jubbing 0 Posted May 17, 2010 Basically I have TPG, and they do a decent job (from time to time), but I know now there are PLENTY of other alternative companies. I get 5.5mb/s max when I should be getting 15 at least (as confirmed by TPG). SO I don't know if it is house wiring or what, I'm like 1km away from exchange. Are there those network providors that give they speed they specify as per distance from exchange? Share this post Link to post Share on other sites
Chancellor 3 Posted May 17, 2010 There are too many factors to take into account when it comes to the final transfer speeds. Line noise, house wiring, street wiring (which you HOPE is ok), how wiring is terminated, how many connections there are, etc. There is no guarantee that you will get the quoted speed. A few things you can try are: - Make sure your modem is running a recent firmware release, especially if you are running with firmware that is very old or the initial release. I know it's a cop out when someone says upgrade your firmware, but it does quite often help and only takes a few minutes. - Try an isolation test. Unplug all phones/devices on the line, leaving only the modem plugged in. Do not use a filter here. Check your line speeds and download speeds. This isolates if another device is adding noise to the line. If it helps, add one device at a time and check if something changes in regards to transfer speeds. - Make sure that every phone on the same line has got a filter attached. The modem should not be filtered. (If you have one of the splitter filters, make sure the modem is plugged into the correct port). - If you have a friend who has adsl, ask if you can borrow their modem or if they can test yours. This is probably a long shot but can help to isolate hardware problems. (I don't think this will be your case, but it's something to try before changing ISP) - If you are using bandwidth test sites, make sure that you are using something hosted in Australia, and run multiple tests at different times of the day. Using one test only is not going to prove anything. - If you suspect dodgy cabling in the house, try another place in the house, preferably as close as possible to the place where the cable enters the house. (This may or may not be known) I don't think any consumer ISP will guarantee you X bandwidth. Yes you can try another ISP but it is highly possible that you will get the same kind of results. Rule out anything local before making any drastic changes. Share this post Link to post Share on other sites
Master_Scythe 541 Posted May 17, 2010 if TPG support it try changing your modem connection setting from PPPoE to PPPoA. I know technically it shouldnt make much of a difference; but with Exetel it was a whole 2.5Mbps difference >< Share this post Link to post Share on other sites
jubbing 0 Posted May 17, 2010 Yea Chancellor, done ALL that like 20 times (excpet trying to find net connection from someone nearby) And PPoA or wtv shut donw my net lol.. so fail on that for me. Share this post Link to post Share on other sites
HyperHorse_ 0 Posted May 18, 2010 Having read and considered the information in this thread, I can only come to one conclusion..... TPG SUCK. It's time to switch! Share this post Link to post Share on other sites
Chancellor 3 Posted May 18, 2010 From memory TPG do support both PPPoE and PPPoA, so it's worth giving it a shot. (Unfortunately I can't test this for you as I don't have my TPG connection anymore.) If you do change to PPPoA, you will need to change to VC based multiplexing. PPPoE will be LLC. (Just in case you did not change both at the same time) As a matter of interest: -What modem do you have? -How are you testing the connection? Are you reading the numbers from the modem sync speed, or using a test site? If the later, what does the modem sync speed get reported as? (This should be in the modem status page.) Share this post Link to post Share on other sites
ArcaneMagik 0 Posted May 18, 2010 (edited) Also a quick note, if you have done all of the above and are still having trouble, that should be enough for TPG to organise Telstra to send a line commit to confirm your connection to outside the house. If you iso test and have slow speed with a 2nd modem, there is really not much else you can do other than having your own electrician check the wiring in your house. Edited May 18, 2010 by ArcaneMagik Share this post Link to post Share on other sites
LogicprObe 66 Posted May 18, 2010 If you want fast, get cable. Share this post Link to post Share on other sites
krispy89 19 Posted May 18, 2010 If you want quota, go with anyone OTHER THAN fuc@ing Telstra. Share this post Link to post Share on other sites
jubbing 0 Posted May 18, 2010 WNDR3700, its gotten a little faster now after a bit of complaining on the whirlpool forums. Speedtesting done via speedtest.net as well as router status page. Share this post Link to post Share on other sites
PC FREAK 0 Posted May 18, 2010 The best is Internode IMO :) Share this post Link to post Share on other sites
mattym 0 Posted May 18, 2010 Having read and considered the information in this thread, I can only come to one conclusion..... TPG SUCK. It's time to switch! Share this post Link to post Share on other sites
HyperHorse_ 0 Posted May 18, 2010 mattym, get with it... Everyone knows TPG sucks. Share this post Link to post Share on other sites
eat_the_flag 0 Posted May 18, 2010 mattym, get with it... Everyone knows TPG sucks. Well i am with TPG and i love it. So you are wrong HH Share this post Link to post Share on other sites
mattym 0 Posted May 18, 2010 I'm also with TPG and love it. No problems and cheap as chips with awesome quota. It's ok though... I know you're trolling and just looking to stir the pot. Nice try though. Share this post Link to post Share on other sites
Chancellor 3 Posted May 18, 2010 Despite my personal thoughts on TPG as a company, I can not complain about the end product for the given price. You do get what you paid for in most cases. And yes you will read bad things about every provider. As ArcaneMagik states, give TPG a call and ask if they can organise for a telstra tech to come out. You have done just about all of the tests that you can do by yourself, though I would suggest testing with another modem to check if that syncs at a higher speed. Share this post Link to post Share on other sites
HyperHorse_ 0 Posted May 19, 2010 I'm also with TPG and love it. No problems and cheap as chips with awesome quota. It's ok though... I know you're trolling and just looking to stir the pot. Nice try though. I'm not trolling. I just refuse to support a company that gives rubbish customer service and which out sources all of it's customer service staff to a country where I'd regard the people residing in this country to have intelligence barely higher than primates. Share this post Link to post Share on other sites
eat_the_flag 0 Posted May 19, 2010 (edited) I'm not trolling. I just refuse to support a company that gives rubbish customer service and which out sources all of it's customer service staff to a country where I'd regard the people residing in this country to have intelligence barely higher than primates. That country that the call centre is located in is the Philippines and since i was born there i take offence to that. Fuck you. Edited May 19, 2010 by eat_the_flag Share this post Link to post Share on other sites
iamthemaxx 0 Posted May 19, 2010 I'm also with TPG and love it. No problems and cheap as chips with awesome quota. It's ok though... I know you're trolling and just looking to stir the pot. Nice try though. I'm not trolling. I just refuse to support a company that gives rubbish customer service and which out sources all of it's customer service staff to a country where I'd regard the people residing in this country to have intelligence barely higher than primates. Dude, you continually put your foot into shit and you wonder why people think you stink? That is one of the most retarded things you have said in a while, and by while I mean a week or so. Think before posting. Share this post Link to post Share on other sites
bushi 34 Posted May 19, 2010 Well if you're dumb enough that you NEED support then you only deserve to pay for customer support, rather than awesome quotas and flawless service. Share this post Link to post Share on other sites
moist 0 Posted May 19, 2010 I'm also with TPG and love it. No problems and cheap as chips with awesome quota. It's ok though... I know you're trolling and just looking to stir the pot. Nice try though. I'm not trolling. I just refuse to support a company that gives rubbish customer service and which out sources all of it's customer service staff to a country where I'd regard the people residing in this country to have intelligence barely higher than primates. Well that stupidity did well for you. See you in 3 months Marcus. Share this post Link to post Share on other sites
mudg3 0 Posted May 19, 2010 Well if you're dumb enough that you NEED support then you only deserve to pay for customer support, rather than awesome quotas and flawless service. What happens when its on their end though? Even professionals still need support. Share this post Link to post Share on other sites
bushi 34 Posted May 19, 2010 Ya I know, but the support's really not that bad anyway. People just seem to hate accents. Share this post Link to post Share on other sites
mudg3 0 Posted May 19, 2010 Ya I know, but the support's really not that bad anyway. People just seem to hate accents. Well I work for an ISP and its hard enough trying to get them to understand me when Im speaking English. So I could see having an accent being a hurdle. Share this post Link to post Share on other sites
osama_bin_athlon 0 Posted May 24, 2010 I'm also with TPG and love it. No problems and cheap as chips with awesome quota. It's ok though... I know you're trolling and just looking to stir the pot. Nice try though. I'm not trolling. I just refuse to support a company that gives rubbish customer service and which out sources all of it's customer service staff to a country where I'd regard the people residing in this country to have intelligence barely higher than primates. opening your mouth to change feet again, HH? Share this post Link to post Share on other sites
