Nh-D14 fir in my case?, Fit in my Coolermaster Ammo 533 box case? |
Oct 8 2011, 11:12 AM
Post
#1
Atomican Journeyman |
I want to know if a Noctua NH-D14 will fit in my Coolermaster Ammo 533 Box case. It is the one with the handle on top.
I've pulled out the tape measure and it looks like a close call. I estimate I'll have less than 5mm clearance, it's hard to tell. Anyone know either way? -------------------- i5 2500k, Antec Kuhler H2O 620, Gigabyte Z68, G.Skill 8gb Ripjaws, Gigabyte GTX 570 OC, Coolermaster Ammo 533 Case, OCZ ModXtreme 650 watt, WD HDs, LG Bluray/DVD combo, Steel Series Cans, MS Ergo KB, Witcher2 laser mouse I won from PC PowerPlay :)
Oct 8 2011, 01:54 PM
Post
#2
Atomican Overlord ![]() |
I thought you only had $500 to spend? ;)
http://forums.atomicmpc.com.au/index.php?showtopic=45509 Seems like it'd be very close though. |
Oct 8 2011, 05:49 PM
Post
#3
Atomican Master |
I want to know if a Noctua NH-D14 will fit in my Coolermaster Ammo 533 Box case. It is the one with the handle on top. I've pulled out the tape measure and it looks like a close call. I estimate I'll have less than 5mm clearance, it's hard to tell. Anyone know either way? Best info I could find was "The Noctua NH-D14 should fit in all cases with a minimum width of 20 to 21 cm" http://www.youtube.com/watch?v=Djki8c31Dqs It seems the dimensions for the 533 are either 210 or 215mm so should be OK. -------------------- 2600k | GTX580 | GA-Z68XP-UD4 | 4x4GB 1866Mhz | 120GB Corsair Force 3 | 2x1TB Barracuda RAID0 | Corsair HX-850 | NH-D14 | Define XL
Oct 8 2011, 06:57 PM
Post
#4
Hi guys/girls,
I made my purchases today, spent $539. Was set for NH-D14 but most people in Brisbane no stock and MSY were shut when I arrived at 13:55! Therefore I got the Antec Kuhler H2O 620. Assembly in an hour or so when my twins are sleeping. -------------------- i5 2500k, Antec Kuhler H2O 620, Gigabyte Z68, G.Skill 8gb Ripjaws, Gigabyte GTX 570 OC, Coolermaster Ammo 533 Case, OCZ ModXtreme 650 watt, WD HDs, LG Bluray/DVD combo, Steel Series Cans, MS Ergo KB, Witcher2 laser mouse I won from PC PowerPlay :)
Oct 8 2011, 07:47 PM
Post
#5
Atomican Master |
Hi guys/girls, I made my purchases today, spent $539. Was set for NH-D14 but most people in Brisbane no stock and MSY were shut when I arrived at 13:55! Therefore I got the Antec Kuhler H2O 620. Assembly in an hour or so when my twins are sleeping. Looking forward to hearing how you go with it. -------------------- 2600k | GTX580 | GA-Z68XP-UD4 | 4x4GB 1866Mhz | 120GB Corsair Force 3 | 2x1TB Barracuda RAID0 | Corsair HX-850 | NH-D14 | Define XL
| Lo-Fi Version | Time is now: 24th May 2013 - 06:56 AM |
