What is most important to you in Graphics Cards?
graphics gpu vga graphics cards
23 replies to this topic
#21 Roscosity
Roscosity
    Learner
  • Quark
  • 50 posts
Posted 12 April 2016 - 01:14 PM
I pick a budget first off, $300 is my sweet spot, Then see what card gives the best performance for my nominated budget.
If it looks like Im not going to get thr required increase in or level of performance then I bump up the budget a little.
Dont run overclocks, dont care about noise, heat or energy use. (though have come unstuck when I went to fit a card and it was 3cm's to loong for my case....)
That seems fair enough! Do you ever buy overclock cards though? Since they usually have a higher base clock too?
Roscosity | Gigabyte ANZ Community Manager
#22 te0p
te0p
  • 841 posts
Posted 14 April 2016 - 11:27 PM
The prettiness of the fans. Big fans = $$ though :(
#23 Roscosity
Roscosity
    Learner
  • Quark
  • 50 posts
Posted 18 April 2016 - 01:18 PM
Have you seen the RGB LED fans on the Gigabyte Xtreme Gaming cards? :)
#24 EthanStark
EthanStark
    Serf
  • Lurker
  • 5 posts
Posted 29 May 2017 - 10:49 PM
Hello Guys,
I'm assuming this is for gaming.
Most important specs are your displays resolution and refresh rate. If your display can't output more than 60 Hz at 1080p, then getting something like a GTX 980 is just a waste of money. Basically your display puts an upper limit on the card you have any reason to buy. Then just get the most expensive you can afford up to that point (with very few exeptions the more you pay the better the card and those exeptions don't last long)
Ethan Stark
Software Developer
Edited by EthanStark, 02 June 2017 - 09:55 PM.
Also tagged with one or more of these keywords: graphics, gpu, vga, graphics cards
