Vcore for e8500 @ 4.0ghz
7 replies to this topic
#1 jonno4130
jonno4130
    Cherry Danish
  • 168 posts
Posted 16 September 2008 - 02:19 PM
after i finish benchmarking my system running normally, im thinking of having a crack at overclocking my e8500. it will be my first time overclocking, and i was just wondering around about what Vcore i should be aiming for. Ill be having a crack myself first up, but i am a little apprehensive so having a ball park figure on hand would be handy.... so yeh, if you have an overclocked e8500, what Vcore are you running?
#2 c0nc0n
c0nc0n
    Macaron
  • Lurker
  • 1,559 posts
Posted 16 September 2008 - 02:43 PM
Just wondering - When did you buy that E8500? Download CPUz and tell me the stepping of your CPU
E8600 w/ TRUE + Slipstream 4Gb DDR2-1066 Crucial Ballistix Tracers Gigabyte EP45-DS3R - ASUS HD4870 1000GB Seagate Barracudas X-FI Fata1ty FPS Antec P182 Razer Lacesis/Lycosa
#3 Fat_Bodybuilder
Fat_Bodybuilder
    Apple Strudel
  • Banned
  • 8,893 posts
Posted 16 September 2008 - 03:04 PM
It's most likely C0 stepping, and you should be able to do it with 1.3V :-)
Don't worry about a thing. 'Cause every little thing is gonna be alright.
#4 c0nc0n
c0nc0n
    Macaron
  • Lurker
  • 1,559 posts
Posted 16 September 2008 - 03:52 PM
Yep, +1 to that. I'm sitting on 4.0~Ghz at 1.29volts
#5 MyAlbanianAss
MyAlbanianAss
    Éclair
  • Quark
  • 2,413 posts
Posted 16 September 2008 - 08:29 PM
wow thats impressive..... 4ghz at under 1.3v
#6 ravennoir
ravennoir
    Cupcake
  • Quark
  • 59 posts
Posted 16 September 2008 - 09:22 PM
I can run my E8400 at under 1.3v, these new Core2Duo's are great :D
#7 osama_bin_athlon
osama_bin_athlon
    Canelé
  • 21,067 posts
Posted 16 September 2008 - 10:41 PM
well under 1.4v anyhoo.
Quote by lunchbox1988 No, but the way he eases me onto his chimp-meat, makes me think he is prince charming. i7 2600K @ 4.4G/Corsair H100/Asrock Z68 Ext4 Gen3/16G 2133Mhz RipjawsX/2x GTX560 Direct CU SLI/2x Corsair 120G Force3 (RAID_0)/8TB Storage (2x RAID_0 arrays)/1x 320G WD Black - Backup/SB Recon3D Fatal1ty Pro/Corsair HX1000/LiteOn BD-RW/CM HAF 932 Adv/Win7 Ult. x64/27" AOC e2795Vh
#8 espionage
espionage
    Croissant
  • 706 posts
Posted 16 September 2008 - 10:46 PM
make sure to use a quality air cooler like a TRUE before OCing your CPU.
