xzibit0007
Where to pucharse a Multimedia HD
Does any one know of stores that sell Multimedia Hd, preferably with a hard drive of 500gb + or 1tb? Also any brands that are recommended?
i'd grab something like this
http://www.umart.com.au/pro/products_revie...3&sid=29139
because its pretty cheap and compatible with NTFS formatted harddrives
along with one of these
http://www.umart.com.au/pro/products_revie...9&sid=35180
1TB, 3X 333GB platters, $99, 5400RPM.
Densest platters = fastest read\write.
5400RPM = MUCH less heat
and while 5400RPM isnt something you look for in a desktop, in a media enclosure it is. its also quieter, cooler less vibration, USUALLY more reliable, and you dont notice a speed drop thanks to the great platter density.
www.staticice.com.au, just throw it through there, should show you what u need :D
yeah, but it's handy to know what you're looking for first.
Ye knowing what to search for can certainly help. :P
Although a lot more expensive I would actually go for something like a Dvico TViX-2230 DVB-T HD PVR
http://www.tvix.co.kr/eng/products/PVRR-2230.aspx
Then you can use it to record digital TV as well as use it as a media player and external HDD.
