nodnerb
Help: "Warning: file_put_contents() : failed to open stream"
Yo
I'm using Artisteer template designer for Joomla, which exports the templates to zip file for upload and install through the extension manager.
Did a full test run in local environment using XAMMP without any hassles at all.
Now replicating this on my webhost, and when I go to upload and install the site template, I get the following error:
Warning: file_put_contents(/home/sou49347/public_html/joomla/tmp/install_4a4755386c97d/SoundSuccess/functions.php) [function.file-put-contents]: failed to open stream: No such file or directory in /home/sou49347/public_html/joomla/libraries/joomla/filesystem/file.php on line 298
Here's line 298 of the functions.php file:
$ret = file_put_contents($file, $buffer);
Buggered if I know why. Any ideas?
noddy
CLOSED
There was a problem with the zip routine from the template software.
I manually zipped myself and this solved it.
w00t!
now a days it is very tough to find a template which you can say that this is right template for you because many web designers and web developers are designing and developing templates very fast. thats why decision making not easy to select a templates.
