Euhemerus
Help finding suitable Case
Hey everyone,
I have just installed my 9800GX2 and damn its bigger than I expected. I currently have a Lian Li PC-60 and I had to remove the hdd cradle for my 9800GX2 to fit. I now have space for only 1 hdd. I have another 3 hdds that I need back in my machine.
Does anyone know of a good case that will fit this new card and also my existing Thermalright Ultra-120 CPU cooler. The current dimensions of my PC-60 case is 210mmx450mmx490mm(WxHxD). I have almost zero room remaining with my CPU Cooler, so I cannot go less than 210mm.
I am currently using the GA-965P-DS3P motherboard, with a Seasonic M12 PSU. If anyone can help I would greatly appreciate it.
Thanks.
im currently using the cm stacker 832 and it has ample room. i have 2x9800's in it and and still have ~2.5cm from the back of the gpu to the hdd.
move the hdds to the 5.25 bays.
easy
I didn't even think about that.... thanks, but what would be the best way of securing them??
easy
3.5" to 5.25" Mounting Kits...which would be the cheapest way.
easy
3.5 to 5 1/4" adaptors/coolers
http://www.scorptec.com.au/product/1359
http://www.scorptec.com.au/product/12904
http://www.pccasegear.com/index.php?main_p...roducts_id=6871
Or you could use some removable HDD bays like these
http://www.scorptec.com.au/browse/40/139?d...disp&init=1
I use these
http://www.pcicase.com.au/mobile/snt136.htm
for removable SATA drives and with the ability to switch the fan off when not in use it means you do not have the constant fan noise, plus when in use the fan is very quiet.
Agreed, there's plenty of options on the market ranging from front hot swap enclosures:
http://www.pccasegear.com/index.php?main_p...roducts_id=7962
To internal fan cooled bays:
And fan cool bays with front mesh for more air flow:
http://www.pccasegear.com/index.php?main_p...roducts_id=7234
http://www.pccasegear.com/index.php?main_p...roducts_id=5630
http://www.pccasegear.com/index.php?main_p...roducts_id=7182
Or perhaps a single drive with some noise absorbtion is in order:
http://www.pccasegear.com/index.php?main_p...roducts_id=1327
Take your pick.
cheers
