fisha
Help
hey guys... umm just wondering, im planing to build my own computer, and instead of ordering all the parts off of the internet.
I want to get them from a store,
i live in brisbane and i need a shop that provides nearly all the parts i need...
any ideas would be greatly appreciated
Is this the first PC you've built?
Is good customer service important to you? If so, you understand this might mean you pay a bit more right?
Can I ask why you want to get them from a store instead of on the net? Is it to save on shipping or to get assistance in the store?
I hate ordering stuff off the net.
You can never be certain when (or if) you're going to get the item, in what condition, and returning anything is rarely even worth it.
In Brisbane your best bet is probably Umart.
lol thanks alot for the quick reply lol =)
umm yes it is the first, im only 15 haha..
yeh i just thought it might be easier to get it from a store for some support and stuff, but if you could recommend a good site that would be good to.
and thanks for that store tantryl appreciate it
In that case, +1 Umart. Better customer service than MSY imo.
Feel free to post what you're thinking of getting in the Building section and some peeps will give you some feedback before you even go into the store. :)
I only use umart so +1 to tantryl
also Fisha if you need help with the parts for your budget don't hesitate to ask :)
ok thanks alot.... what i was thinking of getting, is wouldnt mind some feedback on this either thanks =)
is
a quad core not quite sure what one yet but maybe a 2.4
4gb memory
9800 GTX+ 512MB
umm what i would like some info on is what motherboard to get... ive never known much about them =p
is
4gb memory
9800 GTX+ 512MB
i sorta want to spend about maybe 1000$
ive got a mate in a swat 4 clan that made a really awesome comp for only 1000 so i figure that would be cool =)
thanks
is
4gb memory
9800 GTX+ 512MB
thanks
I take it you have a screen and OS? if so for $1000 i would go down this track
-e8400/q6600 depending on your needs (gaming/encoding)
-gigabyte ep45 ds3l
-2gb 800mhz ram or 4gb if you have a 64bit OS
-Gecube HD4870
-antec nsk 6580 case and psu
-Western Digital 640gb hdd
-pioneer 216b dvdrw drive
that should come to about $1000
thanks for that... i want this computer mainly for gaming, well thats what i need the performance for.
umm im not very farmiliar with the e8400/q6600 what would that be like 2.4 or what??
o and i dont really need a very big hard drive, just atm i have a 180 and its nearly full so i need something like a 220 or so.
and yes i alwready have vista,
sorry lol would u mind tellin me what a
gigabyte ep45 ds3l is
and a
-Gecube HD4870
hah thanks alot
ah i see... well i really want to stick with the nvidia graphics cards and, that motherboard sounds great lol... i dont know much about them myself so that should be ok.. :)
and a
-Gecube HD4870
hah thanks alot
Gigabyte EP45-DS3 is a motherboard where you put your Intel CPU / ram / vga / Basically the base of your computer
GeCube HD4870 is a ATI 4800 Series VGA Card.
Google and Wikipedia is your best friend.
haha... ok thanks guys, appreciate it =)
what do u think about this
GSkill 4G(2x2G) DDR3
Creative SoundBlaster Audigy SE Sound Card 7.1
Intel Xeon Quad-Core X3360 2.83G S775
Seagate Barracuda 250GB 7200RPM(16Mb Cache)
Asus VW192C 19inch wide 5ms DVI-D Colorshine 1ys Zero Bright Dot
Antec Three Hundred Tower Gaming Case- Black NO PSU
e-GeForce 9800GTX+ SSC Edition, 512MB
There's no motherboard in there and no PSU.
The 640GB is recommended because it is a very fast drive.
I'd be surprised if what you listed comes in under $1000 (before you add the costs of a mobo & psu).
I'd take nesquick's advice if I were you.
lol yeh, its not gonna be under 1000, because that adds to 1000 wat i listed there. what is the psu??
If you don't know the basic parts of a computer you should do some serious reading before you attempt to put all this together, just a tip ;) everyone starts somewhere
also at the moment there is no discernible difference between low end ddr3 and mid range ddr2 (maybe %3) which does not justify the price difference
also for gaming a faster clocked dual core is better than a slower quad core as most games are only designed to run on a single core anyway.
umm what else oh yea if you want nvidia give the 9800 a miss and get a gtx260
PSU = Power Supply Unit which is critical to running your system stably
power supplies stick to the following and you wont end up destroying your system with some generic piece of junk
-corsair hx520/620
-corsair vx450
-antec earthwatts 380/430/500
-most silverstone power supplies
that hdd is the fastest 7200rpm drive on the market at the moment and it is always good to have 2 partitions for backups and reinstalls
onboard sound is great just make sure its set to HD not ac97 in bios
as for screens if you can afford the benq g2400w its a cheap 24inch that looks great and is good for gaming (no discernable difference between 2-6ms)
haha believe me mate, i am gettin some help from my cousin who has alwready made his own comp =)
im learning from him, im just chekin out what i should get in it =)
and thanks for the advise.
with the PSU, should i just get
Antec NSK6580 Solution Series ATX MiniTower
instead of buying a separate tower and PSU??
the psu in the nsk is a very good one
just search earthwatts 430 review and it should return some nice results its this one> http://www.antec.com/us/productDetails.php?ProdID=27430
although the best would be a corsair hx520 as they use industrial grade parts and come with a 5year warranty.
ah ok, thanks, im just thinkin bout the price here. because if i buy it separately then it will cost a fair bit more.
Personally id take Nesquicks advice what hes layed out would be a very nice computer.
And is very similar in spec to mine, and i really cant fault it :)
you shouldn't put a price on critical system parts, another bit of advice ;) things like the psu is something that should never be scimped on as it may one day save the rest of your computer from frying due to a short or something like that.
ah ok... well, using all ur advise i will go do some searching and get all the parts i think would be good based on wat u guys have said,
and ill post them back
thanks again for the advise
