Fez
I need help finding rings like these please.
Hi, I am trying to find somewhere that sells these rings in Australia.
http://s178.photobucket.com/albums/w259/fezzy72/Rings/
I found a place in the US and by the time you buy them add shipping
and do a currency conversion they end up really expensive.
If anyone finds them here please let me know, i'm desperate.
Thanks, Luke.
Ah, blank bezel cup rings :-)
Aussie Sapphire have some fancy-pants blank rings, although it doesn't look quite like what you're looking for, and they're a bit exxy.
Beads on Kelly Street have some funky looking ones like this, or this or this.
Though I usually just make my own, so I'm not much help off the top of my head. I can check my usual suppliers in a bit if these sites don't look like they help you out much
edit: spelling
edit: actually, before I go pointing at stores, I should find out what your requirements are, shouldn't I? I'm an idiot :-)
What are you looking to do with them (ie, pour resin, attach cabs/pre-supplied inserts)? And as pappes said, what material do you need them to be made out of?
one more edit: Feeling Inspired have a small selection of ring components, although not quite bezel cups unfortunately.
Edited by elvenwhore
Fez.
Why don't you ask elvenwhore for a quote ?
They're pretty reasonable pics, easy to see the design.
To me ,they don't look like the average cast, are they silver ?
You should be looking for a place that does jewellery findings. Try places in sydney like "House of jewellery", and A&E metals.
Or failing that learn to make your own, they will ultimaly look far better than a mass produced cast setting.
