Where are all the Z68 Mobo's? |
Jun 20 2011, 03:52 PM
Post
#1
Lurker Serf |
Well where the heck are they all and their reviews?
Been waiting to upgrade and tired of waiting for tons of mobo's to choose from. |
Jun 20 2011, 04:12 PM
Post
#2
Super Hero Guru ![]() |
there is a fair few about now
asus has 3 asrock has a few gigabyte has a heap and there is a few good reviews out there http://www.hardwarecanucks.com/forum/hardw...rm-expands.html http://www.xbitlabs.com/articles/mainboard...p8z68v-pro.html http://www.anandtech.com/show/4329/intel-z...-caching-review edit this is the one i meant to link http://www.anandtech.com/show/4337/z68-ssd...sandforce-ssd/5 This post has been edited by Dasa: Jun 20 2011, 04:38 PM -------------------- 2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Storm G5 - MCW60 - EK-VGA HF - MCP355 XSPC Restop - PA120.4 - Scythe GT 4x120 1440/1850rpm http://i3.photobucket.com/albums/y83/dasa09/z77rog.jpg |
Jun 20 2011, 05:01 PM
Post
#3
Atomican Primarch ![]() |
^^ agree on the Anandtech review. I think SSD caching has kinda snuck underneath most enthusiast's radars . Largely Intel's fault for not promoting it, but it's a big benefit nonetheless.
This post has been edited by philo-sofa: Jun 20 2011, 05:02 PM -------------------- i5 3570K | ASRock Z77-E ITX | 8 GB G.Skill DDR3 @ 2200 CL11 | EVGA GTX 670 @ 1.06 GHz (Base) / 1.27 GHz (Max Boost) / 7.0 GHz (Mem) | 500GB Seagate 7200.11 | 5TB Media Storage | Seasonic G-550 | BitFenix Prodigy 'Yang' | BenQ 2750 | Logitech G19 | Logitech G500
Jun 20 2011, 06:20 PM
Post
#4
Lurker Serf |
there is a fair few about now asus has 3 asrock has a few gigabyte has a heap and there is a few good reviews out there http://www.hardwarecanucks.com/forum/hardw...rm-expands.html http://www.xbitlabs.com/articles/mainboard...p8z68v-pro.html http://www.anandtech.com/show/4329/intel-z...-caching-review edit this is the one i meant to link http://www.anandtech.com/show/4337/z68-ssd...sandforce-ssd/5 You're quite correct and I have seen and read them all but was hoping for a few more mobo's from ASUS and as for Gigabyte what the... not including onboard video on the boards that are mid range and have all the features I want. This post has been edited by stone2: Jun 20 2011, 06:51 PM |
Jun 20 2011, 06:37 PM
Post
#5
there should be a z68 itx mb from zotac next month hopefully more will follow
Jun 20 2011, 07:15 PM
Post
#6
Atomican Guru |
The thing is most motherboard manufacturers are probably waiting till their stocks of H67 and possibly P67 to run out before they start pumping out the Z68. MSI at work hasn't had a lot of motherboards shipped to us (one m-ATX and as well as one normal business board) so far so I'm guessing the above.
-------------------- Main Rig: AMD FX-8320@ 4.4GHz/Asus Sabertooth 990FX/8GB G-Skill Ripjaws DDR3-1600@1766/Sapphire HD 7870@1050/5000/OCZ Vertex 2 120GB/Bitfenix Shinobi/Noctua NH-D14/Corsair HX-750
Camera rig: Sony Alpha a77/Sony DT 16-50mm f2.8 SSM/Sony DT 16-105mm f3.5-5.6/Tammy 70-200mm f2.8/Sony DT 50mm f1.8/Sony HVL F42AM Flash |
Jul 17 2011, 06:51 PM
Post
#7
Quark Learner |
^^ agree on the Anandtech review. I think SSD caching has kinda snuck underneath most enthusiast's radars . Largely Intel's fault for not promoting it, but it's a big benefit nonetheless. As SSD drives become larger and more eccomomical the SSD caching will become obsolete, the only long term benifit of the Z68 boards is the fact that if you need to opperate your PC without a dedicated graphics card you may, but that would only be a solution if you are having your GPU repaired. SSD caching is a gymic and most people have realised that its not worth the upgrade for that reason alone when they can simply just upgrade to a larger and faster SSD anf have their system run off that. -------------------- [b]"Behold the thread killer has arrived"[/b] with each post i make a thread is stopped in its track with none daring to post again.
Jul 17 2011, 09:59 PM
Post
#8
^^ agree on the Anandtech review. I think SSD caching has kinda snuck underneath most enthusiast's radars . Largely Intel's fault for not promoting it, but it's a big benefit nonetheless. As SSD drives become larger and more eccomomical the SSD caching will become obsolete, the only long term benifit of the Z68 boards is the fact that if you need to opperate your PC without a dedicated graphics card you may, but that would only be a solution if you are having your GPU repaired. SSD caching is a gymic and most people have realised that its not worth the upgrade for that reason alone when they can simply just upgrade to a larger and faster SSD anf have their system run off that. i need at least a 500g ssd to fit my currently played games\os on and i dont want to pay over $350 for it so for me z68 caching is a very real option since i could get a 3tb install at near ssd speeds on repeat data use as a 60g sata3 ssd is only $135 vs ~1k for 480g it seems like good value and it will take a few years yet for ssd to reach aceptable size\price -------------------- 2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Jul 20 2011, 12:16 AM
Post
#9
Atomican Charge |
Anandtech's review is fair enough. Well, now I think I'll be upgrading my machine...
Dec 20 2011, 02:31 PM
Post
#10
Atomican Charge |
I recently bought an Asus P8Z68-V le but really wanted an asrock extreme 4 gen 3. I was looking at MSY and IJK (coz they have branches in canberra), but they were out of most z68 boards. luckily MSY had a few Asus P8Z68-V le which was my 2nd choice
Dec 21 2011, 03:22 PM
Post
#11
Atomican Overlord ![]() |
That quite a bump there ameel .... ;-)
-------------------- http://www.youtube.com/watch?v=znodcpMzcnA&feature=player_embedded |
Feb 29 2012, 12:15 AM
Post
#12
Quark Learner |
Theres plenty of reviews around especially on youtube,just do a search on the board your looking for on youtube with review after the name of the board.
-------------------- CoolerMaster CM Storm Trooper with Window,Corsair AX1200 Gold,ASUS Rampage IV Extreme,Intel Core i7 3930K C2 @ 4.6ghz,ASUS GeForce GTX 680 2GB,Mushkin 993997 32GB 2133MHZ PC3-17000 Ridgeback Redline,OCZ Vertex 3 240GB SSD Max IOPS,Crucial RealSSD C300 SATA 6Gbps 256GB SSD,Corsair Hydro H100,Logitech G700,Logitech K800
Mar 20 2012, 05:25 PM
Post
#13
Quark Learner |
Your right the Z68 seem to be obsolete before they took off. I got the last MSI Z68A GD65 (G3) from PC CaseGear. They indicated they would not be getting any more in. Unless a new chipset will be coming out for Ivy Bridge support, socket 1155 looks a little stale now.
Regards MarkL |
Mar 20 2012, 07:13 PM
Post
#14
Atomican Journeyman |
I just bought a Gigabyte GA-Z68X-UD3H-B3. Seems to be no shortage on these boards (I wonder if these is a reason for this.....lol)
Seriously though. Now that the Z77 chipset has been released I think you will find the current stocks of Z68 boards to dwindle. |
| Lo-Fi Version | Time is now: 21st May 2013 - 08:05 AM |
