Stupid things you forget when building a pc, Things which you should remember from doing a million and 1 times |
Mar 18 2011, 06:39 AM
Post
#1
Hero Titan ![]() |
So last time I put my watercooling loop together, which was a few months ago (early january) I put my 2 GPUs on water with 2 Swiftech MCW80 GPU blocks, I also added another radiator to the loop.
It was all working well for a while, until I noticed a difference in the GPU temps, 1 was always 5-10c higher than the other, without fail, I thought it may have just been a dodgy mount or simply the top card running hotter than the bottom card due to slightly higher load and what not. Last week my watercooling loop shit itself, it already had quite a low flow rate and I daresay something got stuck in one of the GPU blocks, as one of them was hitting over 100c after less than 1 minute of load, I put this down to the flow rate problem, which I had been having troubles with since I put the loop together. I ordered a new radiator, reservoir and pump from gammods last week and received it on Friday, on Sunday I went to stay at Dasa's for a few days (3 hour trip!) to do a bit of a case mod and install my new gear. We took the GPU blocks apart and cleaned them out, while doing that I noticed something... On the bottom of one of my GPU blocks was a flap of plastic, I peeled it off, revealing a nice shiney copper plate, damnit! I'd forgotten (most likely in my haste to get the GPU blocks mounted) to remove the plastic protective film, every aftermarket cooler I have bought has had one of these and I've never forgotten to take it off, ever. After removing it, GPU temps are now identical, silly me. Anyone else done something that you know is completely stupid and out of character when it comes to building PCs? Share your horror stories! -------------------- My Rig: ASUS P67 Sabretooth | i5 2500k @ 4.6ghz w/ Corsair H80 | 8gb G.Skill Ripjaw-X 1866mhz | 2x7950 @ 1000mhz CrossfireX| NZXT Phantom | Corsair HX850
Mar 18 2011, 07:06 AM
Post
#2
Lurker Serf |
That red switch on the back of old power supplies....
Mar 18 2011, 08:11 AM
Post
#3
Lurker Serf |
The little blue tab on the end of a network cable protecting the pins. Spent close to an hour troubleshooting that one..
Mar 18 2011, 08:21 AM
Post
#4
Atomican Master ![]() |
That red switch on the back of old power supplies.... I'm guilty of that one. -------------------- h.IV+[Kymatica]
Mar 18 2011, 09:01 AM
Post
#5
plugging in 3 fans to some of those molex splitters, spent a good half hour wondering why the bleep my fans weren't spinning up, unplugging replugging these cables, till i saw i hadn't actually hooked up the end of this mess of wires to the PSU, good thing i was alone, no one to mock me.
-------------------- --- CLEVO HORIZE P150HM --- i7-2720Qm --- 8GB DDR3 1333Mhz --- 500GB 7200RPM --- 15.6-inch FHD LED --- nVidia Geforce GTX485M 2GB GDDR5 ---
Mar 18 2011, 09:08 AM
Post
#6
Mod Hero ![]() |
plugging in 3 fans to some of those molex splitters, spent a good half hour wondering why the bleep my fans weren't spinning up, unplugging replugging these cables, till i saw i hadn't actually hooked up the end of this mess of wires to the PSU, good thing i was alone, no one to mock me. I've done that before. :P -------------------- "Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
Mar 18 2011, 09:14 AM
Post
#7
Atomican Titan ![]() |
sometimes when I'm troubleshooting PCs at work, I'll put the jumper on to clear the CMOS, and sometimes I forget to put it back again.
Usually this means the PC won't boot, and I'll scratch my head for 15 minutes trying to figure out why -------------------- Put your monkey where your mouth is.
These are the voyages of the starship Lucy Liu. What's On My Mind? http://twitter.com/smadge1 http://smadge1.tumblr.com/ |
Mar 18 2011, 09:35 AM
Post
#8
I'd like to say I don't make mistakes, well I don't anymore...
first and last major mistake was trying to put a delta fan on a TRUE while the computer was on, not only did my finger get 5mm shorter but one of the metal fan clips fell off and landed on a HD4870 and fryed all the resistors, luckily I got an RMA for that one. -------------------- STEAM/BC2 name: AllNightmareLong
Mar 18 2011, 09:42 AM
Post
#9
Hero Overlord |
The one I've been doing lately, fiddling with old AT motherboards...
set up the board on a test bench,plug in HDD, floppy etc... very gingerly turn on the power switch to avoid getting bitten by 240V... hard drives spin up, no beeps, nothing on screen. Crap, another dead board. Turn the power off and start pulling it apart only to notice that I'd forgotten to plug the two power connectors into the motherboard :P Also, a dude I knew who worked at a computer shop quoted a customer on a $2000 PC and forgot to include any RAM. They didn't notice until the parts arrived and he want to build it. Wasn't a big deal, they just threw in a stick from their stock but we gave the dude plenty of shit about it. -------------------- 486DX4-100|16MB|ET4000W32/P VLB|GUS Classic|CT2800 SB16+XR385|DOS6.22
386DX-40|8MB|ET4000|CT1690 SBPRO+Sony CDU33A|Music Quest MPU401|Roland SC55+MT32|DOS5 286-10|1MB|ATI EGA WONDER|1987 Adlib|Roland LAPC-I|CT1300 CMS|Above Board 2MB EMS|ST251 42MB|DOS3.3 AMIGA 1200|ACA1230/42 64MB|1084S AMIGA 500|A501 512KB |
Mar 18 2011, 09:45 AM
Post
#10
Quark Apprentice |
power to the GPU ........... fucks me every time.
-------------------- * Steam & Xbox Live Name - xXl STIG lXx
Mar 18 2011, 09:58 AM
Post
#11
Super Hero Guru ![]() |
bumped a vmod on my 8800gt gs 1g when installing a new mb\cpu which made it short across the pins pumping max v into the gpu rather than a moderately increased amount
after repeatedly trying to post checking things to try work out what was wrong with me being worried i had bent some of the socket pins due to all the crunching noise the socket made as i clamped in the q9450 (first pinned socket) it eventuly let out a puff of smoke when it hit me what had happened it must have been pumping as much v as it possibly could into that poor little gpu a sad day indeed but the timming couldnt have been better as the 4870x2 was just out so i placed my preorder and had a great card for the next 2 years the rest of my mistakes with pc's i seem to have conveniently forgotten :) which probably meens i have also forgotten the lesson learnt and will repeat them some day :( -------------------- 2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Storm G5 - MCW60 - EK-VGA HF - MCP355 XSPC Restop - PA120.4 - Scythe GT 4x120 1440/1850rpm http://i3.photobucket.com/albums/y83/dasa09/z77rog.jpg |
Mar 18 2011, 10:00 AM
Post
#12
Atomican Overlord |
forgot to plug in the 2nd 6 pin to my GPU...
i havent killed any hardware..yet -------------------- Atomic's wannabe LN2 Junkie
Soon:Project "Giga-bench"- In progress Main Rig: GA-X58A-UD7(v2)|i7 950|12gb Corsair XMS3 1600mhz|Gigabyte GTX 460 768mb/580 SOC|Coolermaster HAF X |1TB WD Black HDD||Pionner DVDRW|Corsair HX850w|Logitech X530|Dell U2711+ AOC 17"|Logitech G500|Logitech G510|HD 280 Pro Steam Name:jim_jam333/jimba86 Xbox 360 S 250GB + Kinect owner |
Mar 18 2011, 10:03 AM
Post
#13
Atomican Overlord ![]() |
thermalpaste........
Mar 18 2011, 10:12 AM
Post
#14
Hero Titan ![]() |
After installing my first GTX480 in my Raven RV01 I knocked my watercooling tubes, which were using compression fittings, didn't notice until I looked into my case to see water dripping out of the cpu block. Took it all apart, dismantled the loop to drain it etc. then put it back together but forgot to plug my fans back in on the radiator, the result?
Super heated tube that came loose of the compression fittings again and caused another leak. Thank fuck I had distilled water in there and didn't fry everything, lesson learnt there, now every time I touch my watercooling/move my case I check for leaks before booting. Also have given up on using compression fittings, 1/2" barbs, 3/8" tube and steel hose clamps now :D I forgot to put SLI/Crossfire bridges in all the time too, pain in the ass, but not hard to fix :P I tend to rush when I'm putting my PC together, which is a big mistake, took my time with the last rebuild but still forgot the SLI bridge :P -------------------- My Rig: ASUS P67 Sabretooth | i5 2500k @ 4.6ghz w/ Corsair H80 | 8gb G.Skill Ripjaw-X 1866mhz | 2x7950 @ 1000mhz CrossfireX| NZXT Phantom | Corsair HX850
Mar 18 2011, 10:35 AM
Post
#15
yea rushing is when you make mistakes, any build I do I just take my time and revel in the new tech I am installing :D
Mar 19 2011, 10:57 AM
Post
#16
Atomican Primarch ![]() |
plugging in 3 fans to some of those molex splitters, spent a good half hour wondering why the bleep my fans weren't spinning up, unplugging replugging these cables, till i saw i hadn't actually hooked up the end of this mess of wires to the PSU, good thing i was alone, no one to mock me. I'm guilty of that, and I think I've made the same mistake on both previous builds too. -------------------- Xbox Live: jjgrubb
Steam ID: jjgrubb13 ------------------------------------------ Current PC Specs: i5 760, GA-P55A-UD3R | 4GB G.Skill Ripjaws DDR3-1600 | eVGA 1GB GTX460 Coolermaster Hyper 212+ | Corsair HX650 | Fractal Design R3 G110 Gaming Keyboard | MX1000 Bluetooth Mouse Samsung 226BW 22" Monitor |
Mar 19 2011, 01:37 PM
Post
#17
ahh a list of things
the little red switch. the cpu power the gpu power the hdd power one end of a sata cable no sata cable mixing up the power and reset button trying to install a dvd drive upside down. -------------------- “Jealousy is that pain which a man feels from the apprehension that he is not equally beloved by the person whom he entirely loves”
Joseph Addison |
Mar 19 2011, 02:50 PM
Post
#18
ahh a list of things the little red switch. the cpu power the gpu power the hdd power one end of a sata cable no sata cable mixing up the power and reset button trying to install a dvd drive upside down. on some of those sounds like you need to: RTFM This post has been edited by nesquick: Mar 19 2011, 02:51 PM -------------------- STEAM/BC2 name: AllNightmareLong
Mar 19 2011, 03:25 PM
Post
#19
Hero Guru ![]() |
Water pump, forgot to plug it in, like 3 years ago, no damage was done though =D
Also Nuke, I'm surprised that overheated with passive radiator use, when I turn my fans off, my temps slowly creep up and sit highish, but nothing more than stock cooling would. Seems odd to me. This post has been edited by morgoth: Mar 19 2011, 03:26 PM -------------------- 2011 Atomic 3DMark & Game Benchmark Rankings !! http://forums.atomicmpc.com.au/index.php?showtopic=41178
Current PC (no lie) Athlon XP-M 2400+@2640MHz (3d) / Abit NF7-S2.0 Vmodded / 1Gig OCZ Gold EL GX BH-5 / ATI Radeon 9800XT@500MHz |
Mar 19 2011, 03:28 PM
Post
#20
Mod Hero ![]() |
on some of those sounds like you need to: RTFM Return, Trade For Mac? -------------------- "Great minds discuss ideas; Average minds discuss events; Small minds discuss people." - Eleanor Roosevelt
| Lo-Fi Version | Time is now: 22nd May 2013 - 08:44 AM |
