Dock Auto Hide Issue |
Feb 12 2012, 03:12 PM
Post
#1
Atomican Overlord |
So recently when I have been turning on my Mac:Mini, it has been defaulting to "Automatically hide the Dock". Now I have to go into the settings and change this almost every time I turn it on (it is random). Does anyone know what would be causing this to default back to auto hide the dock when I am not, and also not aware of anything that would be changing this setting.
-------------------- Intel i7 3770k
Corsair 32GB Kit DDR3 Vengeance C9 1600MHz Samsung 250gb SSD WD Caviar Green 3tb WD Caviar Green 2tb x2 AFOX GeForce GTX660 TI ASRock Z77 Fatal1ty Professional LGA1155 ATX Thermaltake Chaser A31 USB3.0 Black Mid Tower SAMSUNG 21.5" HD LED x 2 Corsair AX860 860W 80PLUS |
Apr 12 2012, 06:40 AM
Post
#2
Lurker Serf |
You can try trashing the dock pref by going to terminal and typing ~/library this will open user library. Scroll down until you find the "Prefrences" folder.
Put the view to list view if it's not set that way already because it will make navigation easier. Next look for the pref file named "com.apple.dock.plist" & "com.apple.dock.plist.lockfile". Once you have found these files highlight them then drag them to the trash. Or Ctrl+Click and move to trash. Finally restart your machine, this will make OS X return the dock plist file to default by crating a new one automattically. Hopefully that fixes it. Cheers. NOTE: Changes you have made to dock i.e. the application shortcuts you had on the dock will need to re added, and ones you removed will need to be removed again, few minutes extra work :P |
| Lo-Fi Version | Time is now: 26th May 2013 - 05:20 AM |
