Asus Xonar DX Not Detected, AudioCard not being detected |
Jan 29 2011, 10:31 AM
Post
#1
Quark Apprentice |
Hi, hoping for some help with my Xonar DX.
I am running the system in my signature with win 7 64 bit. When I installed the Xonar dx and rebooted it ran fine. However once I shut down and turned it back on it does not detect the card at all, not in device manager or anything. I can’t get the Xonar software to run either. At this point, if I try to reinstall the driver, it tells me the CARD IS NOT DETECTED and I have to cancel the reinstall. If I now restart the computer it loads the driver up fine and even remembers my previous settings. I have tried looking up EEPRom error but I can’t see the card when it fails to load, and when it does load the EEPROM looks correct. I have also heard of PCI/PCI-e bridge detection problems in these cards but as I understood this was only for nvidia sli capable motherboards, and hence the fix was for sli boards too. So I am now stuck with turning my computer on, attempting an install of the driver and then doing a restart before I can use sound. To clarify, I have the motherboard sound disbabled in bios and the realtek drivers disabled in the os. I can’t try another pci-e slot on my mobo as the first one is blocked by motherboard heatsink. Do I return the card and try for a pci card like the Asus ST or return the card and try another Xonar DX. Or does someone know of a fix? Thanks Tyrone -------------------- ibuiltit
e8500 cpu, GB EP45 ds4p, Asus 5850 1gb gpu, Xigmatek S1283 HSF lapped, Asus Xonar DX sound card, TT Armour case, Corsair 750TX psu HDD 750gb & 500gb F1 spinpoint, zboard, G5 mouse, Beyerdynamic DT234 phones, logitech Z263 speakers, [i]It's like the rage that I feel from being bombarded with stupid is sitting in my sack and squeezing all the life from my balls, .[/i] disolusiond |
Jan 29 2011, 01:46 PM
Post
#2
Atomican Guru ![]() |
Have you tried the card in another system? And just to make sure, you've plugged in the power cable?
-------------------- "TheFrunj doesn't guess, when he forms words with his lips, the world will Warp and change to do his bidding." - Shikimaru
No longer writing for Atomic :( http://forums.atomicmpc.com.au/index.php?showtopic=49899 |
Jan 29 2011, 02:22 PM
Post
#3
Quark Apprentice |
Have you tried the card in another system? And just to make sure, you've plugged in the power cable? Yes have checked the power cable, (2 or 3 times lol) as I heard this can be a problem. Will try in my wife's computer (didn't think of the obvious) in the next day or two and post back on how that turns out. Cheers Tye -------------------- ibuiltit
Feb 1 2011, 04:17 PM
Post
#4
Quark Apprentice |
Okay, solved it.... I am pretty sure.
I went through the uninstall program manager to unistall the xonar drivers before removing the card (and swapping to another pc as TheFrunj suggested) and I saw that I had not uninstalled the realtek hd sound drivers. I had disabled them in the sound control menu, disabled the chip in the bios but not unistalled the drivers, um yep, good. Unistalled these and reinstalled the xonar drivers after a reboot, and now when I shut down and turn the computer back on from being powered off the xonar drivers are there and the card works. So thanks TheFrunj because without your suggestion I wouldn't have found I'd left the old drivers in. Tye -------------------- ibuiltit
Feb 1 2011, 04:36 PM
Post
#5
No worries, the Xonar drivers can be pretty fickle sometimes (especially with Skype). Glad you worked it out :)
| Lo-Fi Version | Time is now: 26th May 2013 - 02:04 PM |
