D5 replacement
3 replies to this topic
#1 gamble
gamble
  • 1,367 posts
Posted 08 November 2016 - 04:41 AM
Looks like a good option for those needing to replace or buy new:
http://www.tomshardw...ment,32987.html
HAF 912 | Biostar x370GT7 | 1700x @ 4ghz | Asus Strix GTX 1080ti @ 1962c/12000m | EVGA RAM @ 2933mhz  | EK Watercooled CPU | EVGA G2 1300W
#2 Dasa
  • 14,915 posts
Posted 08 November 2016 - 07:18 AM
0.1m increase it head pressure but a massive drop in flow rate from 1500l/h to 350 l/h
edit ok seems you can ignore the pumps flow rating it performs well looking at this review
http://thermalbench....pe-vpp755-pump/
now they just have to do a mcp355 pwm replacement that fits my apogee drive :)
Edited by Dasa, 08 November 2016 - 07:29 AM.
Silverstone TJ08-EW 6700k@4.7 1.375v - Z170-GENE - 2x8g 3866 16-16-16 - 1070@ 2100\9600MHz  -Samsung 830 64G, Sandisk Ultra II 960G, WD Green 3tb - Seasonic XP1050 - Dell U2713 - Pioneer Todoroki 5.1 Apogee Drive II - EK VGA-HF Supreme  - Phobia 200mm Rad - Silverstone AP181 Project Darkling
3770k vs 6700k RAM Scaling, HT vs RAM, Arma III CPU vs RAM, Thief CPU vs RAM
Parts Guide
#3 SonOfNoddy
SonOfNoddy
    Snotblock
  • 640 posts
Posted 08 November 2016 - 10:48 AM
This is a pretty good replacement
Do not go gentle into that good night,
Old age should burn and rave at close of day;
Rage, rage against the dying of the light.
#4 gamble
gamble
  • 1,367 posts
Posted 08 November 2016 - 01:36 PM
Yea the flow rate seems strange as most manufacturers are border line lies. . . Most be different way they test.  Here's another review:
http://www.xtremerig...-pump-review/3/
