Waisted some cash 6700k\gtx1070
49 replies to this topic
#41 gamble
gamble
  • 1,349 posts
Posted 13 September 2016 - 01:04 PM
maybe toggle the xmp on and off and back to your profile?  I have to do a cmos reset it seem now if I run 5ghz... even if I load the 4.7ghz profile it will keep the 5ghz profile.  I have to reset and then load the 4.7ghz profile then its fine... Just a guess since you have probably been playing with the bios alot :)
These are the best I can do with 5ghz running:
cpu @ 5ghz - gpu core is all over the place depending on the part of a bench... But the core is around 1974 - 2025ghz with a few higher and lower... Memory is at 4750 and starts to artifact around ~4800.
16251 - http://www.3dmark.com/fs/10145773
6165 - http://www.3dmark.com/spy/436959
Oh and this is interesting:
Edited by gamble, 13 September 2016 - 01:09 PM.
HAF 912 | Biostar x370GT7 | 1700x @ 4ghz | PowerColor RX 56 (RX 64 Bios) @ 1600c/945mhz | EVGA RAM @ 2933mhz  | EK Watercooled CPU | EVGA G2 1300W
#42 Dasa
  • 14,870 posts
Posted 13 September 2016 - 01:16 PM
lol 1 point short in timespy so dam close! i bet you could tweak some more out of your ram sub timings
timespy sees artifacts much sooner than firestrike for me i had to back off the gpu\mem clocks a lot for it
firestrike can run +825 with maybe the odd minor artifact but i run +750 when gaming
1974 - 2025 sounds like a fairly typical range for the most part sounds like your gpu really wants a waterblock though ;)
got 4000 running again after loading the profile this time i noticed that the ram was reporting 2400 and that was the max speed available till if poked at it a few times in the uefi
its not perfectly stable at the moment though need to tweak it again
Silverstone TJ08-EW 6700k@4.7 1.375v - Z170-GENE - 2x8g 3866 16-16-16 - 1070@ 2100\9600MHz  -Samsung 830 64G, Sandisk Ultra II 960G, WD Green 3tb - Seasonic XP1050 - Dell U2713 - Pioneer Todoroki 5.1 Apogee Drive II - EK VGA-HF Supreme  - Phobia 200mm Rad - Silverstone AP181 Project Darkling
3770k vs 6700k RAM Scaling, HT vs RAM, Arma III CPU vs RAM, Thief CPU vs RAM
Parts Guide
#43 gamble
gamble
  • 1,349 posts
Posted 13 September 2016 - 02:10 PM
I know right!?  1pt and ran 3 times and restarted once, would have to come from timings or slight blck bump...  I think your time spy was 4.5ghz so you'll see more probably with 4.7ghz?
#44 Jeruselem
Jeruselem
  • 14,097 posts
Posted 13 September 2016 - 05:44 PM
Say, can you try the new geekbench 4 on that rig?
MTM NBN with FTTP/FTTH, FTTN, FTTC/FTTdp, HFC and Satellite. Buffering included
#45 Dasa
  • 14,870 posts
Posted 13 September 2016 - 06:23 PM
here you go at 4.7ghz 4000
sc 6337 mc 21305
https://browser.geek...m/v4/cpu/306559
just hit 6000 write speed 5200 copy in aida64 then still over 37ms at 4000 though
since going on water at stock clocks the gtx1070 stays at 1999mhz in heaven
increasing gpu memory speed also reduces core clocks when overclocking due to increased power use but its worth it as the performance still goes up
Edited by Dasa, 14 September 2016 - 06:41 AM.
Parts Guide
#46 Dasa
  • 14,870 posts
Posted 19 September 2016 - 09:45 AM
just did the power mod gamble linked above with liquid ultra
must say i was a bit worried since the last time i fiddled with a card i killed my 7970 by having the diy vrm slide due to bad glue and short the vrm
thankfully it posted ok but then failed to boot sure made my hear skip a beat but it was just the mb had decided to give me a scare by changing the boot order
it seems to have worked! heaven was running a solid 1139 with 140+boost at 1050mv  instead of dropping back to ~1000mv due to power limits
reported power use does go over 100% so it may still restrict clocks a little under some circumstances
firs run of firestrike at stock clocks reported some inconstancy error but timespy was fine
need to do further testing
also need to get some new arctic adhesive to stick those hs on over the vrm plate so they dont cook with the extra v
Parts Guide
#47 gamble
gamble
  • 1,349 posts
Posted 21 September 2016 - 06:29 AM
That was pretty ballsy mod there ;)    I need to get under water so I can do this mod... nice job.
#48 Dasa
  • 14,870 posts
Posted 14 October 2016 - 09:09 AM
final stable speeds for now...
Dasa--i76700K @4.7/4.6 1.376-1.4v---3866Mhz-C16-16-16-34-2T----1.425v---SA 1.25v---IO 1.2v
idle power use 40-50w peak 315w
Edited by Dasa, 14 October 2016 - 09:11 AM.
Parts Guide
#49 gamble
gamble
  • 1,349 posts
Posted 10 February 2017 - 08:16 AM
So, I have been looking over your charts... Age old mhz vs latency, but with ddr4... It looks like mhz wins slightly in most?  Holding out for ryzen before I pick next build but thought about buying ram before and a few other pieces before then.
#50 Dasa
  • 14,870 posts
Posted 10 February 2017 - 08:37 AM
provided you can keep the final latency close to the same with mhz vs timings then higher freq gains the edge through increased bandwidth
some software cares more about bandwidth some more about latency so depending on what your running it can swing more one way than the other
games typically seem to lean towards final latency but some do like a bit of bandwidth as well
Edited by Dasa, 10 February 2017 - 08:53 AM.
Parts Guide
