12 Pages V  « < 9 10 11 12 >
Atomic’s Most Recommended Psu’s Thread., Looking for a good PSU. Look no further than this thread.
post Mar 25 2012, 03:12 PM
Post #201
Super Hero
QUOTE (bushi @ Mar 25 2012, 03:41 PM) *
It's probably been mentioned here, but would I benifit from the AX over the HX if I'm just running 1 card and not overclocking anything?
What are the major advantages for the AX?
uses a bit less power and the fan stops under low load to make it silent
other than that your not likely to notice the other improvements
hx750\850 have much better efficency than hx 650
if your only using a single gpu and not overclock you probably only need a 400w psu max
corsair ax are much the same psu as seasonic x
This post has been edited by Dasa: Mar 25 2012, 03:15 PM
2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Storm G5 - MCW60 - EK-VGA HF - MCP355 XSPC Restop - PA120.4 - Scythe GT 4x120 1440/1850rpm http://i3.photobucket.com/albums/y83/dasa09/z77rog.jpg
Go to the top of the page
+Quote Post
bushi
post Mar 25 2012, 07:27 PM
Post #202
Atomican
Thanks man.
Looks like I'll probably go AX-650 then.
http://bfbc2.statsverse.com/sig/detail5/pc/squatter.png
i7 875k | Intel DP55KG | 6GB G-Skill Pi | Inno3D GTX580 1GB | 120GB Intel 520 + 1.5TB (+ 1.5TB backup) Seagate | Pioneer BDR-206BK | Auzentech Prelude 7.1 | Hauppauge 2200 PVR | Corsair AX750 | Silverstone FT-02BW
+Quote Post
post Mar 25 2012, 08:08 PM
Post #203
Super Hero
QUOTE (bushi @ Mar 25 2012, 08:27 PM) *
Thanks man.
its a nice psu and should have enough power to run cf\sli if you find a second card going cheap that you want
+Quote Post
post May 26 2012, 07:14 AM
Post #204
Quark
Initiate
Hey guys, is there any reason the Corsair HX650 is not in the recommended list?
Other similar corsairs are and I've noticed quite a few forum members have them, but they are missing from the list.
I figured it would have been mentioned somwhere but I've not been able to find anything directly discussing it.
Assuming there is a reason, could you suggest the best alternative?
I'm looking for a good, modular, PSU at least 550W under $150.
Thanks.
*Assuming the reason isn;t that the HX620 was replaced by the HX650??
This post has been edited by .....: May 26 2012, 07:31 AM
+Quote Post
post May 26 2012, 12:31 PM
Post #205
Super Hero
mostly its due to this thread not being updated for ~ 2 years
hx 650 is a good psu with a 7 year warranty but its efficiency isnt as good as some newer psu like this one
550W "FSP" Aurum Series Modular PSU, 80PLUS Gold, 120mm Fan,1x 20+4Pin, 1x 4+4Pin ATX, 4x 6+2 PCIE, 7x SATA, 4x Molex, 1x Floppy, Manufacture 5 Year Warranty $110
+Quote Post
post May 26 2012, 05:38 PM
Post #206
Quark
Initiate
QUOTE (Dasa @ May 26 2012, 12:31 PM) *
Maybe a comment needs to be made in the 1st post... or maybe I'm just daft and missed that completely.
Legend Dasa, Thanks!
Although I can't find good reviews (or even any images too see just how many cables are 'hardwired" if you will rather than being modular).
+Quote Post
post May 26 2012, 06:15 PM
Post #207
Super Hero
im guessing the 550w will use the same cables setup as the 650w
Mainboard cable with a 20+4-pin connector (55 cm)
AU-650M has one CPU cable with one 4+4-pin connector (55 cm)
AU-750M has one CPU cable with one 4+4-pin and one 8-pin connector (55+10 cm)
One graphics card cable with two 6+2-pin connectors (55+10 cm)
One connector for a second graphics card cable
Four connectors for peripheral power cables
Included with the PSU are:
One cable with three SATA power connectors (55+15+15 cm)
One cable with two SATA and two PATA power connectors (55+15+15+15 cm)
One cable with two SATA, two PATA and one floppy-drive power connector (55+15+15+15+15 cm)
One cable with one SATA and one PATA power connector (55+15 cm)
http://www.xbitlabs.com/articles/cases/dis...su_3.html#sect0
there is plenty of reviews of the slightly larger models around and the psu often gets slammed in the reviews as at the time its reported price put it in competition with seasonic x but now the fsp price has dropped a lot and by comparison to other psu in its current price range its not bad
This post has been edited by Dasa: May 26 2012, 06:19 PM
+Quote Post
post May 26 2012, 06:23 PM
Post #208
Quark
Initiate
hell man, above and beyond.
Thanks.
+Quote Post
Pigs can fly
post Jun 2 2012, 03:28 PM
Post #209
Atomican
I just had my motherboard and CPU die. When the XFX 750 Black editions system protection kicked in I actually thought the PSU had died. So I swapped it out for my Corsair HX 650 This lead to a puff of smoke being emitted from my motherboard when I hit the power. both PSU have the same system protection (both Seasonic based PSU's). this all happened while the machine was running at stock speeds and voltage.
So i'll give a + to the XFX 750 Black edition and a - the the Corsair HX650
Rather pissed at the Corsair PSU as it fried a very nice CPU 4.4 at 1.22v
| Asus P8Z68 Deluxe | i7 2600k 4.4GHz - 212+ | 2x 4GB G.Skill Ripjaws 2133mhz CL9 | HIS 6870 1GB@ 915MHz | Gigabyte 6870 1GB OC @915MHz | XFX 750w Black Edition 80Plus Silver |
| Corsair Force 3 120GB SSD | Samsung F3 1TB 7.2k | 2x WD Green 1TB | WD Green 2TB | Samsung Story 2TB USB 3 |
| Coolermaster HAF X | Logitech G110 | Logitech G13 | Logitech G27 | Razer Lachesis |
+Quote Post
GhostFaceKilla
post Jun 2 2012, 04:11 PM
Post #210
Atomican
QUOTE (Pigs can fly @ Jun 2 2012, 04:28 PM) *
I have a very low opinion of Corsair Power supplies. An ax 850 took out my motherboard and an ssd. Corsair replaced the AX 850 with a new one and an 'apology'. I have sought a replacemnt OCZ ssd and am still trying for a new motherboard from ASUS. Not sure if I want to use the new ax 850 again. Its main benefit was that it was silent at low loads. But so are the equivalent Seasonics which have had little to no issues. Strange as the AX series are based on the Seasonics. Except for the ax 850.
Still recommened unequivocally Antec PSU's.
And Seasonic.
http://www.youtube.com/watch?v=znodcpMzcnA&feature=player_embedded
+Quote Post
iamthemaxx
post Jun 2 2012, 04:21 PM
Post #211
Atomican
Super Hero
Given this thread hasn't been updated in years, is anyone interested in taking it over with a V2? Or shall I just unsticky this?
+Quote Post
post Jun 2 2012, 11:01 PM
Post #212
Super Hero
QUOTE (GhostFaceKilla @ Jun 2 2012, 05:11 PM) *
And Seasonic.
corsair ax 850 is seasonic its the ax 1050w thats different its flextronics and a bunch of corsair cheaper models are cwt
its a great psu but unfortunately even the best can go seriously wrong occasionally :(
http://www.jonnyguru.com/modules.php?name=...y4&reid=197
be nice if someone would bring life back tho this thread
This post has been edited by Dasa: Jun 2 2012, 11:01 PM
+Quote Post
GhostFaceKilla
post Jun 3 2012, 09:15 AM
Post #213
Atomican
QUOTE (Dasa @ Jun 2 2012, 11:01 PM) *
And Seasonic.
Thanks Dasa. My original interpretation was that the ax850 while based on aspects of the Seasonic models was modified somewhat. From what I can gather my issue was related to its voltage regualtion. Something screwed up big time. My concern is that the design is prone to this.
+Quote Post
cohmoddersolo
post Jun 3 2012, 02:58 PM
Post #214
Atomican
Please dont let this thread go. Im pretty sure this thread has steered people in the right direction for PSU's as their not really a thing you'd be messing around with. Just like our hearts. I think the community should contribute recommendations and rebuild this thread with it.
Anyways, I'm looking into buying a new efficient PSU that wont blow my bank and wondering if an Antec Earthwatts Platinum 650w will power 2 GTX 560 OCed, i5 2500k or 3570k OCed to 4Ghz, a HDD and SSD and 6 case fans with platinum rating efficiency. Its got only 2 PCI-e (6+2) cables but Ive got some 4 pin to PCI-e connectors. Maybe the Corsair AX650 Gold is the last resort if I cant find anything cheaper with high efficiency. Cheers.
This post has been edited by cohmoddersolo: Jun 3 2012, 02:59 PM
+Quote Post
iamthemaxx
post Jun 3 2012, 03:58 PM
Post #215
Atomican
Super Hero
Given the OP hasn't updated it in 2 years it's already gone.
All I am suggesting is it might be best to restart it with more current information and a link to this one to retain history.
+Quote Post
.:Cyb3rGlitch:.
post Jun 3 2012, 04:18 PM
Post #216
Mod
Hero
I didn't even realise how old this thread was!
"Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
+Quote Post
mohawk
post Aug 6 2012, 07:21 PM
Post #217
Atomican
Sorry guys.
Yes I have been really slack with up dating this list and I apoligise to the community for my slackness.
Ok this is what I am prepared to do.
In the next couple of weeks I will hit the books and get the list up to date.
Atomic's Most Recommended Psu's Thread.
http://forums.atomicmpc.com.au/index.php?showtopic=266
+Quote Post
post Aug 18 2012, 11:30 AM
Post #218
Super Hero
thanks mohawk it would have been a shame to lose this
found an interesting new budget psu fsp raider lowest price in au is 550\650w $53.9 450w $60
it peaks at ~90% efficient and its low load efficiency on 240v is better than antec ea platinum also made by fsp so it isnt bad considering its a cheaper version of it
but it does have some down sides the 650w model gets a little lose with vreg ect once you get around 500-650w but still within spec so its not terible for the price and anyone that has a pc that uses 500-650w should be spending more on the psu anyway
http://www.anandtech.com/show/6013/350450w...1-cheap-psus/17
http://www.hardwaresecrets.com/article/FSP...ply-Review/1610
+Quote Post
mohawk
post Aug 21 2012, 12:53 PM
Post #219
Atomican
OK guys I have started to update the list. More will follow.
Added:
• FSP Raider 650w
• In Win GreenMe 650w
• Corsair GS700w
• Xigmatek Tauro 700w
• In Win GreenMe 750w
This post has been edited by mohawk: Aug 21 2012, 12:53 PM
+Quote Post
post Oct 1 2012, 07:38 PM
Post #220
Super Hero
finally found a low wattage 80plus gold psu thats available in au Huntkey Jumper 300G $101
http://www.anandtech.com/show/4069/huntkey-300w-80plus-gold
http://www.hardwaresecrets.com/article/Hun...y-Review/1362/1
+Quote Post
0 Members:
Lo-Fi Version Time is now: 22nd May 2013 - 02:27 AM
