mark84
The Truth About Graphics Power Requirements V2
That's totally understandable.
The csv or/and website is a pretty cool idea too.
I'm looking forward for any new development (whenever it happens).
Thanks again for the reply and for your hard work. :)
Added
- GTX 480 (512SP)
- HD 4670X2
- GTS 450
- GTS 450 OC (850/1000)
- GTS 450 OC (925/1000)
- GTS 450 SLI
- GTS 450 OC SLI (920/1025)
- GTS 420
- Quadro 4000
- Quadro 5000
- Quadro 6000
- FirePro V9800
- As per vampy's request I've now made a CSV file which will be kept updated. You can find it HERE. This link will also be under the graph in the OP for future reference/downloadage. Let me know what you think!
Updated
- GTX 460 1GB
- GTX 460 1GB SLI
- GTX 460 1GB OC SLI
- GTX 460 768MB SLI
- FirePro V3800
- FirePro V5800
- FirePro V7800
- FirePro V8800
- Quadro 5000
- Quadro FX 5800
- Quadro FX 4800
- Quadro FX 1800
- Quadro FX 580
Added
- HD6870
- HD6850
- HD6870 CF
- HD6850 CF
- HD5970 4GB OC CF
- Quadro 2000
- Quadro 600
- Quadro Plex 7000
- Quadro 5000M
- GT 430
- GT 440
Updated
- GTS 450
- GTS 450 SLI
- GTS 480 OC SLI
- HD5970 4GB OC
Yeah I saw that and is mainly the reason I didn't use that review as a source (can only have 4 source results per card atm) and as I had 4 other reviews to choose from I used those instead. All the other sites that measure accurately were reading about 20W idle.
I often filter out obvious variations like this. If a result skews too far from the standard deviation I omit the offending reading. Or use another site's results. If there's not much data around I may stick with it even if it skews a bit much, as I think with not much data, any more data even if not quite correct still helps.
In this case 10W and 33W is quite varied compared to what 4 other good sites were measuring, so left xbits out this round.
fair enough
silly me for not looking at the reviews you had collected the data from first
would the average user ever see that kind of draw? I doubt it but never the less that is what the card draws at full tilt maybe add a second GTX580 uninhibited column or something?
I'd was going to suggest leaving it below the Furmark level, however after a bit of a look around I did find this:
While this is a hardware measure the real trigger is in software. FurMark and OCCT are indeed throttled, but we’ve been able to throw other programs at the GTX 580 that cause a similar power draw. - Anandtech GTX 580 Review
To be honest I wasn't aware of anything else that put up that kind of sustained draw, so it is a bit of a surprise. To be honest I'd leave it at 300w for a little while rather than worrying about it excessively right now - it'll take a while for various other RL ingame to come in (not that I doubt techpowerup et.all per se, just I think more data points would be good). If that does turn out to be anything other than a very unusual case though definitely up the peak load, however at a guess I'm thinking that won't be necessary.
Sorry about the long wait between updates.
Added
- GTX 570 & SLI
- GTX 580 3x & 4x SLI & OC
- GTX 460 SE
- HD 6950 & CF
- HD 6970 & CF
- HD 6850 OC & OC CF
- HD 6870 OC & OC CF
- Added "Active Power Management" section to OP
Updated
- Updated the "Getting power to them cards!" section in OP
I hope you may update soon with these newer cards in the wild (mostly GTX 560Ti), and thanks for your efforts!
Yep, with the imminent release of the GTX550 and dual GPU cards from both camps I'll post an update once they're out.
We'll wait: the official launch of the reference Nvidia GeForce GTX 550 Ti (GF116) is scheduled in three weeks' time.
Yeah I was hoping it would be sooner.
Updates made.
Added
- GTX 570 3x SLI
- HD 6950 and 6970 3x CF
- GTX 580 OC SLI
- HD 6950 OC
- GTX 560 Ti & OC & OC SLI
- HD 6950 1GB & OC
- GT 440 (retail)
Updated
- GTX 580 3x SLI
- HD6950 CF
- GTX 460 1GB
Added
- HD6990 & OC & CF & OC CF
- GTX 560 SLI
- GTX 550 & OC & OC SLI
- GTX 590 & SLI & OC
- HD6790 & CF
Updated
- GTX 570 SLI
- GTX 560 SLI OC
- GTX 580 3x SLI
- HD 6970 3x CF
Added
- HD 6450 GDDR3 & 5
- HD 6670
- HD 6570
- GT 520
- Sandy Bridge HD3000 IGP
- HD 6990 + 6970 3x CF
- GTX 560 & OC
- HD 6770
- HD 6750
- GT 530
- GT 545 GDDR3/5
Updated
- GT 440
Glad you found it useful :)
Interesting that I haven't posted an update in a long while. Basically nothing has come out since!
Well there was a FirePro card out yesterday, but apart from that not much. I'll probably wait until HD7000 series before the next update.
As promised, the update with HD7000 card!
Added
- GTX 580 3GB OC
- FirePro V7900 & V5900 & V4900
- HD 6870 X2
- GTX 580 ASUS Mars II
- GTX 560 Ti 448 & OC
- HD 7970
- GTX 560 Ti "EVGA 2Win"
Updated
- HD6450 GDDR3
- HD6770
- HD6670
Holy mother of God. After all this time I'd not looked at this. Amazing work Mark, after reading the methodology this has to be the best resource I've seen for this topic on the interwebs!
You sir is a winrar!
The charts are no longer visible on the site, and no information is presented in text. I just thought you should know...
Yeah it's bound to happen, websites get updated, URLs change etc. I'm not going to bother updating links once I've put them in. At the time I put them in they work.
No doubt though you can search their site and find the article in question though.
rofl you've only just seen this? This has been going since well before forums 3.0 launched. :P
In fact this thread really should be called V3 not V2. Had to do a lot of rejigging when forums 3.0 happened (back then all graphs we're ASCII art!)
But yeah, glad it's useful and thanks for the praise. Like watching the thread views go up. No one comments much but I know it gets looked at a lot lol.
Added
- HD7970 2x, 3x & 4x CF
- HD7950 CF
- HD7770 & OC & CF
- HD7750 & OC & CF
- FirePro V3900
- HD7970 OC
Okay, so my PSU supplies 408W on the 12V. My CPU's max TDP is 128 W. Therefore, that leaves ~280W for the GPU right? The AMD 6950 uses 176W @ Peak 3D. Does that mean my 450W XFX PSU can handle a 6950?
