error: "class Db" has no member named "exists" |
Feb 12 2011, 05:59 PM
Post
#1
Hero Pun Savant ![]() |
Okay, so I get an error when compiling, and I'm trying to track down the source of the problem (since dependencies on this system are a bit strange). The problem is that I can't seem to find where "class Db" actually originates from. Any suggestions on how I could track it down?
CODE [root@localhost src]# make -f makefile.unix bitcoind g++ -c -O2 -Wno-invalid-offsetof -Wformat -g -D__WXDEBUG__ -D__WXGTK__ -DNOPCH -DFOURWAYSSE2 -DUSE_SSL -I"/usr/local/include/wx-2.9" -I"/usr/local/lib/wx/include/gtk2-unicode-debug-static-2.9" -o obj/nogui/util.o util.cpp db.h: In member function âbool CDB::Exists(const K&)â: db.h:146: error: âclass Dbâ has no member named âexistsâ make: *** [obj/nogui/util.o] Error 1 [root@localhost src]# grep -R "Db" ./ | grep -v "Dbt" | grep -v "Dbc" | grep -v "DbT" ./db.cpp:static bool fDbEnvInit = false; ./db.cpp:DbEnv dbenv(0); ./db.cpp:static map<string, Db*> mapDb; ./db.cpp: if (fDbEnvInit) ./db.cpp: fDbEnvInit = false; ./db.cpp: if (!fDbEnvInit) ./db.cpp: fDbEnvInit = true; ./db.cpp: pdb = mapDb[strFile]; ./db.cpp: pdb = new Db(&dbenv, 0); ./db.cpp: mapDb[strFile] = pdb; ./db.cpp:void CloseDb(const string& strFile) ./db.cpp: if (mapDb[strFile] != NULL) ./db.cpp: Db* pdb = mapDb[strFile]; ./db.cpp: mapDb[strFile] = NULL; ./db.cpp: printf("DBFlush(%s)%s\n", fShutdown ? "true" : "false", fDbEnvInit ? "" : " db not started"); ./db.cpp: if (!fDbEnvInit) ./db.cpp: CloseDb(strFile); ./db.cpp: fDbEnvInit = false; ./db.cpp: CloseDb(strFile); ./db.cpp: CloseDb(strFile); ./db.h:extern DbEnv dbenv; ./db.h: Db* pdb; [root@localhost src]# Thanks, Rob. |
Feb 13 2011, 09:08 AM
Post
#2
Atomican Master |
locate would be a good start. See if the file actually exists somewhere.
Could be you need to install an additional package for "WXWindows"? I assume that is the library you are using. -------------------- poweredbypenguins.org - SledgY lives in the cloud...
Feb 13 2011, 10:21 AM
Post
#3
locate would be a good start. See if the file actually exists somewhere. Which file? Could be you need to install an additional package for "WXWindows"? I assume that is the library you are using. I don't actually have WxWidgets installed, that's why I'm compiling "bitcoind" (as opposed to "bitcoin", which spits out many errors about missing WxWidgets header files) which doesn't require WxWidgets. I see no reason to suspect this compiler error is due to WxWidgets. Rob This post has been edited by robzy: Feb 13 2011, 10:25 AM |
Feb 13 2011, 10:42 AM
Post
#4
Okay, something funny was going on with the dependencies. CentOS has a number of older libraries, and it would appear BitCoin didn't like them.
Using these notes as a guide I was able to compile all the required dependancies to their own directory and just point the BitCoin build at them. Rob. |
Oct 26 2011, 12:31 AM
Post
#5
Atomican Charge ![]() |
"class" ... presumably in cpp definitive keyword concievabley but not nescissarilly maybe in the actual DB name as in a school not the programming language.
-------------------- http://sidewinder11sucommanderxer.podserver.info/SideWinderColourBalancer(EBLA4-Linux-Win-Oct-2012(Oct-fix)).zip
| Lo-Fi Version | Time is now: 26th May 2013 - 01:57 PM |
