USB 3 headers on motherboard, strange problem
tristan-117
post Mar 21 2012, 08:13 PM
Post #1
Quark
Learner
So I am thinking of upgrading by Antec Dark Fleet DF-30 case to a Bitfenix Shinobi XL which has four USB 3 ports on the front panel. My current motherboard, a GA-P67A-UD3R has one 9 pin USB 3 internal connecter but no 19 pin USB 3 connector. It does however, appear to have a spot for it – labeled F_USB30 F_PANEL – but its just an empty spot with 19 gold dots on the board (see attached picture). So how do I use this spot? Do I buy some bracket/header or rip one off someone else’s board? Or is it time for a motherboard upgrade?
Attachment didn't work so here:
Also, what is the difference between a 9 pin and 19 pin USB 3 header?
Many thanks
This post has been edited by tristan-117: Mar 21 2012, 08:16 PM
Go to the top of the page
+Quote Post
fajw
post Mar 22 2012, 10:20 AM
Post #2
Atomican
Don't know about the difference between a 9 pin and a 19 pin header. Pretty sure you can't use the 19 gold dots and they are there because that spot is used for a header on another motherboard yours is closely related to. Maybe you could buy a PCIe USB 3.0 card .
+Quote Post
A Hitman
post Mar 22 2012, 11:26 AM
Post #3
Atomican
You can't use that spot as there wont be a USB3.0 controller connected to it.
You will have to get a new motherboard or get a PCI-E USB 3.0 card that has a 19pin header on it.
Or if you don't actually use USB 3 devices atm you could just use an adaptor and plug the 19pin cable into a USB 2.0 header.
not working is hard work
+Quote Post
tristan-117
post Mar 22 2012, 01:40 PM
Post #4
Quark
Learner
Thankfully the shinobi xl has 2 usb 3 cables but both also use the 9 pin header.
If I use a usb 3.0 9 pin cable and connect it to a usb 2.0 9pin header will it still work?
+Quote Post
fajw
post Mar 22 2012, 02:24 PM
Post #5
Atomican
I'm pretty sure it will work.
+Quote Post
cohmoddersolo
post Mar 22 2012, 05:47 PM
Post #6
Atomican
QUOTE (fajw @ Mar 22 2012, 02:24 PM) *
but not with USB3.0 speeds.
+Quote Post
fajw
post Mar 23 2012, 11:01 AM
Post #7
Atomican
Yeah.
+Quote Post
0 Members:
Lo-Fi Version Time is now: 19th June 2013 - 07:44 AM
