2 Pages V   1 2 >
To H2O or just O2, Cool all the things!
ReapermanRS
post Apr 29 2012, 12:30 PM
Post #1
Atomican
I've pretty much got my new build planned out but now I am wondering how to cool it. I've pretty much got my heart set on a 3570K with an ASRock Extreme4 (or a Sabertooth maybe) to go in my current case a Raven RV 01.
My options are basically this.
Get some 1155 brackets for my current CoolerMaster V8 CPU Cooler
Buying a H100 or a 920
or something like this EK-KIT H3O 360 HFX Cooling Kit
I know that by far the cheapest and easiest way is just to source some brackets for the V8 but im not sure what sort of temps and headroom it will give me it runs bloody cold (like never higher than 45 degrees) on an e8400 @ 4g but I have no idea how that would stack up thermally vs a 3570K
Next easiest is an all in one system but I suppose if I do that Im halfway to decent watercooling anyway money wise.
I've never drowned a system before and I wouldn't mind a little bit of advice. If I do drown it then eventually I'm going to want to drown the Video card as well which will probably be a 7950 or 7970 or the closest NVIDIA equivalent depending on how I feel at the time.
08/11/2012 the day the music died.
Go to the top of the page
+Quote Post
twents
post Apr 29 2012, 02:00 PM
Post #2
Atomican
depends how far you want to overclock, i really dont see the point in buying all this expensive WC gear just to run a mild overclock.
my 2500k is at 4.6ghz and running around 65degrees with the $39 hyper 212
If you were going to run 5ghz+ 24/7 then i would get a WC setup, depending on how the ivy's OC.
BF3 name: FREEZINBONES
Battletag (WoW D3): FREEZIN#1668
Steam: FREEZINBONES
2500k @ 4.6, 7970 @ 1150/1650, HX750, P8p67 pro, Sandisk/Patriot SSD/Ram, Xonar DG
N40L, z2300's, desklamp, mousepad, old shit desk.
+Quote Post
123abc
post May 4 2012, 09:32 PM
Post #3
Quark
Learner
I was planning on grabbing a loop as well, however so far ive read ivy bridge seems to hit a wall temp wise at 4.8 - 5.2 (depending on chip) that air or water can't overcome. Water would give better average temps but your max oc would be about the same on air, it depends on if you want to spend the extra money for the gain. Water becomes more appealing if you want silence as well as the performance and the satisfaction of your own loop.
I know I've decided to skip wc for this year, as its not really needed for ivy bridge or the 6xx series gpus and dasa showed that water didn't affect his 7970 clock all.
+Quote Post
osama_bin_athlon
post May 5 2012, 10:43 AM
Post #4
Hero
I never really liked the CM V8 cooler....the TRUE, and Megahalems were heaps better
I just went the easy way, got an H100
I'm very happy with it.
Quote by lunchbox1988
No, but the way he eases me onto his chimp-meat, makes me think he is prince charming.
i7 2600K @ 4.4G/Corsair H100/Asrock Z68 Ext4 Gen3/16G 2133Mhz RipjawsX/2x GTX560 Direct CU SLI/2x Corsair 120G Force3 (RAID_0)/8TB Storage (2x RAID_0 arrays)/1x 320G WD Black - Backup/SB Recon3D Fatal1ty Pro/Corsair HX1000/LiteOn BD-RW/CM HAF 932 Adv/Win7 Ult. x64/27" AOC e2795Vh
+Quote Post
NukeJockey
post May 5 2012, 11:43 AM
Post #5
Hero
QUOTE (ReapermanRS @ Apr 29 2012, 12:30 PM) *
The only really viable radiator mounting spot in a Raven RV01 is on the rear and it can be a real pain. From memory you have 1 120mm exhaust at the top of the case, so one of the single 120mm rad all in ones (not the H100) should probably mount in there okay, but if you go for a proper solution with a 2x120mm radiator, it requires that you mount it to the back of the case, the issue there, is that it really only supports 3x120 so the H100 still wouldn't be viable, however the EK solution you linked would be okay.
My Rig: ASUS P67 Sabretooth | i5 2500k @ 4.6ghz w/ Corsair H80 | 8gb G.Skill Ripjaw-X 1866mhz | 2x7950 @ 1000mhz CrossfireX| NZXT Phantom | Corsair HX850
+Quote Post
ReapermanRS
post May 5 2012, 06:42 PM
Post #6
Atomican
Yeah I figured it would have to be on the back. I suppose that rules the H100 out completely though. I reckon I'll just go air to start with and sort out a decent loop later on.
+Quote Post
AMD AKIMBO
post May 6 2012, 08:41 AM
Post #7
Atomican
one question that is always overlooked, where do you live ? lower ambiants ?
my rig in sig runs @ around 50 under full load atm summer may be a lil different but we use aircon if its hot.
love the mobo all my rigs run asrock boards now.
2600k @4.5, 2x120gb agility3's, 1.5tb seagate, 8 seagate 2tb lp's on perc6i raid6, hx 650 psu,inno gtx 580,16 gig g-skill sniper 1600,asrockxtreme4gen3 hr02 macho, acer b273h, x-fi titanium,
fractal xl, samsung bluray.
+Quote Post
ReapermanRS
post May 6 2012, 08:16 PM
Post #8
Atomican
Tasmania, ambients ranging from -10 to +32 but mostly about 17.
Although I am considering a move out West.
+Quote Post
fredzfrog
post May 9 2012, 12:01 PM
Post #9
Hero
is it just me, or is the thread title wrong? Should be "O2" at the end...
or "78.1% N2 , 20.9% O2, 1% other mixed gases"
Increases your chance
of love by 75.3%
+Quote Post
Xen
post May 9 2012, 12:04 PM
Post #10
Atomican
QUOTE (fredzfrog @ May 9 2012, 12:01 PM) *
Yeah i thought someone was going to try cooling with liquid O2,
I was going to get me some popcorn and watch the drama unfold.
如诸佛尽寿不杀生, 我亦尽寿不杀生
如诸佛尽寿不偷盗, 我亦尽寿不偷盗
如诸佛尽寿不妄语, 我某甲亦尽寿不妄语
+Quote Post
ReapermanRS
post May 9 2012, 12:13 PM
Post #11
Atomican
QUOTE (Xen @ May 9 2012, 12:04 PM) *
Pedants :p
Also give argon some credit, it's nearly a whole percent on its own.
+Quote Post
Xen
post May 9 2012, 12:22 PM
Post #12
Atomican
QUOTE (ReapermanRS @ May 9 2012, 12:13 PM) *
Pedants :p
A noble gas walks into a bar, the bartender says "we don't serve noble gases in this bar."
The noble gas ignored him.
The bartender yelled: "Hey YOU! We don't serve noble gases in this bar!"
The noble gas did not react.
如诸佛尽寿不杀生, 我亦尽寿不杀生
如诸佛尽寿不偷盗, 我亦尽寿不偷盗
如诸佛尽寿不妄语, 我某甲亦尽寿不妄语
+Quote Post
TinBane
post May 10 2012, 03:02 PM
Post #13
Mod
Super Hero
Fixed :)
I guess it saves on ambiguity. If you put N2 then people might think you meant liquid nitrogen.
Romans 10:3
absit iniuria verbis
+Quote Post
fredzfrog
post May 10 2012, 03:17 PM
Post #14
Hero
Good point :P
Xen, nice joke, got any others?
of love by 75.3%
+Quote Post
Xen
post May 10 2012, 03:20 PM
Post #15
Atomican
QUOTE (fredzfrog @ May 10 2012, 04:17 PM) *
Good point :P
I think a physics joke thread went sailing by this morning... i popped two in there...
如诸佛尽寿不杀生, 我亦尽寿不杀生
如诸佛尽寿不偷盗, 我亦尽寿不偷盗
如诸佛尽寿不妄语, 我某甲亦尽寿不妄语
+Quote Post
iamthemaxx
post May 10 2012, 04:25 PM
Post #16
Atomican
Super Hero
I can't believe you all missed the H20, not H2O!
+Quote Post
Xen
post May 10 2012, 04:33 PM
Post #17
Atomican
QUOTE (iamthemaxx @ May 10 2012, 04:25 PM) *
0000hhh... N00000 :)
如诸佛尽寿不杀生, 我亦尽寿不杀生
如诸佛尽寿不偷盗, 我亦尽寿不偷盗
如诸佛尽寿不妄语, 我某甲亦尽寿不妄语
+Quote Post
fredzfrog
post May 10 2012, 05:16 PM
Post #18
Hero
I thought it looked wonky...
of love by 75.3%
+Quote Post
ReapermanRS
post May 10 2012, 05:55 PM
Post #19
Atomican
All of you, get out of my thread.
:p
+Quote Post
insertfunnyname
post May 10 2012, 06:26 PM
Post #20
Quark
Apprentice
Antec 920 is apparently a great cooler a friend of mine owns one and he is really pleased with it. I would go for the 920 over the H80 because the Antec one has better software.
Noctua make friggin beast air coolers so check them out also.
My baby: i5 2500K, ASUS P8Z68-V Pro Gen3, ASUS GTX 560 with 120MHz coreclock overclock, 8GB DDR3 G.Skill Ripjaws X 1600MHz 9-9-9-24 RAM, Corsair AX650, Corsair H60 and Antec P280.
+Quote Post
2 Pages V   1 2 >
0 Members:
Lo-Fi Version Time is now: 26th May 2013 - 07:19 AM
