Noticed "Not Supported" Actually means "We'll break it"?
23 replies to this topic
#21 Jeruselem
Jeruselem
  • 14,445 posts
Posted 02 December 2016 - 02:48 PM
I'm talking the trend of V7.1 supported, 7.0 not. With no protcol changes, as are in this example, a chat client.
I expect v7.1 will not break v7.0 . I expect that v8.0 can break v7.0. Major version numbers are for exactly that reason, breaking changes. So typically, if you upgrade from one version to another you can accept that things may break. People should read the change log before upgrading. Same as v1.0 of an API can completely fuck apps coded against v0.9.
This isn't really in direct response to your OP, just version numbering in general, and stuff like Windows is a bit different, where Microsoft would go bankrupt if an upgrade from windows 8.1 to window 10 meant you had to reinstall all your data and your software working on 8.1 doesn't work on 10. MS are a definite exception though, with their diligence in maintaing backwards compatibility.
Considering you can still run like VB6 apps on Windows 10 x64 ... yes!
That's with a bit of finicking with some OCX and DLL but it works.
DOWN DOWN, the Dow Jones is DOWN.
DOWN DOWN, the ASX is DOWN.
#22 Master_Scythe
Master_Scythe
  • 20,375 posts
Posted 02 December 2016 - 03:04 PM
Oh for sure, and I'll even give a weak free pass to companies who offer old versions.
Android, iOS and Metro apps, all don't allow that though.
Very few companies host their APK's, and even fewer allow old versions to even connect.
I'll admit my initial post is certainly more mobile focused; but still.
#23 Jeruselem
Jeruselem
  • 14,445 posts
Posted 02 December 2016 - 03:15 PM
We have an in-house VB6 app which is still in VB6 because no one here codes in VB6 anymore, but it's still working even on Windows 10 x64 1607. It was last updated in like 2011 to make it work with Vista.
Edited by Jeruselem, 02 December 2016 - 03:18 PM.
#24 stadl
stadl
  • 9,047 posts
Posted 05 December 2016 - 01:13 PM
We have similar apps at work.
But they are not performing authentication over public networks and or interfacing with servers that interface to multiple versions of clients.
In isolation, old software can run for decades. With interfacing the costs go up, Care about security, and you can add another zero.
A device so simple that it took a mind as brilliant as mine to create it! So brilliant, in fact, that simply by harnessing the power of one live frog, it... it... uhh... <poke> <poke> ... World domination has encountered a momentary setback. Talk amongst yourselves.
