OCZ Synapse vs Intel SRT |
Apr 17 2012, 06:05 PM
Post
#1
Atomican Primarch |
How do these compare?
Apr 17 2012, 06:20 PM
Post
#2
Super Hero Guru ![]() |
there is a few others out now using the dataplex software like ocz
Corsair 30GB Accelerator $85 Corsair 60GB Accelerator $119 Crucial 50GB Adrenaline Solid State Cache $129 http://www.storagereview.com/crucial_adren...hing_ssd_review im afraid there isnt much info in comparison to srt but if you have a compatible mb you can try both and decide for yourself srt is limited to hdd speed for writes unless you enable a high speed option but if something goes wrong you can lose data synapse writes to the ssd by default so its fast and it has data recovery built into the software to minimise the risk of data loss and it seems to be working fairly well now This post has been edited by Dasa: Apr 17 2012, 06:22 PM -------------------- 2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Storm G5 - MCW60 - EK-VGA HF - MCP355 XSPC Restop - PA120.4 - Scythe GT 4x120 1440/1850rpm http://i3.photobucket.com/albums/y83/dasa09/z77rog.jpg |
Apr 17 2012, 07:47 PM
Post
#3
Atomican Primarch |
I read SRT doesn't do TRIM and OCZ Synapse does.
Apr 17 2012, 07:57 PM
Post
#4
i think srt needs raid enabled which used to mean no trim but intel has added raid trim support to new controller raid drivers so it should work i would think but i am unable to find anything that confirms it is now working
so one of the drives that comes with the dataplex software is probably the safest bet -------------------- 2600k@4.8GHz 1.38v - Z77-GENE - 2x4g 1600 8-9-8 - 7970 1150\7000MHz 1.15v - OCZ Synapse 120g Seagate 2tb - Seasonic XP1000 - Dell U2711 - Pioneer Todoroki 5.1
Apr 18 2012, 09:25 AM
Post
#5
Super Hero Titan ![]() |
i think srt needs raid enabled Yes it does and SRT only works on Z68 mobos as that seems to be the only one that Intel have included the SRT stuff. Whereas the OCZ Synapse and Corsair Accelerator solutions work on any PC running Windows 7. -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
Apr 18 2012, 06:22 PM
Post
#6
Atomican Primarch |
i think srt needs raid enabled Yes it does and SRT only works on Z68 mobos as that seems to be the only one that Intel have included the SRT stuff. Whereas the OCZ Synapse and Corsair Accelerator solutions work on any PC running Windows 7. Z77 doesn't support SRT? |
Apr 18 2012, 08:33 PM
Post
#7
i think srt needs raid enabled Yes it does and SRT only works on Z68 mobos as that seems to be the only one that Intel have included the SRT stuff. Whereas the OCZ Synapse and Corsair Accelerator solutions work on any PC running Windows 7. Z77 doesn't support SRT? Don't think so. http://www.intel.com/support/chipsets/sb/C...=smart+response Date Created: 29-Sep-2011 Last Modified: 10-Apr-2012 So assume it is current. -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
Apr 20 2012, 06:16 PM
Post
#8
Atomican Overlord |
http://www.anandtech.com/show/5728/intel-z...ecs-and-biostar
The table states that Z77, H77 and Z68 support SRT. -------------------- This post brought to you by, me not playing Portal 2 for a few minutes.
Apr 20 2012, 07:45 PM
Post
#9
http://www.anandtech.com/show/5728/intel-z...ecs-and-biostar The table states that Z77, H77 and Z68 support SRT. MM I would tend to believe Intel more as it is their chipset, especially as the article I linked to was updated on 10-Apr-2012. So who to believe? -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
Apr 21 2012, 05:57 PM
Post
#10
Atomican Overlord |
http://www.intel.com/content/www/us/en/chi...ss-chipset.html
Listed in the diagram as a feature http://www.intel.com/content/dam/www/publi...h-datasheet.pdf Page 53 of the PDF shows SRT as being a feature of z77 http://www.pcstats.com/articleview.cfm?articleID=2653 Bottom of first page. A review showing a mSata port on the board designed for SRT. I thik its just an oversight on the page you were viewing, since it never explicitly stated that z77 does not do SRT and Z68 was at one time the only chipset that could do SRT so it reads perfectly fine before the 7 series chipsets arrival. -------------------- This post brought to you by, me not playing Portal 2 for a few minutes.
Apr 22 2012, 09:21 AM
Post
#11
http://www.intel.com/content/www/us/en/chi...ss-chipset.html Listed in the diagram as a feature http://www.intel.com/content/dam/www/publi...h-datasheet.pdf Page 53 of the PDF shows SRT as being a feature of z77 http://www.pcstats.com/articleview.cfm?articleID=2653 Bottom of first page. A review showing a mSata port on the board designed for SRT. I thik its just an oversight on the page you were viewing, since it never explicitly stated that z77 does not do SRT and Z68 was at one time the only chipset that could do SRT so it reads perfectly fine before the 7 series chipsets arrival. Good stuff Sparky, got better search skillzzs than me. :P Just odd the page I found has not been updated with more more info given it's edit date. You would think they would insert an update about SRT enabled models. But yes I was a bit confused as to why they would introduce a good feature to a mobo only to remove it on the next model. -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
| Lo-Fi Version | Time is now: 24th May 2013 - 09:29 PM |
