phatbeat
Xbox 360 Network problems
Hi Guys,
I've just set up my 360 in a different room of my house, and I can't get xbox live to work. It is plugged into a standard ethernet hub that is powered. I do all the tests and everything comes up fine until it gets to the xbox live connection - fail. All the network settings are unchanged, my dmz is set up and the nat is open. It comes up with the status codes of:
w 0000 - 000B
x 0000 - F001
y 30A8 - 4840
z 0000 - 0000
I have just recently added two more things to my network, a TIVO box and a PS3, but I checked the IP address's on both and they are not clashing with the Xbox. Could it be the hub???
I have a feeling I will have to move the xbox back to the other room and do a direct feed to the modem.
Any help would be hot, I need to play COD4 this weekend, or I'll scream!!!!! (just slightly addicted)
Yeah, as stated, if its a Hub I would be wary.
Check the IP of the xbox and make sure it's on the right subnet and it complies to your nat & dmz rules.
Yeah it's just an old hub I used to take to LAN's. Not a router at all. All the IP's, dmz settings etc are ok.
There are no uplink ports. I will bring a proper switch home from work and give that a try. Should I plug the modem into the uplink port on the switch,or the 360?
All good, looks like the switch has done the job, thanks for everyone's help!!
