Water Cooling 1 or 2 loops
_5c077y_
post Jan 20 2013, 04:54 PM
Post #1
Quark
Initiate
Hey guys, So I have an extended Danger Den Double Wide case and I'm looking into water cooling for it.
It's a massive case so I'm sort of wanting to make it look neat but at the same time I don't wanting it looking empty
The case has room for x2 360 radiators in both sides of the front and a 480 in the back on the right side.
I think I'm wanting to keep as much LC stuff on one side as I can.
Anywho my actual question is 1 or 2 loops? it's a big system and I know it's overkill but I'm wanting blocks on the CPU, RAM (quad channel) and chipset as well as the 2 video cards
So I'm not sure if with the size and height of the case (685mm high) and the parts in it if I should go 1 or 2 loops. I'll be using Swiftech MCP35X2 Dual Motor pump/s
Cheers.
Go to the top of the page
+Quote Post
noskcaj
post Jan 20 2013, 05:13 PM
Post #2
Atomican
what hardware do you have otherwise? if one component is far hotter than the others it may help to have it separated, otherwise your only reasons would be asthetic
Gaming PC: Case: Silverstone SuGo SG09 Mobo: Asrock z77 extreme4-m CPU: intel i7-2600k @4.6Ghz GPU: Powercolor PCS+ 7950 RAM: 8gb 1600mhz corsair Storage: 240gb OCZ agility 3 (OS) + 1tb WB black (unused) PSU: OCZ ModXtream 600w
I am head of testing for Xubuntu, send me a PM if you would like to join the ubuntu testing team or xubuntu development team
+Quote Post
_5c077y_
post Jan 20 2013, 05:49 PM
Post #3
Quark
Initiate
Maximus IV extreme
quad channel RAM
haven't decided on cards yet, either ASUS or Gigabyte 670s
Looking at EK blocks
+Quote Post
noskcaj
post Jan 20 2013, 06:07 PM
Post #4
Atomican
since you are getting a WC loop i think a 7970 would be a better option (huge OCs).
if you don't have the mobo already the maximus V formula has WC barbs already in it.
+Quote Post
_5c077y_
post Jan 20 2013, 06:09 PM
Post #5
Quark
Initiate
I would go for ATI cards... But I'm wanting to try out nVidia's 3D vision =P and I've already got the MoBo =(
+Quote Post
noskcaj
post Jan 20 2013, 06:29 PM
Post #6
Atomican
QUOTE (_5c077y_ @ Jan 20 2013, 06:09 PM) *
AMD has good 3D as well, but ok.
+Quote Post
Modz
post Jan 21 2013, 10:33 PM
Post #7
Atomican
I'm guessing your looking at SLI then yes, duel loop is the best way. Suggesting use of the duel pump/res 5 1/2" bay setup using this config.
Pump1>CPU>Rad1>Pump2>GPU1>GPU2>Rad2>Pump1
That way the heat is removed from the water right after its source and isn't taken back into the pump/res warm and gives the coolest overall water temp.
This post has been edited by Modz: Jan 21 2013, 10:34 PM
New build Log: http://forums.atomicmpc.com.au/index.php?showtopic=54270
i2500K@4.8 - SLI GTX460s@990/2340 - 16Gb Ripjaws X 1600 - 120Gb Samsung SSD - 4.5TB Media & 3TB AV Storage - Corsair Silver 600T Case
www.atomicf1.net || www.youtube.com/user/AtomicF1Modz/featured || www.aaronwproductions.com
+Quote Post
post Jan 22 2013, 06:21 PM
Post #8
Super Hero
single loop is best if its just for core blocks cpu\gpu
ram and chipset blocks will make no difference other than looks\cost\work and if there not in there own loop they will restrict things due to how much smaller they are
2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Storm G5 - MCW60 - EK-VGA HF - MCP355 XSPC Restop - PA120.4 - Scythe GT 4x120 1440/1850rpm http://i3.photobucket.com/albums/y83/dasa09/z77rog.jpg
+Quote Post
_5c077y_
post Jan 26 2013, 11:27 AM
Post #9
Quark
Initiate
Awesome, thanks for the advice guys =) I was looking at doing the chipset / ram as well for the looks and might do some overclocking, but will see how I go I guess
+Quote Post
Modz
post Jan 26 2013, 07:33 PM
Post #10
Atomican
QUOTE (_5c077y_ @ Jan 26 2013, 11:27 AM) *
If so, add a "Y" loop in conjunction with the cpu block using Smaller gauge pipe. That way the main flow isn't bottle necked and hot water isn't being taken from cpu to chip or vis versa. Or try and get high flow mobo /ram blocks that don't restrict flow.
+Quote Post
_5c077y_
post Apr 15 2013, 08:52 PM
Post #11
Quark
Initiate
2 Months later and I still haven't finished this build... man I've been lazy =( considering I'm excited to play about 8 games at the moment lol.
So Ii decided to scrap cooling the chipset and RAM and just LC the CPU and GPUs.
having trouble deciding on the loop and utilising everything.
Wanting 1 loop but using 2 radiators, 2 reservoirs and 2 pumps...
Is the following correct?
PUMP 1 > CPU > RAD 1 > RES > PUMP 2 > GPU > RAD 2 > RES > PUMP 1
the reservoirs are stacked so 1 under the other... or should I just go:
PUMP 1 > CPU > RAD 1 > RES > RES > PUMP2 > GPU > RAD 2 > PUMP 1
Since I originally got 2 reservoirs for a dual loop system but still want to keep them for the look and to fill up 2 bays being a Danger Den case...
Thoughts / help =)
+Quote Post
post Apr 16 2013, 11:05 AM
Post #12
Super Hero
order wont mater other than what is the shortest loop
for my sli loop i went with pump>rad>gpu>cpu>gpu> http://s3.photobucket.com/user/dasa09/medi...ort=3&o=138
so for you it will probably be PUMP 1 RES > PUMP 2 RES > then for the rest it depends on your rad placement
the water should heat up less than 1c as it goes round the loop so order doesnt really mater in that respect but if you can have a rad between the cpu\gpu and one after the pumps before whatever block comes next while keeping the tubes short and without tight bends might be the ideal
+Quote Post
0 Members:
Lo-Fi Version Time is now: 20th May 2013 - 01:29 PM
