LordBug
Now these are some sexy DIY speakers!
I doubt you'll have any JAN6418's though.
Just give the kid some KT88's instead :P
I near cried one night......I had four 6550's and some EL34's.....and this dickhead had put them in a box with a dodgy bottom (I didn't know that) and they waited until I got to the tiled floor in the laundry before they fell out!
Lost 2 6550's and one EL34!
awww fuck man :(
I'll get around to a nice class A design at some stage... Transistors can only take you so far...
when researching speaker construction, i found an article where a guy made in essence a floating speaker cabnet, placed one cabnet in another with a 3gap and filled with asphalt.
edit
found the article
http://www.speakerbuilding.com/content/1044/
Interesting...
Bookmarked for later :)
@ Logic
Ah...fuck!
6550's? half a set of a matched quad?
Bummer :(
Those new issue Tungsols I got for my mates Grant amp are sounding nice, good valve for a reissue.
@ Rob, I have a pair of Russian 6N3's here if you want them?
Edited by datafast69
I'm gonna grab one next time I'm at Oatley!
I like the tube dampeners he's got there!
oatly is a waste of time
Wes components i found to be much better.
Read the whole thread.........and you'll find we were talking about a particular kit...as linked by Caelum.
It uses those miniature valves, this is something I missed :P
Fuck they look funny with the dampening rings on them :)
These 6N3's are of no use then, unless building something different, like a normal pre-amp maybe :D
Edit:I wonder if that thing can drive a SS power amp that has a input impedance of 22kohms?
The kit? Given the solid state buffer on the front end I'd be terribly surprised if it couldn't.
Rob.
That kit is a bargain.
I'm gonna get one to try...........want one DF69?
Very tempting mate :)
I can't get one for another three weeks, bloody rego shafted me last week :(
I hate op-amps though they do have there uses in low cost stuff, but I like the Bonsai valves, Rob :D
If you like, mate :)
Looks like a little bit of fun for not very much.
I think I have a power transformer here I can use instead of batteries.
Yeah I have seen how some pieces of kit like this and little DACs use batteries for lower noise from the power.
If I have something here already I'll try it all the same (It's just a wall-wart), maybe even compare it to batteries.
Also guys - the op amp they use is pretty ordinary - replace it with a better one... there are suggestions for it around on the net somewhere i think.
here:
http://diyaudioprojects.com/Tubes/6418-Tub...-Headphone-Kit/
"With the original PT2308 IC the kit is a capable headphone driver. The PT2308 has only slightly higher distortion figures than the OPA2134 but can drive more demanding loads such as 32 ohm headphones. Because I am using this build strictly as a preamp (feeding a valve power amp) the OPA2134 is a better choice. "
I'll need to use that op-amp too, Caelum.
I might try some others at some stage too, something to look at and have fun with at the same time :)
If I remember right, back in my youth they used a lot of miniature valves (along with there larger friends) in every day consumer shit like TV's and radios...
God I feel old :(
I got this valve tester off a guy in NY City whose old man used it as a 'valve jockey' fixing valve TVs.
It has punch cards you inset for each different valve type.
Very modern!
LOL :)
I have on occasion seen those on ebay, awesome things :D
Hay I might bow out of getting one of these kits, and instead go for something that's an all valve circuit. I'm pretty sure I will be able to drive the amp I'm building directly from this DAC anyway.
Cheers for the thought all the same, Les, very nice of you :)
Thanks for the offer LP, but I ought to be right for now :)
The OPA2227 is a decent alternative to the 2132/2134, it's got a more "tubey" sound though which might not work so well with the actual tubey sound from a... tube.
TI.com offers free samples of a lot of opamps. (But of course the morality is questionable :P)
Rob.
