njbignell
Trouble Configuring SFP Module for CISCO Switch
I've just bought a Catalyst 2960 Series 24-port switch with SFP module but whenever I plug the fibre into the module I simply get no connection at all. I called CISCO and they sent me an IOS command to change the media type to SFP but that hasn't helped. I was thinking enabling auto negotiation would help but I can seem to get it working.
Here's some output from the IOS:
SWT04#show interface g0/1
GigabitEthernet0/1 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet, address is 081f.f36c.2599
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
Keepalive not set
Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseSX SFP
input flow-control is off, output flow-control is unsupported
ARP type: ARPA, ARP Timeout 04:00:00
Last input never, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total outpt drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
0 input packets with dribble condition detected
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 babbles, 0 late collision, 0 deferred
0 lost carrier, 0 no carrier, 0 PAUSE output
0 output buffer failures, 0 output buffers swapped out
Thanks to anyone that can help, cheers
Can you give us a sh run?
TRCSWI04#sh run
Building configuration...
Current configuration : 3106 bytes
version 12.2
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
hostname TRCSWI04
boot-start-marker
boot-end-marker
enable secret 5 ################################################
no aaa new-model
system mtu routing 1500
ip subnet-zero
crypto pki trustpoint TP-self-signed-4083950976
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-4083950976
revocation-check none
rsakeypair TP-self-signed-4083950976
crypto pki certificate chain TP-self-signed-4083950976
certificate self-signed 01
30820241 308201AA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
69666963 6174652D 34303833 39353039 3736301E 170D3933 30333031 30303030
34395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D34 30383339
35303937 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
8100A46C B0E7479B 22822F94 CB74798F 1BA1399F 182DF9CF 23668397 2D383D89
B8F2B3C8 CF363C41 E0F00F51 B15FE784 F07BD9AA 63283708 979A82C0 9D6DBA77
91EB386E D81FDAB2 78FDA00F 3EA814D4 0D6AC2DB 5B29C857 DBA3A045 343938A7
7CE94078 9CDCBF7F 9046EF45 0E5B3DD8 BE684FDE A8D65000 AEBD0C54 DB462061
B7D70203 010001A3 69306730 0F060355 1D130101 FF040530 030101FF 30140603
551D1104 0D300B82 09545243 53574930 342E301F 0603551D 23041830 16801467
3697572D D5D36116 66612B03 D769782B FC1EFE30 1D060355 1D0E0416 04146736
97572DD5 D3611666 612B03D7 69782BFC 1EFE300D 06092A86 4886F70D 01010405
00038181 005D02DA 4FAF3E47 BA4803BC 55DC6DE3 7F344319 DD6D20FB A9B3EEDF
BDC55A2E 0FE69955 B586C254 206B2546 E64CBD68 26640818 0DA69FD8 428A5D00
53AC94B3 6C7E910E 8B74D0BE 746A5AD9 68C5355D E4861390 2A2DFB87 1044E395
B871B85C 4D817FA3 87297455 27D63D50 7675F75B E869367A EF4FDE27 1C9A0D8E
A3F3B633 7A
quit
spanning-tree mode pvst
spanning-tree extend system-id
vlan internal allocation policy ascending
interface FastEthernet0/1
interface FastEthernet0/2
interface FastEthernet0/3
interface FastEthernet0/4
interface FastEthernet0/5
interface FastEthernet0/6
interface FastEthernet0/7
interface FastEthernet0/8
interface FastEthernet0/9
interface FastEthernet0/10
interface FastEthernet0/11
interface FastEthernet0/12
interface FastEthernet0/13
interface FastEthernet0/14
interface FastEthernet0/15
interface FastEthernet0/16
interface FastEthernet0/17
interface FastEthernet0/18
interface FastEthernet0/19
interface FastEthernet0/20
interface FastEthernet0/21
interface FastEthernet0/22
interface FastEthernet0/23
interface FastEthernet0/24
interface GigabitEthernet0/1
media-type sfp
interface GigabitEthernet0/2
media-type sfp
interface Vlan1
ip address #.#.#.# 255.255.255.0
no ip route-cache
ip default-gateway #.#.#.#
ip http server
ip http secure-server
control-plane
line con 0
line vty 0 4
password ###############
login
line vty 5 15
login
end
Well I don't know SFP but you don't have that port setup at all.
eg;
int gi0/49
switchport mode trunk
switchport trunk encapsulation dot1q
switchport trunk native vlan 1
Or whatever you want.
eg;
int gi0/49
I'm trying to set it up for fibre, I've never worked with the IOS in switches, only routers. Can someone give me the commands I need? I only want a basic setup
Edited by njbignell
A couple of assumptions here...
1. The fibre is plugged in at the other end, and you *know* that interface is/was operational
2. The fibre is undamaged
3. You have the fibre plugged in correctly at all joins (i.e. rx > tx, tx > rx)
4. You are using compatible fibre (in this case, it looks like multimode is the go...)
unless you have the above, you won't get the link light showing
with regards to your port config, the switch has recognised the module, so I don't think there is a problem with your switch or sfp.
A test I have employed to check MULTIMODE fibre, is to plug it in, and very carefully look at the end. You should see light coming out one end. Plug in the other way around, and repeat.. (and yes, the LC connector can be swapped around, it is just a bracket holding the fibre ends in place, its a sort of twist, and it will come free.) btw, NEVER do the above with single mode, the light / laser is way more intense, and a very high likely hood of blindness if you look directly into the end of a lit single mode fibre...
Edited by garlic
Yeah I've tried averything you suggested there and everything seems to be working fine, but thanks anyway. I'm fairly certain it has something to do with the configuration in the IOS.
Edited by njbignell
this:
says otherwise...
There really is nothing you need to configure in order to get a link, just plug in the cable at both ends and away you go. To double check this I just checked our old 2960 configs for SFP configuration and there is nothing.
What is on the other end of the cable? Is it the same type of SFP module or is it something else?
The other end goes into a media converter (RJ45) and then into the RJ45 Gigabit uplink on another switch.
After I set the speed negotiation to auto the fibre side of the media converter lit up but still nothing lights up on the SFP port of the switch.
Ill try get in there before anyone arrives tommorow and try a different port (all the uplink ports are taken bar one so I'll have to disconnect part of the network to try anything)
My guess would be either faulty fibre, faulty SFP or faulty switch. I would start with the fibre myself. The media converter is possibly giving a link indication because it is receiving light, and the SFP isn't or similar
there isn't anything else you can configure on a 2960 to enable the SFP other than specifying the media-type (afaik) (the other media-type being a GLC-T or 1000Base-T interface) and this is only optional, I have rarely had a problem leaving the media-type unconfigured, and letting the switch work itself out...
Can I see a show version and could you also include the cisco part number for the sfp? Also they brand / model of the media converter would also be handy.
I'll post it all for you in the morning
TRCSWI04#show version
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(44)SE6, RELEASE SOFTWARE (fc1)
Copyright © 1986-2009 by Cisco Systems, Inc.
Compiled Mon 09-Mar-09 18:10 by gereddy
Image text-base: 0x00003000, data-base: 0x01100000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(44)SE6, RELEASE SOFTWARE
(fc1)
TRCSWI04 uptime is 33 minutes
System returned to ROM by power-on
System image file is "flash:c2960-lanbasek9-mz.122-44.SE6/c2960-lanbasek9-mz.122-44.SE6.bin"
........ << Boring Stuff
cisco WS-C2960-24TC-L (PowerPC405) processor (revision J0) with 61440K/4088K bytes of memory.
Processor board ID FOC1409V50L
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 08:1F:F3:6C:25:80
Motherboard assembly number : 73-11437-07
Power supply part number : 341-0097-02
Motherboard serial number : FOC14095C2N
Power supply serial number : DCA14078EGY
Model revision number : J0
Motherboard revision number : B0
Model number : WS-C2960-24TC-L
System serial number : FOC1409V50L
Top Assembly Part Number : 800-29826-03
Top Assembly Revision Number : E0
Version ID : V06
CLEI Code Number : COMFT00BRA
Hardware Board Revision Number : 0x01
Switch Ports Model SW Version SW Image
* 1 26 WS-C2960-24TC-L 12.2(44)SE6 C2960-LANBASEK9-M
Configuration register is 0xF
To me it sounds a little like a faulty cable somewhere along the line.
Can you post a "show inventory"? Blank out the serial numbers if needed. Also, the model of the media converter would be useful.
What type of cable are you using? Is it the same all along the line?
I am assuming the media converter is quite a distance away from the switch (perhaps inter floor)? The WS-C2960-24TC-L has 2 dual purpose gig links. Meaning while there are four ports, only two can be used. If the other switch is in the same room, I would just run copper and be done with it.
The media-type sfp command selects between the copper and sfp port, so regardless of how its physically connected it should still work... at a bit of a loss here to be honest
Did you end up being able to test the sfp / fibre on another port?
It's in the same room at the moment but we'll be deploying it shortly. I've got CISCO calling me again today but they don't seem to know what going wrong either
