Backing up 10Tb Drive, Advice and options wanted |
May 4 2012, 10:35 PM
Post
#1
Lurker Serf |
I've got a machine with a 10Tb RAID5 drive array, being used as a shared storage space for the family. As this is storing lots of family photos and videos, I was looking at creating a periodic backup of the drive, in case the worst happens and something causes the drives to fail (as unlikely as that might be). I was wondering if anyone had any suggestions as to what I can use.
Ideally, it would be a low maintenance solution (ie I don't want to be having to swap DVDs every day to continue the backup), and not too costly to impliment. Any ideas? |
May 4 2012, 11:04 PM
Post
#2
Super Hero Titan ![]() |
First you need to sort through the data and see if any can be safely excluded from the backups. Stuff like file downloads that can be downloaded again.
Considering the size you are stuck with multiple external or hot swappable hard drives. That's it. -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
May 5 2012, 04:46 AM
Post
#3
Atomican Master ![]() |
Use another 10tb drive? or and online backup solution lololol
-------------------- BF3 name: FREEZINBONES
Battletag (WoW D3): FREEZIN#1668 Steam: FREEZINBONES 2500k @ 4.6, 7970 @ 1150/1650, HX750, P8p67 pro, Sandisk/Patriot SSD/Ram, Xonar DG N40L, z2300's, desklamp, mousepad, old shit desk. |
May 5 2012, 05:23 AM
Post
#4
Atomican Primarch ![]() |
I've got a machine with a 10Tb RAID5 drive array, being used as a shared storage space for the family. As this is storing lots of family photos and videos, I was looking at creating a periodic backup of the drive, in case the worst happens and something causes the drives to fail (as unlikely as that might be). I was wondering if anyone had any suggestions as to what I can use. Ideally, it would be a low maintenance solution (ie I don't want to be having to swap DVDs every day to continue the backup), and not too costly to impliment. Any ideas? Unfortunately with that size you would be looking at Buying more hard-drives and swapping them all the time, tape or DVD's. There's no real way around it. IMO clean up the drives as much as possible, if there is something rarely accessed pull it off and archive it on DVD. You mention it is 10Tb... how much is actually used? There is another method i used to use "Back in the day"... have a LAN party with your friends and forget that you shared the entire drive... You will have multiple sorted backups by the next day. -------------------- 如诸佛尽寿不杀生, 我亦尽寿不杀生
如诸佛尽寿不偷盗, 我亦尽寿不偷盗 如诸佛尽寿不妄语, 我某甲亦尽寿不妄语 |
May 5 2012, 08:35 AM
Post
#5
if there is something rarely accessed pull it off and archive it on DVD. Actually you should probably burn to multiple DVDs for redundancy, then store the disk properly with at least one stored off site. Oh and the DVDs should be verified after burn and new disks should be burnt every few years. :-) QUOTE There is another method i used to use "Back in the day"... have a LAN party with your friends and forget that you shared the entire drive... You will have multiple sorted backups by the next day. Sneaky. :-P Actually an option I forgot is online backup from companies like Carbonite http://www.carbonite.com.au/ Yes 10 Tb is going to take a long time to backup but it is doable and if you can cut down what actually needs backing up it becomes more viable. -------------------- She's going to be really smart, very savvy, haunting good looks, really good at her job. And kind of slutty.
| Lo-Fi Version | Time is now: 26th May 2013 - 01:30 PM |
