Want a $25 linux running PC that fits in your pocket?, No really, a whole PC (DVD burner be damned) |
May 7 2011, 03:03 PM
Post
#1
Atomican Champion ![]() |
http://news.cnet.com/raspberry-pi-computer...20060489-1.html
QUOTE A British nonprofit has a novel idea for getting kids interested in computer programming--a computer that fits in a pocket and costs less than the latest video game. ![]() It's called Raspberry Pi, and the prototype isn't pretty--it looks like a leftover scrap from electronics recycling day. But it's a working computer that game developer David Braben and his Cambridge-connected colleagues expect to make available for only $25 for a fully configured system. 700MHz ARM11 128MB of SDRAM OpenGL ES 2.0 1080p30 H.264 high-profile decode Composite and HDMI video output USB 2.0 SD/MMC/SDIO memory card slot General-purpose I/O Open software (Ubuntu, Iceweasel, KOffice, Python) Could be a very cheap way to setup virtual machines around an office. I'd make millions! |
May 7 2011, 03:13 PM
Post
#2
Atomican Super Hero |
You could run some low volume servers on them, postfix, ngix etc.
A little more RAM and you could run a DB! |
May 7 2011, 04:20 PM
Post
#3
Atomican Guru ![]() |
I think it needs a $5 case to cover it. Like that, it's asking to be damaged.
-------------------- Resident KatyCat
Smartphone: HTC Trophy T8686 - WP 7.10.8107.79 (aka Mango updated) Netbook: ASUS EEE PC 1015PN - Win7 Pro, Intel N550@1.5Ghz, 2GB RAM, 250GB WD SATA, nVidia ION2 Laptop: Win8 Home x64, Intel i5-430 @ 2.26Ghz, 4GB RAM, 240GB Corsair SSD, nVidia Geforce GT310 1GB Work PC: Win7 Pro x86, Intel Q9550@2.83Ghz, 4GB RAM, 2 x 250GB SATA, nVidia Quadro FX1700, 600W PSU |
May 7 2011, 05:33 PM
Post
#4
Atomican Primarch |
Why Braben is making this and not the next elite/x3 killer, I'll never know.
May 7 2011, 06:05 PM
Post
#5
Atomican Champion |
I think I've just found the board to complete my monitor into photo frame project! :-D
May 7 2011, 06:24 PM
Post
#6
Hero Titan ![]() |
Whats the point of something that can fit into your pocket if it needs to be out of your pocket to plug in? :P
-------------------- My Rig: ASUS P67 Sabretooth | i5 2500k @ 4.6ghz w/ Corsair H80 | 8gb G.Skill Ripjaw-X 1866mhz | 2x7950 @ 1000mhz CrossfireX| NZXT Phantom | Corsair HX850
May 7 2011, 08:25 PM
Post
#7
Whats the point of something that can fit into your pocket if it needs to be out of your pocket to plug in? :P If I can get my hands on one I'm going to pick one up to play around with. Im sure you could solder on more ram :) -------------------- 3930K || ANTEC KUHLER 920|| ASUS Rampage IV ||16GB Corsair Vengence DDR3@1877mhz||ATI 7970||120GB Vertex 3 MAX IOPS||4x3tb||DELL2711||Corsair 650D|| ASUS Essence STX ||Audio Engine A2's||Aiaiai:TMA-1||Enermax 1050w||
Atomics resident filth |
May 8 2011, 03:06 PM
Post
#8
Atomican Charge |
Whats the point of something that can fit into your pocket if it needs to be out of your pocket to plug in? :P Well, in it's intended market (education) it's a very useful feature. Students could plug the machine in at school, do some work with it in class and then unplug it and take it home to do homework. If you have screens and peripherals at both home and school, you may as well take as little of the PC when you are going between them. My only concern is WRT the power supply. It seems to use the HDMI 5V pin for power, yet HDMI is the rarest of all the connections available, coming only in high-end monitors and HDTVs. They'll have to build a HDMI-based power brick for it as well. At least it has composite out as well. -------------------- You can lead a man to knowledge but you cannot make him think.
May 8 2011, 08:23 PM
Post
#9
Hero Overlord ![]() |
Think I'll have to buy a couple of these. Running Ubuntu too.
May 8 2011, 10:28 PM
Post
#10
Hero Guru ![]() |
Whats the point of something that can fit into your pocket if it needs to be out of your pocket to plug in? :P Well, in it's intended market (education) it's a very useful feature. Students could plug the machine in at school, do some work with it in class and then unplug it and take it home to do homework. If you have screens and peripherals at both home and school, you may as well take as little of the PC when you are going between them. My only concern is WRT the power supply. It seems to use the HDMI 5V pin for power, yet HDMI is the rarest of all the connections available, coming only in high-end monitors and HDTVs. They'll have to build a HDMI-based power brick for it as well. At least it has composite out as well. I'm not sure of the proliferation in the UK, but even super cheap HDTVs have HDMI. And I know quite a lot of low income families that have them... -------------------- I<3G
Kikz: Good for you, your sig says something. whoop-de-do dude. |
May 8 2011, 11:04 PM
Post
#11
Atomican Charge |
I'm not sure of the proliferation in the UK, but even super cheap HDTVs have HDMI. And I know quite a lot of low income families that have them... If it's going to be used in the 3rd world, it will need an external power supply. Unless it's being aimed solely at equalising first-world computer access, which I hope it isn't. It's still a fundamentally good idea - learning to use a CLI and scripting always is. -------------------- You can lead a man to knowledge but you cannot make him think.
May 9 2011, 09:22 AM
Post
#12
Mod Super Hero ![]() |
Lancer: Odds are, they could couple this with the One Laptop tech, and have a portable hand-cranked dynamo.
I would expect it would be pretty trivial to re-wire it to use a standard barrel connector from another power source. -------------------- Romans 10:3
absit iniuria verbis |
May 9 2011, 10:09 AM
Post
#13
Lancer: Odds are, they could couple this with the One Laptop tech, and have a portable hand-cranked dynamo. I would expect it would be pretty trivial to re-wire it to use a standard barrel connector from another power source. Although the choice of HDMI for output means they have go get a HDMI monitor, which aren't cheap especially for people who have no spare money. This post has been edited by Jeruselem: May 9 2011, 10:09 AM -------------------- Resident KatyCat
May 9 2011, 10:28 AM
Post
#14
Atomican Guru |
Why Braben is making this and not the next elite/x3 killer, I'll never know. David Braben... *eyes gloss over for a minute of nostalgia* TBH, as much as I want Elite 4, I can understand why he'd concentrate elsewhere. Ya gotta make a living, and anything Elite-like would be in direct competition with EvE. A tough call, IMHO. Having said that, I reckon an updated and made-pretty version of Frontier would run beautifully on modern mobile handsets and tablets... -------------------- "Be Excellent to each other." - Bill and Ted
Got my PS3 - now I need a 360 for teh gaems. |
May 9 2011, 10:35 AM
Post
#15
Atomican Primarch |
Well, there should be a new X3 game out by the end of the year to keep us going in the meantime.
May 9 2011, 11:41 AM
Post
#16
Lancer: Odds are, they could couple this with the One Laptop tech, and have a portable hand-cranked dynamo. I would expect it would be pretty trivial to re-wire it to use a standard barrel connector from another power source. Although the choice of HDMI for output means they have go get a HDMI monitor, which aren't cheap especially for people who have no spare money. Odds are that was so they could output audio on the one plug. True, HDMI isn't cheap. But then again, it's becoming more ubiquitous, and odds are they could simply set it up with a different connector. This is effectively the prototype. -------------------- Romans 10:3
May 9 2011, 12:23 PM
Post
#17
Atomican Charge |
Perhaps if they had an adapter that ran composite, 3.5mm audio and barrel power connector off the HDMI socket they could get it to work that way. Solves a lot of problems neatly.
May 9 2011, 08:05 PM
Post
#18
Super Hero Titan ![]() |
This might make a nice emulation platform.
-------------------- | QUOTE (Adrian Edmunson) <-
| The only failsafe solution to slugs is to dig raised beds and put a little moat around them. It's hard work, but your cabbages will thrive. |
May 9 2011, 08:26 PM
Post
#19
Whats the point of something that can fit into your pocket if it needs to be out of your pocket to plug in? :P What's a flash drive? All I could think of :) -------------------- "If the forums were just Opy talking about World of Tanks, I'd... okay, maybe not." - hawkeye
May 10 2011, 04:30 PM
Post
#20
Atomican Primarch |
I dunnO what the fuss is, I have a computer that fits in my pocket. I make calls with it, too.
| Lo-Fi Version | Time is now: 19th May 2013 - 05:52 AM |
