Parts Guide (2019 update)
9 hours ago, foolz said:
Well, against everyone's best judgement (including my own) i ended up getting the Gaming Trio X. 😛
Hey you wanted the quietest option and were willing to pay for it nice choice.
The case you chose is a good value blend of low noise and airflow but there is quieter options.
With the HDD make sure it is 5400RPM even then it will be the loudest thing in your PC at low loads unless it is asleep.
Updated the builds and deleted a few unnecessary builds
AM4 MOTHERBOARDS COMPARISON TABLE
Cheapest Gaming PC Updated 22/09/2019
  • CPU AMD Ryzen 3 3200G 4 Core with Vega 8 Graphics $139 (Or 3400G $229 if you can justify it)
  • MB 320M $75 (Make sure the BIOS has been updated to support The CPU) -OR- B450M $99+ (B450 If you wish to OC, also needs BIOS updated using old CPU)
  • RAM 8G (2x8) 3200 c16 $130
  • HDD 240GB $43 -OR- 480GB $75
  • CASE\PSU Antec VSK4-500 w/ 500W PSU $91
    TOTAL $478-534
Intel Low Budget Gamer I3 9100 Review | (not overclockable) Updated 22/09/2019
  • CPU Intel Core i3 9100F 3.6GHz 4 Core $125
  • MB B365M $105
  • RAM 8G (2x8G) 2666 Kingston HyperX FURY HX426C15FBK2/16 $119
  • GPU RX 570 4\8GB $209\239
  • SSD 480GB $75
  • PSU Cooler Master MWE Bronze 450W 3Y $65 -OR- Seasonic Focus 450W 7Y $99
  • CASE SilverStone Precision PS16 $49
    TOTAL  $747-811
AMD Low Budget Gamer 2600 Review Updated 22/09/2019
  • CPU AMD Ryzen 2600 6C\12T $199
  • MB ASRock B450M Pro4-F $115
  • SSD 480GB $75
  • PSU Cooler Master MWE Bronze 450W 3Y $65 -OR- Phanteks PH-P550GF Gold 550W 5Y $99
    TOTAL $842-906
AMD Gamer 3600 Review Updated 22/09/2019
  • CPU Ryzen 5 3600 6C\12T $315 -OR- Ryzen 7 3700X 8C\16T $519 (Budget priority should go to GPU for current games)
  • MB MSI B450M MORTAR MAX $149
  • RAM 16G (2x8) 3000c15 Crucial Ballistix Sport LT $119 OC to ~3600
  • GPU RX 5700 8GB OC $599 -OR- RX 5700 XT 8GB OC $699 (2070 Super is decent value at $750 with ebay sales)
  • SSD Kingston A2000 M.2 NVMe $159
  • PSU Super Flower Leadex III 650W Gold 7Y $129
  • CASE SilverStone Precision PS15 RGB $69 (Non RGB lacks fans)
    TOTAL $1539-1843
Intel Gamer Updated 22/09/2019
  • CPU 9700k 8C $550 -OR- 9900K 8C\16 $899Gamers Nexus 9700k Review
  • MB ASRock Z390 PHANTOM GAMING-ITX/AC $269 (Newegg) -OR- Asus ROG STRIX Z390-I GAMING $322
  • RAM 2x8 3200c14\3600c16 $239 OC to ~4000c17 1.4-1.5vdimm
  • GPU RX 5700 XT 8GB OC $699 -OR- RTX 2080 Super 8GB $1089 -OR- RTX 2080 Ti  $1699
  • SSD ADATA XPG 1TB SX8200 Pro M.2 NVMe $225
  • PSU Corsair SF600 Gold\Platinum 600W SFX 7Y $166\199 + SilverStone PP08 Adapter SFX to ATX $10 (SFX PSU provides extra breathing room for GPU. Have PSU inlet facing up)
  • CASE Fractal Design Define S Nano $99 (Block bottom vents to force airflow past GPU and out the back)
  • HSF Noctua NH-D15 $125 (Move fan from over RAM to the case lower front inlet)
    TOTAL $1683-igp $2382-$3468
AMD High End, Low Noise Updated 22/09/2019
  • CPU Ryzen 7 3900X 8C\16T $809 3700X & 3900X Review
  • MB ASUS Prime X570 Pro $369
  • RAM 2x16 3200 Crucial Ballistix Sport LT $269 OC to ~3600
  • GPU RX 5700 XT 8GB Red Devil $749 -OR- RTX 2080 Super 8GB Gaming X Trio $1272 -OR- RTX 2080 Ti 11GB GV-N208TAORUS-X-W-11GC $2195
  • SSD Samsung 970 EVO PLUS 1TB $303
  • PSU Super Flower Leadex Titanium 750W 5y $219
  • CASE Fractal Design Define R6 USB-C $219
  • HSF Noctua NH-U12A $159
    TOTAL $3096-4542
Re. storage, I'd probably want at least 2tb to complement the SSD.
Well, the fractal define c and be quiet! pure base 600 are still both options; I was not sure when the build began if they'd provide adequate cooling or not, but the GPU I've ended up with runs pretty cool as does the CPU. So should I consider them more seriously? Cable management seems to be easier on the fractal define c as well, and, well, I'm very bad at cable management lol. I may try overclocking the GPU at some point, but I'm open to all suggestions.
Speaking of Be Quiet!, Boris suggested on Whirpool going for the Pure Rock (I was thinking the Slim, as according to their website the standard version will impede the ram) instead of the Noctua. That should be fine if I don't overclock, right? The 3700x overclocking results seem underwhelming so far, unless I've been looking in the wrong places. He also said it might be a bit difficult to fit the SSD, GPU and sound card on the board, and suggested the MSI B450-A Pro Max as an alternative.
Edited by foolz
    TOTAL $1539-1843
    TOTAL $3096-4542
Is the Intel Gamer deliberately spec'd to make it higher end/performance than the AMD gamer?
My thought was that if you are willing to pay more for a Intel CPU for minimal improvement then you might as well do the same with the rest of the parts.
But they are also good parts that needed to be shown and people should feel free to mix and match the bits with the AMD build if they wish.
Don't know that the Fractal C is all that good for low noise as it uses fairly thin noise dampening and smaller fans from memory.
The be quiet does run a bit hotter but it is supposed to be quiet so it may be a good option.
For sure.
Although the CPU does auto OC I think and the cooler it runs the higher the clock speed and while every little bit adds up on it's own it wouldn't be enough to make a noticeable difference.
First has two M.2 ports and one gets disabled when you use the bottom port for the sound card while the second only has one M.2.
I don't see how it would make much difference ether way but you would get a little more breathing room for the GPU.
Might be changing my suggestion for the Asus X570 Pro MB as it looks to have a serous flaw that none of the previews for it picked up on.
Users are reporting high noise from the chipset fan and when I looked at this image I noticed that looks like the bare chipset die is barely making contact with the HSF and is just sitting bare under the fan.
https://www.techpowerup.com/review/asus-prime-x570-pro/images/chipset.jpg
Apparently the fan is PWM but cannot be controlled in BIOS on the current header and changing the header would not allow adjustment based on system temperature.
Edit: found some better pictures and the HSF may actually be covering the chipset so it is not all bad but apparently it is still loud at 4700RPM <50c idle
https://forum.hardwareinside.de/media/asus-rog-strix-x570-e-gaming-14-jpg.89805/
For sure.
So, if I were to go for the Be Quiet!, I should be fine without needing to add an extra fan at the front so long as I'm only overclocking the ram, not the CPU or GPU, right?
My other, and silliest, option would be to replace the fans in my Antec three hundred with high end fans, but the air flow doesn't look much better than the BQ PB 600, so it'd be a bit redundant. xD I'm also open to other suggestions, if there's anything out there better than the pb 600 in that price range, but it seems to be in the same league as the likes of the silent base which is nearly twice the price!
As an aside, what are people's thoughts on PCIE 4? I'm not interested in it for this build due to the price increase on the motherboard and the chipset fans most of the boards have, but was just curious. It doesn't seem like it'll offer a huge benefit to video cards. 😕
Edited by foolz
GPU will be the main concern for airflow as those drive bays will block there fair share in the BQ 600 and looking at the case adding extra fans may not help that much although blocking the other fan slots in the front so that air cant just go round in circles may help a bit and maybe reduce escaping noise.
PCI-E 4 ay be helpful to some games for those targeting ~240FPS
If I were to try and seal that fan slot, would I need to buy a screen mount or something to that effect, or would a carefully secured piece of cardboard be acceptable? 😉
These should be my last couple of questions, the pure rock slim should still be adequate in the pb 600 if I don't manually OC, or do I need to go back to the Noctua? While the main issue is GPU airflow, it shouldn't be too big of a deal for the gaming trio x given it runs pretty coolly, should it?
Edited by foolz
Bit of double sided tape and some cardboard should work nicely.
Pure rock slim should be fine but the bigger you go the slower you can run the fan.
The better the airflow the lower the GPU fan speed so it is a balancing act against what result sin lower noise and is it quieter at idle or load.
Well, what about the price middle ground between the Noctuas $100-$130 and the Pure Rock Slim $39 of the Shadow Rock slim for $65? That raises the fan size from 95mm to 135mm.
Yep. The only thing is, other cases end up with noise ratings higher than the card runs in cases with good airflow going by reviews, so it's probably worth the risk of having to run the fan a bit higher considering the sound deadening, I think. I assume the slightly more space between sound card, GPU and SSD shouldn't make a big difference in cooling, as I really prefer the big heatsinks of the Mortar?
Edited by foolz
Updated the title to better describe my intentions with the build
Bang 4 Buck Gamer
Also added some review links to help chose between GPU brands and updated the links up the top.
GPU RX 5700 8GB OC <Review $599 -OR- RX 5700 XT 8GB OC <Review $699 (2070 Super is decent value at $750 with ebay sales)
  • Yes Sir! Very atomic! 1
Ordered the last of the parts today (ended up going for the PB 600 and a DRP4)! Just wanted to make a post to thank you, Dasa! Your patience was much appreciated, and you were an extraordinary help! 🙂
Posted in wrong thread by accident. Sorry. Please delete.
Edited by foolz
House was robbed.... Glad you make these part list, great reference...  Sucks as I finally had everything the way I wanted, now not sure what parts I'll go with for a new build.
Oh dam.
It's kinda a bad time to go buying new high end GPU maybe just get a cheap card to screw around with and vmod or something unless there is a demanding game you really want to play in the next few months.
Maybe a middle ground like a reference RX 5700 8GB $299 Microcenter then stick it on water.
Have you thought about going big or small with the build?
