Flashed my 2 6850's to 6870's, dang nice
lightrevealed
post Mar 6 2011, 11:10 PM
Post #1
Quark
Apprentice
So I flashed my 2 sapphire 6850 cards to a 6870 bios using RBE or radeon bios editor.
It still keeps the 960 stream processors but core jumps to 900mhz and 1.172v and mem to 1050mhz.
I then overclocked the mem further to 1150mhz.
Final result in Heaven v2.1 was:
FPS: 62.9
SCORES: 1585
MIN FPS: 21.0
MAX FPS: 146.9
Not sure if thats good or not but I am happy with it, and certainly destroys my old 5870 card.
AMD Phenom II 1090T 6 core @ 4.1ghz 24/7
MSI 890FXA-GD70
8gig G.Skill Ripjaws DDR3 1600mhz
CROSSFIRE 2 Sapphire 6850's flashed to 6870 @900mhz
Zalman CNPS9700 NT CPU Cooler
Zalman ZM-MFC2 FAN Controller
Soundblaster X-Fi Extreme
Win7 64bit Home Premium
OCZ 120GB Vertex II SSD
750w OCZ crossfire ed
Thermaltake Armor MX
http://www.youtube.com/watch?v=iZBD0TX4lfM
Go to the top of the page
+Quote Post
nobody813
post Mar 7 2011, 07:40 AM
Post #2
Atomican
Wow, I've never heard of that being done before
Good work mate
"If the forums were just Opy talking about World of Tanks, I'd... okay, maybe not." - hawkeye
AMD Phenom II X6 1090T | 8GB G.Skill Ripjaws DDR3 | Sapphire Radeon 5870 | 120GB Intel 520 (Windows 8) | 1TB Seagate 7200.14 (Programs) | 500GB WD Blue (Data) | 160GB Samsung Crapper (Ubuntu 13.04)
+Quote Post
lightrevealed
post Mar 12 2011, 10:57 AM
Post #3
Quark
Apprentice
QUOTE (nobody813 @ Mar 7 2011, 08:40 AM) *
Good work mate
Thanks man! Its pretty easy to do and a huge boost to this card which makes the $210 spent big value :) on each card.
MSI 890FXA-GD70
+Quote Post
sora3
post Mar 12 2011, 11:16 AM
Post #4
Atomican
Odd. Unless the 6850s are also 6870s that can't be 6870s... >>
Main Rig: AMD FX-8320@ 4.4GHz/Asus Sabertooth 990FX/8GB G-Skill Ripjaws DDR3-1600@1766/Sapphire HD 7870@1050/5000/OCZ Vertex 2 120GB/Bitfenix Shinobi/Noctua NH-D14/Corsair HX-750
Camera rig: Sony Alpha a77/Sony DT 16-50mm f2.8 SSM/Sony DT 16-105mm f3.5-5.6/Tammy 70-200mm f2.8/Sony DT 50mm f1.8/Sony HVL F42AM Flash
+Quote Post
nesquick
post Mar 13 2011, 08:55 AM
Post #5
Atomican
QUOTE (sora3 @ Mar 12 2011, 11:16 AM) *
yea pretty much, like I flashed my GTX570 to a 580 but didn't get the extra shaders but its still a 580.
STEAM/BC2 name: AllNightmareLong
+Quote Post
taza438
post Apr 23 2011, 06:24 AM
Post #6
Lurker
Serf
can you please post a step by step tutorial so i can flash my 6850 to a 6870 btw it is a sapphire too...and if you can post the bios you flashed its way simpler:)
+Quote Post
nesquick
post Apr 23 2011, 07:19 AM
Post #7
Atomican
QUOTE (taza438 @ Apr 23 2011, 06:24 AM) *
no need to waste your time with it, just use afterburner and up the clocks.
+Quote Post
amdDarcy
post Apr 23 2011, 05:05 PM
Post #8
Atomican
Thinking about getting this card myself and upgrading from my trusty old 4850!!! Good to know.
+Quote Post
deejeta
post Apr 24 2011, 02:24 PM
Post #9
Atomican
Journeyman
great work on the flash man, always good to get a free upgrade pretty much.
note though for those considering flashing their 6850 - , 6850's are either 6870's that didnt make the grade or are flashed to make the model quota. some will flash fine, others may crap themselves. backup the original bios, and have a backup video card in case the flash goes wrong.
and remember when using RBE dont have anything running in the background while it flashes. for a whole heap of bios files head over to http://www.techpowerup.com/vgabios/
Q9550 @4.25 w/cooled || Gigabyte P45 UD3-P || 8 gb DDRII ||GTX 480 w/cooled || Lots of HD's, Patriot Inferno SSD || LG W2242T ||
--------------Vantage- P25876-------------------Wprime 32m - 11.765-----------------------
+Quote Post
Mr.Twinkie
post May 8 2011, 07:20 PM
Post #10
Atomican
Sounds so juicy good. Lucky you.
"Ignorance is a luxury that you cannot afford"
If you know you can do better, you will do better.
And where there's a will, there's a way and you can always find the way....
+Quote Post
phill360
post May 23 2011, 05:38 PM
Post #11
Lurker
Serf
So would you recommend the 6850 or spend the extra $30 and get the 6870?
Intel 2600K, ASUS Z68 Pro M/B, Gigabyte 560Ti, 8Gb GSkill Ram, Corsair H60 Cooler, Corsair H750, LG BluRay Writer, Fractal Design R3
+Quote Post
Brissmas
post Jun 13 2011, 10:52 AM
Post #12
Atomican
QUOTE (phill360 @ May 23 2011, 05:38 PM) *
Go with the 6870.
i7 920 c0 3.6ghz@1.3v||EX58-UD3R rev 1.6||6gb Hyper X 1600mhz||Palit GTX480||Modded Generic Case||Antec NEO ECO 620w
XSPC RX120 push/pull||XSPC Rasa||Swiftech VGA HF Supreme (Not installed yet)
+Quote Post
matarael
post Jun 15 2011, 07:51 PM
Post #13
Atomican
That's cool. I've only ever heard of the 69xx flash.
Good work,
+Quote Post
Jeruselem
post Jun 16 2011, 02:35 PM
Post #14
Atomican
I guess some cards are so similar you can do this.
Resident KatyCat
Smartphone: HTC Trophy T8686 - WP 7.10.8107.79 (aka Mango updated)
Netbook: ASUS EEE PC 1015PN - Win7 Pro, Intel N550@1.5Ghz, 2GB RAM, 250GB WD SATA, nVidia ION2
Laptop: Win8 Home x64, Intel i5-430 @ 2.26Ghz, 4GB RAM, 240GB Corsair SSD, nVidia Geforce GT310 1GB
Work PC: Win7 Pro x86, Intel Q9550@2.83Ghz, 4GB RAM, 2 x 250GB SATA, nVidia Quadro FX1700, 600W PSU
+Quote Post
lightrevealed
post Jun 17 2011, 11:33 PM
Post #15
Quark
Apprentice
Yes just go to the techpowerup website, linky above in deejeta's post, and download the 6870 bios, I had sapphire cards so choose a saphire 6870 bios.
Download radeon bios editor or RBE, I had to force the bios write though, as it wouldn't do it the traditional way.
You will have to read through the RBE to understand what your doing and the risk, as you could kill your card.
I had two so no biggie, plus I love playing with tech and pushing it.
My mate has 2 6870 saphires in crossfire and he only gets 2fps more in heaven benchmark.
But his are alot hotter then my cards, lol, and use more juice too.
But if the price is right then go for the 6870, this was just a 'see you can do it' if you want to post.
I got the original idea from here http://hardforum.com/showthread.php?t=1562148
when I was looking at ways to improve performance.
Just had to add this, out of both the cards one of them can overclock to 950mhz on the core and the other to 930mhz on the core, both can run 1180mhz on the memory.
Good luck.
This post has been edited by lightrevealed: Jun 17 2011, 11:37 PM
MSI 890FXA-GD70
+Quote Post
lightrevealed
post Jun 18 2011, 12:00 AM
Post #16
Quark
Apprentice
GPUZ screeny showing the new default clock speed of 900mhz.
This post has been edited by lightrevealed: Jun 18 2011, 12:02 AM
MSI 890FXA-GD70
+Quote Post
mattyamdfanboi
post Jun 19 2011, 03:42 PM
Post #17
Atomican
Charge
how is a gtx 570 with no extra shaders a 580??? lol unless it has 512 cudas, it aint a 580 mate.. its still a 570 with a 580 bios hahah
Rig 1: Phenom II x6 1055T 4ghz, Inno3D GTX 580 x2 900/1800/2150 + GTX 460 900/1800/2000 (Physx + Folding), 4gb Kingston ValueRam @ 1524mhz + 4gb Kingston HyperX Blu 1524mhz, 890FXA-UD5 Gigabyte, Corsair TX850 PSU
+Quote Post
0 Members:
Lo-Fi Version Time is now: 23rd May 2013 - 06:42 AM
