityFabric is dependent on RAM speed. Once the AGESA is settled, then we should start to see a lot more speed into these things.
#146 Jeruselem
Jeruselem
  • 14,473 posts
Posted 21 March 2017 - 08:20 AM
I guess if you have 2 weeks to write a uefi/bios this is to be expected.
#147 Rybags
Rybags
  • 35,338 posts
Posted 21 March 2017 - 08:30 AM
It's not like they're done from scratch.  The overall framework is much the same, just specifics like register locations that change.
But really, like any new architecture the edgy stuff is where the learning curve is.  Look back at most high profile overclocking motherboards, it took some of them multiple months and several Bios revisions before they got near their peak capability.
#148 Jeruselem
Jeruselem
  • 14,473 posts
Posted 21 March 2017 - 09:45 AM
Someone said the original launch was like 1 month further ahead ...
#149 gamble
gamble
  • 1,357 posts
Posted 04 April 2017 - 08:05 AM
Interesting jump in fps...
HAF 912 | Biostar x370GT7 | 1700x @ 4ghz | Asus Strix GTX 1080ti @ 1962c/12000m | EVGA RAM @ 2933mhz  | EK Watercooled CPU | EVGA G2 1300W
#150 Jeruselem
Jeruselem
  • 14,473 posts
Posted 05 April 2017 - 09:20 AM
Meanwhile pretty deathly silence about Vega ...
#151 gamble
gamble
  • 1,357 posts
Posted 05 April 2017 - 10:53 AM
Pinch of salt: https://www.google.c...s-leak-nda/amp/
But I hope this is true
#152 Mordenakhnen
Mordenakhnen
    Charge
  • 368 posts
Posted 05 April 2017 - 01:41 PM
Well, they say “As you leave the article, please watch the gap between the article and the comments” which may be referencing the slide they label epilogue where the last two words of the main text area are "April Fools."
People worry that computers will get too smart and take over the world, but the real problem is that they’re too stupid and they already have.
 - computer scientist Pedro Domingo.
#153 Jeruselem
Jeruselem
  • 14,473 posts
Posted 05 April 2017 - 03:04 PM
Yes the nda of 1st of April was another giveaway.
#154 Jeruselem
Jeruselem
  • 14,473 posts
Posted 09 April 2017 - 12:00 PM
The rx500 series is not Vega, it's like Polaris v2 and not a 1080 killer.
Edited by Jeruselem, 09 April 2017 - 03:53 PM.
#155 sora3
sora3
  • 13,900 posts
Posted 10 April 2017 - 07:52 PM
I expected as much since Polaris should last a lot longer than Tonga/Tahiti/Hawaii. But Vega is the new architecture too since it rebuilt from GCN.
#156 Rybags
Rybags
  • 35,338 posts
Posted 12 April 2017 - 12:17 AM
Ryzen 5 out today.  I just watched this review from LinusTechTips.
#157 Jeruselem
Jeruselem
  • 14,473 posts
Posted 12 April 2017 - 10:02 AM
PC Case gear Ryzen 5 prices
http://search.pccase...w=ryzen 5&asug=
1600x 359
1600 319
1500x 275
1400  245
I think the 1600 or 1500x are best value. The 1400 should be cheaper, it's hard to justify it given the 1500x is 30 more.
Edited by Jeruselem, 12 April 2017 - 10:13 AM.
#158 sora3
sora3
  • 13,900 posts
Posted 15 April 2017 - 12:43 PM
To be honest, the 1500X is not really worth it either. For $40 more, you're getting 2 extra cores and additional 4 threads. Plus, you're compromising more with the 1500X for the future since we assume more developers will be optimising for multiple cores.
#159 Jeruselem
Jeruselem
  • 14,473 posts
Posted 18 April 2017 - 09:34 AM
True, the 1600 is better value. Given Ryzen barely overclocks above 4.1 Ghz ... the 1600X might be a waste.
#160 Jeruselem
Jeruselem
  • 14,473 posts
Posted 05 May 2017 - 05:38 PM
It seems the vega gpu is based on the fury x so its not a true redesign like ryzen.
Edited by Jeruselem, 05 May 2017 - 05:38 PM.
