paste: always better than air?
22 replies to this topic
#21 stadl
stadl
  • 9,056 posts
Posted 29 September 2017 - 01:08 PM
How about folding some metal flyscreen?
Unsure how well that would work - In close proximity lots of holes work together to be less effective, but I expect it would still be better than nothing.
EDIT: and would I be best to connect said flyscreen to the antenna GROUND, to act as a faraday cage for the chip?
Points where the current shield is soldered/attached to the board should be grounded - likely there is a ground plane in the PCB that is forming the other side of any shield.
A device so simple that it took a mind as brilliant as mine to create it! So brilliant, in fact, that simply by harnessing the power of one live frog, it... it... uhh... <poke> <poke> ... World domination has encountered a momentary setback. Talk amongst yourselves.
#22 Dasa
  • 14,915 posts
Posted 29 September 2017 - 08:19 PM
whatever you do stick a temp probe on the back of the pcb for some b4 and after temps
Silverstone TJ08-EW 6700k@4.7 1.375v - Z170-GENE - 2x8g 3866 16-16-16 - 1070@ 2100\9600MHz  -Samsung 830 64G, Sandisk Ultra II 960G, WD Green 3tb - Seasonic XP1050 - Dell U2713 - Pioneer Todoroki 5.1 Apogee Drive II - EK VGA-HF Supreme  - Phobia 200mm Rad - Silverstone AP181 Project Darkling
3770k vs 6700k RAM Scaling, HT vs RAM, Arma III CPU vs RAM, Thief CPU vs RAM
Parts Guide
#23 @~thehung
@~thehung
  • 8,762 posts
Posted 05 October 2017 - 03:20 PM
speaking of flyscreen, i wonder if you could just replace the whole shield with something like this:
RFI Shielding Mesh
Edited by @~thehung, 05 October 2017 - 03:20 PM.
no pung intended
