What are the advantages of the 7870 Myst Edition?
it's just an LE version AFAIK
its a cut down 7950
its clocked slower than 7870 but is faster
i listed it specifically as its much the same price as other 7870 but has a clear advantage
http://www.hardwareheaven.com/reviews/1639...conclusion.html
www.hardocp.com/article/2013/01/01/powercolor_radeon_hd_7870_myst_edition_review/1#.URy2yWfZSI4
http://www.tweaktown.com/reviews/5120/powe...view/index.html
http://www.techpowerup.com/reviews/Club_3D...ahiti_LE/1.html
edit
trimmed this build a bit
Low Budget Gamer 1 CPU Review | GPU Review
CPU/MB Option AMD quad A8-5600K UNLOCKED 3.6Ghz (3.9GHz Turbo), 4MB $111 ASRock FM2A75M-DGS $73=$184
CPU/MB Option Intel dual i3 3220 LOCKED Dual Core 3MB $116 With ASRock H71M-DGS $45=$161
CPU/MB Option Intel quad i5 3470 LOCKED (3.6GHz Turbo) Quad Core 6MB $185 With ASRock B75M $59=$244
RAM 4g 1600 $20 - OR - 2x4g $40
GPU 6670 1g $69 - OR - 7770 1g $109 - OR - GTX650Ti-GS $149 - OR - 7850 2G $179 - OR - 7870 2G Myst Edition $229
HDD 500GB 7200rpm $57
DVD sata dvd $18
PSU Corsair VS450 $49
CASE CoolerMaster Elite 334U $39
TOTAL $344-IGP (ok for a start but for gaming get a gpu quick) $413-676
added a new build
Gryphon
CPU Intel i5-4670K 3.4GHz 6MB $270 - OR - i7-4770K 3.5GHz 8MB $384
MB ASRock Z87M PRO4MB $125 - OR - ASUS Gryphon Z87 $174
RAM 2x4G 2400 $89 - OR - 2x8G $170
GPU 7950 3G $285-1GHz $308 - OR - 7970 oc 3G $389 - OR - GTX 780 3G $729
HDD/SSD 2Tb 7200RPM TOSHIBA 3Y $92 - OR - 240\256g SSD $185+
DVD DVD SATA $18
PSU Seasonic X-560 80Plus Gold 560W $139
CASE Silverstone TJ08-E $99
HSF (optional) NZXT Havik 140 $69
TOTAL $832-igp $1117-$1967
edit
high end build has been upgraded from this
High End
CPU i7-3770K 3.5GHz/8M/22nm $331 (for a gaming only rig stick with 3570k)
MB ASUS Sabertooth Z77 $245
RAM G.Skill Trident X F3-2400C10D-16GTX 16GB (2x8GB) DDR3 $145
GPU's (One or Two) 7950 3G $295 - OR - 7970 3g $388 - OR - GTX 780 3G $729 - OR - GTX TITAN 6G $1316
SSD 480Gb Sandisk Extreme SSD $369 - OR - Samsung 512GB SSD 840 Pro $529
DVD Pioneer BDR-208 15X Blu-Ray Write $90
PSU Corsair AX760 Platinum $229 - OR - Corsair AX860i Platinum $279
CASE Silverstone Fortress FT02B Black USB 3.0 $239
HSF NH-D14 $84
TOTAL $2026-4574
to this
High End
CPU Intel Core i7 4770K 3.5GHz $389 (for a gaming only rig stick with 4670k)
MB ASUS Sabertooth Z87 $319
RAM G.Skill Trident X F3-2400C10D-16GTX 16GB (2x8GB) DDR3 $174
GPU's (One or Two) 7950 3G $285 - OR - 7970 3g $375 - OR - GTX 780 3G $729 - OR - GTX TITAN 6G $1199
SSD Samsung 840 500G $388 - OR - Samsung 512GB SSD 840 Pro $499
DVD Pioneer BDR-208 15X Blu-Ray Write $89
PSU Corsair AX760 Platinum $219 - OR - Corsair AX860i Platinum $269
CASE Silverstone Fortress FT02B Black USB 3.0 $249
HSF NH-D14 $84
TOTAL $1911-igp $2196-4470
itx build should be done soon now that itx z87 mb have started to popup
and value gamer to i guess just wish mb prices would settle a little
edit reworked small pc 2
Small pc 2
CPU i5 3570K 3.4GHz/6M/22nm $225 - OR - i7-3770K 3.5GHz/8M/22nm $330
MB Gigabyte GA-Z77N-WIFI $136 - OR - ASRock Z77E-ITX $165 - OR - ASUS P8Z77-I Deluxe $229
RAM 2x4G 1600 $40 - OR - 2x8G 1600 $69 - OR - 2x8G 2400 $149
GPU Optional
SSD samsung 830 256\512G $199\399
DVD SATA dvd $16 - OR - Pioneer BDR-207DBK $109 (FT03 Requires a slot load drive which are not easy to find)
CASE\PSU Lian Li PC-Q08B $125 - Seasonic X-400 Fanless $169 - OR - Silverstone FT03B-MINI-ITX $149 - Silverstone ST45SF-G 450W SFX $115
TOTAL $910-1510
now
Small pc 2
CPU Intel i5-4670K 3.4GHz 6MB $270 - OR - i7 4770K 3.5GHz $389
MB Gigabyte GA-Z87N-WIFI $159 - OR -ASRock Z87E-ITX $189
RAM 2x4G 1600 $65 \ 1866 $75 \ 2400 $89 - OR - 2x8G $95\$140\$170
GPU Optional
SSD Samsung 250GB 840 $184 - OR - Samsung 256GB SSD 840 Pro $244 - OR - Samsung 840 500G $388 - OR - Samsung 512GB SSD 840 Pro $499
DVD SATA dvd $16 - OR - Pioneer BDR-208 15X Blu-Ray Write $89
PSU SeaSonic 350W OEM V3 Gold $69 - OR - Seasonic 400w Platinum Fanless $179
CASE\PSU Lian Li PC-Q08B $125 - - OR - Silverstone FT03B-MINI-ITX $149
TOTAL $841-1664
Hey guys, Looking at upping my graphics card count from 1 to 2.
I currently have a Gigabyte 7970 (pre GHz editions) and was going to buy an XFX 280X to Crossfire with the 7970.
I currently have an Antec 620W High Current Gamer PSU, which I think has all the appropriate cables and spots to run crossfire... but will the wattage be enough?
It all would be going into the follwoing system:
i7 920 with a Thermalright Ultra 120 cooler- Slightly OCd to 3.2Ghz - Want to get an all in one water loop to OC it further...
Gigabyte X58 UD5 M/B
4GB of DDR3 - Need to upgrade this too, was triple channel 6GB but one stick died.
Running triple 24" screens, hence why the single 7970 is only just cutting it for some games now...
Thoughts? any other options that would be better for me to pursue?
Thanks guys.
280x should crossfire well with the 7970 but for best results you want to try set them to run the same clock speed
system will probably use under 620w but your cutting it to fine you really want 750-850w
your psu only has two 6+2 pin pci-e connectors and its best not to use adapters on such high end gpu
Cool mate, thanks. If I go through with the purchase I over/under clock the cards to be the same for sure.
Would something like the Silverstone Strider 750W be a good choice? Has 2 x 8 pin and 2 x 6 pin connectors.
Much appreciated.
Green Machine (yep im bored)
Intel Core i5 4690S $259 - OR - i7 4790S $359
ASUS H97I-PLUS $129
G.Skill F3-12800CL9D-8GBSR2 1.25V $105
eVGA GTX750TI $182 (hopefully close to the nvidia reference which has much lower power use than the non reference)
SAMSUNG 850 Pro 512GB $430US
SeaSonic 400W Fanless 80Plus Platinum $189
BitFenix Prodigy Mini-ITX Case Green with Window $89 (its not a green pc without a ugly green case)
Noctua NF-A14 ULN 140mm Fan $28 0.48w (toss the stock case fans)
Silverstone Heligon HE02 Passive $85
Any chance we could add specs for a Photoshop/CAD/3D rendering build?
thats probably the high end build perhaps not overclockable though so you may want a quieter case with less airflow and you wouldnt need such a powerful gpu
or maybe small pc 2
just depends what you want from it
if the budget is big and you want to speed up render times you could go with a six core skt2011 cpu
Dasa,
Need an office build, for someone, they have small horizontal cases at the moment I think they are actually HP desktops.
Need something that will run 2 monitors 1080p, can use multiple programs at once, mostly internet, a few office programs, word.
No wifi, gigabit lan, SSD is not a must.
HDD space isn't a must, it will be connected to the server for backups.
Must run windows 7-8
WIll be running 24/7
Budget around 500-800 box only.
Cheers.
EDIT: Annnd I just saw the office build you updated last year.
Edited by twents
yep that office build is still ok other than the intel cpu have been replaced with a new revision that requires a bios update on the mb or a h97 mb
i should probably just make it a nuc like this with no moving parts
GB-BXBT-2807 $171.6
Crucial 4G 1600MHz DDR3 SODIMM 1.35V $45
Samsung 840BW EVO 120G $87
$303
but for multiple monitors you may need to step up to Intel D34010WYK NUC Barebone $335
Samsung 840 EVO mSATA $96
$476
or go your standard big pc
Celeron G1840 $48
ASRock H97M $104
4d ddr3 $43
SOHO 6613B3 Case with Seasonic 350W Gold $89
$371
Thanks Dasa
looks like I might go with the standard pc, as then you can add remove parts etc.
Would I need such an expensive Mobo considering OC will not be done?
not overclocking makes things cheaper how about you create a new build thread on the forum give us all you details with budget any existing parts that can be used what software you will be running and if you have any preference on case size\noise and the people around here can give you some advice on a build that is tailored to your needs
till then if you want to look at something to give you an idea there is some solid builds here although there is a few things i would tweak
http://whirlpool.net.au/wiki/rmp_sg_whirlp...tasking_configs
ok i have updated the builds and am having a crack at a rendering build
can you make sense of it or have i tried to cram to much into one?
if anyone knows of some more recent opencl benchmarks using real apps i would love to see them
CPU/MB Option 1 Xeon E3 1231 V3 3.4-3.8GHz (I7 With no IGP) $289 - OR - i7 4790 3.6-4.0GHz $339 & ASRock H97M-Pro4 $108
CPU/MB Option 2 i7 4790K 4.0-4.4GHz $409 & Asus Z97M-PLUS $142
CPU/MB Option 3 i7 4930K $659 & Asus P9X79-LE X79 8xDDR3 $245
RAM 2x8 16G 1600 c9 $195 - OR - 4x8 32G $390
GPU R7 250 1GB $69 - OR - R7 260X 2GB $145 - OR - R9 280 3G $259 OpenCL is the future But if your using old CUDA software look at gtx750/750ti
SSD 3y warranty Samsung 250GB\500GB\1TB EVO $165/322/$525 - OR - Samsung XP941 256/512GB M.2 $368/$675
SSD 10y warranty Samsung 850 Pro 128GB/256GB/512GB/1TB us$130/230/430/730
HDD 3y warranty Toshiba 1/2/3/4/5TB $65/94/129/192/279
HDD 5y warranty Hitachi Ultrastar 1/2/3/4/6TB $89/185/269/359/820
PSU Seasonic G Series 360W $85 - OR - Seasonic G series 550W (for 4930k & 280) $115
CASE Silverstone PS09 $45 - OR - Nanoxia Deep Silence 4 $85 - OR - Nanoxia Deep Silence 1 (atx needed for i7 4930) $119
CoolerMaster Hyper 212 EVO $34 (Optional except with 4930k)
Total $917-IGP $936-3371
found someone that tested there gtx670 4g vs 290 in adobe premier cc with cuda performance vs opencl
the difference is small but then so is the difference between gtx650 and titan with just cuda in other premier reviews
http://www.dslrfilmnoob.com/2014/04/26/ope...-rendering-test
well its missing the k but
GB-BXi7-4770R
Ultra compact PC design - 0.79L (62 x 111.4 x 114.4 mm)
GB-BXi7-4770R
haha true.
What if I already have the CPU tho and just want everything else?
well then your probably looking at something like this
M350 Universal Mini-ITX enclosure
(192 x 210 x 62mm , 2.5L)
http://www.mini-box.com.au/M350%20Universa...0enclosure.html
with a pico psu
http://www.mini-box.com.au/PICOPSU-150-XT.html#
that case may get a bit hot though since its only rated for up to 65w cpu
ok i have updated a build with some color to help break it up a bit and make it easier to read
so... how does it look?
any tips to make it better before i do more? easier to do it once and do it right
thanks
