Post your mod, whether it is epic OR fail we wanna see em! |
Jul 16 2012, 11:11 AM
Post
#1
Atomican Master |
Reading Frunj's "PROJECT:RED" Post gave me a major curiosity to what people are doing with their cases/work stations, and to be honest, i wanna see all the mods you guys having been doing, and instead of googling images of them, turn it into a discussion which we may all learn a thing or two from :D (another reason to add the fails :P)
Jul 16 2012, 12:01 PM
Post
#2
Atomican Primarch ![]() |
Not really planning on doing a normal build log as this is a long project, but I'm currently doing a scratch build.
Here is the radiator setup: If you have Google SketchUp (or SightSpace on smart phone) you can view the planned build here: http://users.datarealm.com/~opy/PC/Jaffa/PCbuild03.skp The bottom section between the legs is a wooden drawer. So far I've build the frame with casters and built and installed the drawer. The top and bottom shelves are cut but not lacquered and not had mount holes drilled yet. Planning to cut up an Antec P180 case to use it's 5.25 drive bays. But need a replacement case first. Started the concept in November. It will not be finished by coming November. -------------------- Reality is just an illusion brought on by a lack of alcohol.
WoT quote: "DishD (5:45:44 PM) ur a bad man Opy, funny as fuk but very Bad!" Opy |
Jul 16 2012, 12:41 PM
Post
#3
Atomican Master |
Nice, would like to see it when it's finished, pics when it is?
Edit: No matter how far away it is :P This post has been edited by ilyria109: Jul 16 2012, 12:42 PM |
| Lo-Fi Version | Time is now: 24th May 2013 - 05:54 AM |
