Laptop battery wont charge
24 replies to this topic
#21 merlin13
merlin13
  • 8,412 posts
Posted 09 February 2018 - 12:34 AM
...the laptop is still so powerless it drops its CMOS settings when I remove AC...
Low main battery means it also drops the settings? As an aside here that smells suspiciously like the CMOS backup battery is also borked (I'm assuming that it's got one, for the price/specs it'd bloody well better have..).
And/or the BIOS itself is somewhat scrambled and needs a serious reset or even a full reflash to clear it out and restore some sanity to it.
Anything not nailed down is mine, and anything I can prise up is not nailed down...
#22 Master_Scythe
Master_Scythe
  • 20,393 posts
Posted 09 February 2018 - 08:43 AM
yeah that little guy is dead too; but it wont matter if it had primary battery charge.
#23 Master_Scythe
Master_Scythe
  • 20,393 posts
Posted 09 February 2018 - 09:45 AM
How will this work? Will the PC receive the output?
Do I run it in a different way to how I've 'written' programs to the Arduino before?
If you have a proper Arduino board with a USB connection, then yes, it manifests as a virtual COM port, and you'd just watch for data in a terminal program (PuTTY will do the trick) or the serial monitor built in to the Arduino IDE.
If you're using one of those ATMEGA328P-based micro/nano boards that's designed to go into a breadboard, then you'd need to find a way to interface the board's logic-level UART with your PC, like one of those FTDI adaptors.
Ah I'd only been using nano's and writing programs.
I had no idea the 'full size boards' had that function.
very cool :)
#24 SquallStrife
SquallStrife
    Really knows where his towel is
  • 18,003 posts
Posted 09 February 2018 - 01:13 PM
It depends how the nanos are connected. The ones I use have no USB connector, a 5-pin header on the short side for an FTDI adaptor for serial connectivity, but are programmed over SPI (I use a USBasp for this) and have no bootloader.
SPI programming uses RST, MOSI, MISO, SS, and SCK.
If your boards have a USB plug on them, and are programmed over the USB cable, then it has the serial functionality already. (Either using an ATMEGA32u4 or similar with on-die USB, or an ATMEGA328P with an FTDI chip on the board)
SyDjDDk.png [retro swim] | AzpUvwG.png @retroswimau | q5O6HgO.png +RetroSwim
四時半を待っています!
#25 SquallStrife
SquallStrife
  • 18,003 posts
Posted 15 February 2018 - 10:50 AM
Keen to know if/how you got on with this?
四時半を待っています!
1 user(s) are reading this topic
0 members, 1 guests, 0 anonymous users
