i have been looking at a i3 build but im not sure where it fits other than as an expensive work pc or perhaps a media pc with the appropriate case and extras
Intel Core i3 530 LGA1156 2.93Ghz 4Mb 32nm 2C/4T $159 - OR - i3 540 3.06Ghz $179
Gigabyte GA-H55M-UD2H $129
2x2g ddr3 $100 - OR - G.Skill ECO 4GB (1600MHz) 7-8-7-24-2N 1.35V $179
Samsung HD502HJ F3 500Gb 16Mb $67
Pioneer DVR-218 $37
Antec NSK4480B-II $107
$599-$698
edit
bit better priced since i removed that extra 1 from the hdd :) woops
Dasa, I know this is something pointless to say, but you spelled 'does' wrong in the Insanity rig.
looks like im short a t in the next word to
Antec Two Hundred $62 Fans: rear 120 - top 140 (3 speed)
Antec Three Hundred $79 Fans: rear 120 - top 140 (3 speed)
Lian-Li DragonLord K58 $85 Fans: rear 120 1500rpm - front 140 1000rpm
Coolermaster CM690 $99 Fans: rear 120 1200rpm - front 120 1200rpm
Lian-Li DragonLord K60 $99 Fans: rear 120 1500rpm - front 140 1000rpm - top 2x 140mm 1000rpm
and that is why i dont bother mentioning the middle 3 cases any more as for value\performance the antec two hundred and the lian li k60 are in front despite the two hundred being a fugly little bastard
if people want to pay more for looks then they can and thats not something i can help with as looks come down to the user
^^ the K58 has a front 140 and a rear 120 - the version I looked at also had an additional two fans at the top - however rather depressingly it seems that isn't standard. Shame as it is still rather pretty tho...
Edited by philo-sofa
very nice :Cyb3rGlitch:. thanks for the link
getting due for fixing a few small errors like the 5850 thats listed as a 5830 and doing some updates like adding these monitors there is also some pineview mb in stock now and the j&w 785g itx mb is replacing the 780g
looks like i also have to revise the watercooling section and read a bunch of reviews on air cooling now there is some new parts there
anything i missed?
BenQ G922HDL 18.5 Widescreen LED 1366x768 $149 18w max
http://www.benq.com.au/products/LCD/?produ...=specifications
19" WS LED Benq G920WL 1440x900 $165 ~16w
Viewsonic 19" VX1932WM-LED BLACK/SILVER LCD 2ms gray-to-gray (typ) 5ms black-white-black (typ) / WXGA 1440x900 / D-SUB / DVI / SPKS / 15.5 W (typ.) / 19.5 W (max) $183.70
http://www.viewsonic.com.au/products/productspecs.php?id=412
G2222HDL BENQ 21.5" LED 1920x1080 $234.03 28w max
http://www.benq.com/products/LCD/?product=...=specifications
also dont be surprised if this doesnt happen till after i finish mass effect 2
and iv also just order a mcp355 a xfpc restop for it along with a thermochill pa120.4 rad and 4x120 50cfm gentle typhoon fans from sidewindercomputers in the us that im hopefully gona have some fun with soonish so expect some pics of that
ok i think thats everything up to date
added a i3 buid
Low Budget gamer 3
CPU i3-530 $152
MB G-B H55M S2H $110
RAM 2x2g 1600 $130 - OR - 2000 $145
GPU 5770 1GB $185
HDD samsung 500GB F3 $67
DVD Pioneer DVR-218 $37
PSU Antec Neo Eco 400C $53 - OR - Corsair VX-450 $83
CASE Gigabyte GZ-X $45
$779-824
also added this
Value kb
Logitech Retail NEWTOUCH 200 USB $13
Razer Arctosa Gaming Keyboard $45 (has flaws) http://www.ocia.net/reviews/razerarctosa/page4.shtml
Value mice
Logitech Retail MX518 $34 optical
Microsoft SideWinder X3 Mouse $35 laser
added a i3 buid
Low Budget gamer 3
CPU i3-530 $152
GPU 5770 1GB $185
$779-824
also added this
Value kb
Value mice
my i3 build is pretty much the same, it runs very well, overclocks easily and i can play mw2 on high settings smoothly
is there a too cheap intel powered version? Seriously, even THAT would be an upgrade!
Actually, since reading the head post, I noticed that some of the parts have been discontinued. Can someone give me a too cheap intel and AMD solution... help a brotha out...
i havent looked at adding a really cheap intel build as at the time there was nothing as cheap as amd that performed any better but i will have another look
the main reason i liked amd with the cheap builds is they have a great onboard gpu intel is currently lacking in this area
if you could point out any parts that have been discontinued would be great i update it fairly regularly but can miss things
might add this as another cheap build cpu is decent for the price gpu im not so sure about but should do the job for office work
CPU Intel Celeron Dual Core E3300 2.5GHZ 800FSB LGA775 $53
MB\GPU Asus P5G41T-M LE G41 $62
RAM 2G(Single Stick) DDR3 1333 $55 add another 2g late
HDD: sata 160GB 7200rpm $35
DVD: DVD Burner $33
CASE\PSU Antec NSK 4480B-II $109
$347
Apparently there is another Corsair H50 competitor called the Cool It ECO A.L.C CPU cooler... o_O
I think it will perform quite similar though... good, but the high end air CPU coolers will outperform it.
yer review here
http://www.tweaktown.com/reviews/3189/cool...oler/index.html
its still beaten by air
to compete with a single fan rad they need to make a thicker 140mm rad instead of these puny 120mm rads it comes down to surface area in the end if the rad is smaller and lighter than the hsf the hsf should win under high heat loads with quiet fans
That's true, although I don't think that there are too many cases out there that have 140mm rear fan spot to hold that at the back of their case.
if they used a 140mm rad mounted outside the case on the rear 120mm fan it would allow them to use denser fins as the extra size would help compensate for the loss of airflow the down side is extra cost brass\copper\alloy are not real cheap but it should only be around an extra $20 and tubes would need a way to get back into the case
Hmm ok... So that's what those rubber grommeted holes are for!! Argh... Never really bothered to check out water-cooling because I thought it was just a hard process that I wouldn't be using.
how up to date is this config?
High end
CPU i7-930 2.80Ghz $348
MB GB X58 UD3R $239 - OR - ASUS P6T Deluxe $368
RAM 6GB DDR3 G.Skill 1600MHz F3-12800CL6T-6GBTD CL6-7-6-18 (3x2GB) $235
HDD 1TB 7200RPM 32M $100
DVD Samsung SH-B083A Blu-ray $128
HSF Cogage Thermalright TRUE Spirit $44
CASE Lian Li Lancool Dark Armor K60 $115
PSU Seasonic X-Series 650W $206 2 gpu's
TOTAL $1415-1544+gpu (5850\5870 would be my pic)
Pretty up to date to me. Although it does come down to user preference... I for example will not want a Blu-Ray player and I might get the K62 case instead!
Value Gamer
RAM 2x2g 2133 c9 $159 - OR - 6GB DDR3 G.Skill 1600MHz F3-12800CL6T-6GBTD CL6-7-6-18 (3x2GB) $235
With this MB MB GA-P55A-UD3R $169
Should the G.Skill memory be 2x2GB??
its a triple channel kit which the mb cant make use of but it wont be any slower with it just gives you a little extra ram which can help things load a bit quicker and will become more useful in the future
well there was a few things getting a little out of date so i spent the day updating it for you even though the changes are mostly minor main things were adding a phenom II x6 and removing 4770 and the e5300 build
Dasa, I seriously love you man. Every time im looking at doing a new build this thread is usually my first stop (usually the last too lol). I think im going to go with something similar to the i3 530 build and build mum a PC for mothers day. Hers broke a while ago and that seems like the level she'd want. High end office / multimedia
Although I'm still wondering whether the i3 530 is the best for her. The other build in the 500-700 price range is the Cheap Number Cruncher, but I know next to nothing about how AMD chips stack up lately.
Edited by SheepyTwoPointOh
what dose your mum do with the pc? if its just web browsing and a few office apps but she likes it zippy maybe the atom (near the bottom of the builds) with a ssd would do
its almost fanless and uses stuff all power
i3 530 is a good build for a office pc to can just use the onboard gpu it has a fair bit more grunt which should help with things like playing hd flash media and any cpu intensive aps
the amd build with 4-6 cores is only worth it if the pc will be used for multithreaded aps that demand a lot of cpu power
Well general computing + some media. So specifically, email, using open office, music, general browsing for womens things (who knows what they do), and she likes her music. I'm not too hard pressed for money at the moment so I thought the i3 530 would be a good buy that should last her a while.
Also went to check the recent prices on MSY and I think they'd made a typo and listed the GB UD2H as the US2H. They already listed the S2H seperately and apparently the "US2H" doesn't exist.
