Trekker
windows 7 Networking problem
i have win 7 x64 on 2 pc's and a popcorn hour media tank. All on a network.
When was on win xp had no problems.
Now i do.
Is there a way i dont have to have 2 account to share files between everything. As in win xp no account just clicked on netwrok and that was that.
Edited by Trekker
Windows 7, you need to make a Homegroup.
Go to your Network and Sharing Center. Then on the right you will see Homegroup.
You might be joined on one of the PCs or need to create one.
Create one on one PC, then join with the other PC. You will need the code from the first PC when joining with the second PC. Then you should be right to share.
Under XP you could have a guest account, though it might work differently under Win7.
