lew~
ZFS NAS
Hrrrrm....
What kind of speeds are you getting on a zpool scrub?
z
There's not a lot of data on the pool yet, does that matter? The few times I've run it so far it's completed almost instantly. I'll rerun tonight and post back for you.
FYI, the file I was using to test transfers in my last post was a 6GB~, so not heaps of small files either.
Could it be having one Seagate in with the Hitachi's is causing something funky to happen, e.g. different read/write/seek times? I could zpool offline the Seagate to test.
Edit: I'll try connecting the NAS and MBP directly with a crossover cable eliminating the switch. I don't think this is the cause, as iozone is showing poor performance.
Edited by lew~
Correct. Without much data on the pool - it'll be a moot point/pointless test.
Definitely and entirely. Mixing spindles can do some weird IO skew stuff. That said, ZFS is generally intelligent enough to abstract away from it. Remember, when writing to a ZFS based FS, you're not writing to "disk". You're writing to Layer 1 adaptive re associative cache, which in itself THEN writes to disk.
I'm thinking this is a sys config/controller issue at this stage. I'd
1. Try different ports.
2. Offline the odd drive.
3. Re-create the pool.
4. Try a dedicated controller card...
6. iostat -xnMz 1 (so we can see what the raw devices are actually tickling).
etc etc...
z
Edited by zebra
I effectively tried different ports when I swapped all the SATA cables over the other day, most disks ended up on different ports I believe.
I'm thinking the intermittent reads in the earlier zpool iostat output could be due to the way writes are cached before committed to disk, so may not necessarily indicate a problem?
I think I need to get a faster host to test SMB/AFP performance over Gigabit as well.
I'll work on getting my HBA updated to hopefully resolve that write performance issue.
Is running iozone with the options e.g. number of threads the best way to be testing peroformance?
Sorry about the long output, is there a better way for me to post/share these?
First test is with all disks online, second is with the Seagate offline. Fairly small differences between them.
# cfgadm -v | grep c5t
sata0/0::dsk/c5t0d0			connected	configured   ok		 Mod: Hitachi HDS722020ALA330 FRev: JKAOA3EA SN: JK1171YAJ73KAS
sata0/1::dsk/c5t1d0			connected	configured   ok		 Mod: Hitachi HDS722020ALA330 FRev: JKAOA3EA SN: JK1171YAJ7107S
sata0/2::dsk/c5t2d0			connected	configured   ok		 Mod: Hitachi HDS722020ALA330 FRev: JKAOA3EA SN: JK11A1YAJGYWKV
sata0/3::dsk/c5t3d0			connected	configured   ok		 Mod: SAMSUNG HD501LJ FRev: CR100-12 SN: S0MUJ1FPA51820
sata0/4::dsk/c5t4d0			connected	configured   ok		 Mod: ST32000542AS FRev: CC34 SN: 9XW063GR
# zpool status tank
  pool: tank
 state: ONLINE
 scrub: resilver completed after 0h0m with 0 errors on Tue Jul 27 08:51:18 2010
config:
		NAME		STATE	 READ WRITE CKSUM
		tank		ONLINE	   0	 0	 0
		  raidz1-0  ONLINE	   0	 0	 0
			c5t2d0  ONLINE	   0	 0	 0
			c5t0d0  ONLINE	   0	 0	 0
			c5t1d0  ONLINE	   0	 0	 0
			c5t4d0  ONLINE	   0	 0	 0  3.47M resilvered
errors: No known data errors
pfexec /usr/benchmarks/iozone/iozone -R -l 5 -u 5 -r 4k -s 100m -F /tank/f1 /tank/f2 /tank/f3 /tank/f4 /tank/f5
		Iozone: Performance Test of File I/O
				Version $Revision: 3.323 $
				Compiled for 32 bit mode.
				Build: Solaris10cc-64
		Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
					 Al Slater, Scott Rhine, Mike Wisner, Ken Goss
					 Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
					 Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
					 Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy,
					 Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root.
		Run began: Tue Jul 27 10:38:56 2010
		Excel chart generation enabled
		Record Size 4 KB
		File size set to 102400 KB
		Command line used: /usr/benchmarks/iozone/iozone -R -l 5 -u 5 -r 4k -s 100m -F /tank/f1 /tank/f2 /tank/f3 /tank/f4 /tank/f5
		Output is in Kbytes/sec
		Time Resolution = 0.000001 seconds.
		Processor cache size set to 1024 Kbytes.
		Processor cache line size set to 32 bytes.
		File stride size set to 17 * record size.
		Min process = 5
		Max process = 5
		Throughput test with 5 processes
		Each process writes a 102400 Kbyte file in 4 Kbyte records
		Children see throughput for  5 initial writers  =  782781.62 KB/sec
		Parent sees throughput for  5 initial writers   =   45861.79 KB/sec
		Min throughput per process					  =   86586.45 KB/sec
		Max throughput per process					  =  194671.81 KB/sec
		Avg throughput per process					  =  156556.33 KB/sec
		Min xfer										=   47016.00 KB
		Children see throughput for  5 rewriters		=  661704.62 KB/sec
		Parent sees throughput for  5 rewriters		 =   87091.72 KB/sec
		Min throughput per process					  =  111850.63 KB/sec
		Max throughput per process					  =  149290.27 KB/sec
		Avg throughput per process					  =  132340.92 KB/sec
		Min xfer										=   75776.00 KB
		Children see throughput for  5 readers		  = 1259258.39 KB/sec
		Parent sees throughput for  5 readers		   = 1236337.61 KB/sec
		Min throughput per process					  =  186270.27 KB/sec
		Max throughput per process					  =  333463.62 KB/sec
		Avg throughput per process					  =  251851.68 KB/sec
		Min xfer										=   54784.00 KB
		Children see throughput for 5 re-readers		= 1802097.93 KB/sec
		Parent sees throughput for 5 re-readers		 = 1759978.27 KB/sec
		Min throughput per process					  =  100785.37 KB/sec
		Max throughput per process					  =  464689.62 KB/sec
		Avg throughput per process					  =  360419.59 KB/sec
		Min xfer										=   22124.00 KB
		Children see throughput for 5 reverse readers   = 1842751.50 KB/sec
		Parent sees throughput for 5 reverse readers	= 1675142.62 KB/sec
		Min throughput per process					  =  249632.25 KB/sec
		Max throughput per process					  =  431956.38 KB/sec
		Avg throughput per process					  =  368550.30 KB/sec
		Min xfer										=   59748.00 KB
		Children see throughput for 5 stride readers	= 1632873.56 KB/sec
		Parent sees throughput for 5 stride readers	 = 1592591.08 KB/sec
		Min throughput per process					  =  175248.38 KB/sec
		Max throughput per process					  =  409092.91 KB/sec
		Avg throughput per process					  =  326574.71 KB/sec
		Min xfer										=   44188.00 KB
		Children see throughput for 5 random readers	= 1235611.92 KB/sec
		Parent sees throughput for 5 random readers	 = 1197447.41 KB/sec
		Min throughput per process					  =  191432.53 KB/sec
		Max throughput per process					  =  293984.19 KB/sec
		Avg throughput per process					  =  247122.38 KB/sec
		Min xfer										=   66680.00 KB
		Children see throughput for 5 mixed workload	= 1077353.20 KB/sec
		Parent sees throughput for 5 mixed workload	 =  141647.72 KB/sec
		Min throughput per process					  =  151635.84 KB/sec
		Max throughput per process					  =  279004.53 KB/sec
		Avg throughput per process					  =  215470.64 KB/sec
		Min xfer										=   55644.00 KB
		Children see throughput for 5 random writers	=  775466.56 KB/sec
		Parent sees throughput for 5 random writers	 =   80261.95 KB/sec
		Min throughput per process					  =   28181.97 KB/sec
		Max throughput per process					  =  210115.14 KB/sec
		Avg throughput per process					  =  155093.31 KB/sec
		Min xfer										=   13736.00 KB
"Throughput report Y-axis is type of test X-axis is number of processes"
"Record size = 4 Kbytes "
"Output is in Kbytes/sec"
"  Initial write "  782781.62
"		Rewrite "  661704.62
"		   Read " 1259258.39
"		Re-read " 1802097.93
"   Reverse Read " 1842751.50
"	Stride read " 1632873.56
"	Random read " 1235611.92
" Mixed workload " 1077353.20
"   Random write "  775466.56
iozone test complete.
$ pfexec iostat -xnMz 1
					extended device statistics
	r/s	w/s   Mr/s   Mw/s wait actv wsvc_t asvc_t  %w  %b device
	0.0	0.1	0.0	0.0  0.0  0.0	0.4	4.2   0   0 c5t0d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.4	4.4   0   0 c5t1d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.5	4.5   0   0 c5t2d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.0   19.1   0   0 c5t4d0
	0.0	0.0	0.0	0.0  0.0  0.0	5.3	5.9   0   0 c5t3d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0	3.8   0   0 c5t0d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0	2.2   0   0 c5t1d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0   33.1   0   3 c5t2d0
	0.0   51.7	0.0	0.1  0.0  0.2	0.2	3.2   1   6 c5t3d0
	0.0   52.0	0.0	0.1  0.0  0.2	0.0	4.2   0   7 c5t3d0
	0.0   52.9	0.0	0.1  0.0  0.3	0.0	5.1   0   7 c5t3d0
	0.0   51.9	0.0	0.1  0.0  0.2	0.0	4.3   0   7 c5t3d0
	0.0   55.9	0.0	0.1  0.0  0.3	0.0	4.6   0   7 c5t3d0
	0.0  289.2	0.0   23.7  0.0  1.6	0.0	5.7   0  17 c5t0d0
	0.0  291.2	0.0   23.6  0.0  1.7	0.0	5.7   0  17 c5t1d0
	0.0  293.2	0.0   23.7  0.0  1.7	0.0	5.7   0  17 c5t2d0
	0.0   72.3	0.0	5.5  0.0  1.7	0.0   23.1   0  17 c5t4d0
	0.0  145.1	0.0   12.0  0.0  0.8	0.0	5.8   0  10 c5t0d0
	0.0  146.1	0.0   12.1  0.0  1.0	0.0	6.6   0  11 c5t1d0
	0.0  145.1	0.0   12.0  0.0  1.0	0.0	6.8   0  10 c5t2d0
	0.0  358.7	0.0   29.9  0.0  9.4	0.0   26.3   0 100 c5t4d0
	0.0  432.2	0.0   35.8  0.0  2.5	0.0	5.9   0  28 c5t0d0
	0.0  433.2	0.0   35.8  0.0  2.7	0.0	6.1   0  28 c5t1d0
	0.0  434.2	0.0   35.8  0.0  2.7	0.0	6.2   0  28 c5t2d0
	0.0  430.2	0.0   35.7  0.0  9.0	0.0   20.9   0  97 c5t4d0
	0.0   49.9	0.0	0.0  0.0  0.2	0.0	4.1   0   6 c5t0d0
	0.0   81.9	0.0	0.1  0.0  0.3	0.0	3.8   0   8 c5t1d0
	0.0   85.9	0.0	0.1  0.0  0.3	0.0	4.0   0   8 c5t2d0
	0.0   83.9	0.0	0.2  0.0  0.5	0.0	5.6   0  23 c5t4d0
	0.0   53.9	0.0	0.1  0.0  0.2	0.0	3.5   0   5 c5t3d0
	7.0	0.0	0.0	0.0  0.0  0.0	0.0	3.1   0   2 c5t0d0
	7.0	0.0	0.0	0.0  0.0  0.0	0.0	2.9   0   2 c5t1d0
	7.0	0.0	0.0	0.0  0.0  0.0	0.0	2.5   0   2 c5t2d0
  120.9  485.7	0.2   39.9  0.0  3.5	0.0	5.7   0  37 c5t0d0
  120.9  487.7	0.2   40.0  0.0  3.4	0.0	5.6   0  37 c5t1d0
  120.9  486.7	0.2   40.0  0.0  3.4	0.0	5.7   0  37 c5t2d0
	0.0  471.7	0.0   38.8  0.0  7.2	0.0   15.2   0  75 c5t4d0
	0.0  375.0	0.0   31.3  0.0  2.2	0.0	5.8   0  24 c5t0d0
	0.0  374.0	0.0   31.2  0.0  2.3	0.0	6.2   0  24 c5t1d0
	0.0  374.0	0.0   31.2  0.0  2.3	0.0	6.2   0  24 c5t2d0
	0.0  322.1	0.0   26.9  0.0  9.6	0.0   29.9   0 100 c5t4d0
	0.0  609.9	0.0   49.8  0.0  3.4	0.0	5.7   1  38 c5t0d0
	0.0  607.9	0.0   49.8  0.0  3.5	0.0	5.8   1  37 c5t1d0
	0.0  610.9	0.0   49.9  0.0  3.6	0.0	5.9   1  38 c5t2d0
	0.0  605.8	0.0   49.8  0.0  8.0	0.0   13.2   1  87 c5t4d0
	0.0  563.4	0.0   46.5  0.0  3.3	0.0	5.9   1  36 c5t0d0
	0.0  561.4	0.0   46.5  0.0  3.4	0.0	6.1   1  36 c5t1d0
	0.0  559.4	0.0   46.4  0.0  3.4	0.0	6.2   1  36 c5t2d0
	0.0  460.9	0.0   38.2  0.0  9.2	0.0   20.0   0  96 c5t4d0
	0.0  164.3	0.0   10.6  0.0  0.9	0.0	5.5   0  14 c5t0d0
	0.0  239.5	0.0   10.7  0.0  1.2	0.0	4.8   0  18 c5t1d0
	0.0  241.5	0.0   10.8  0.0  1.2	0.0	5.1   0  19 c5t2d0
	0.0  401.8	0.0   24.5  0.0  3.8	0.0	9.5   0  47 c5t4d0
	0.0   51.1	0.0	0.1  0.0  0.2	0.0	3.5   0   5 c5t3d0
	0.0	5.0	0.0	0.0  0.0  0.0	0.0	0.7   0   0 c5t0d0
	0.0	5.0	0.0	0.0  0.0  0.0	0.0	0.7   0   0 c5t1d0
	0.0	5.0	0.0	0.0  0.0  0.0	0.0	0.7   0   0 c5t2d0
	0.0	6.0	0.0	0.0  0.0  0.0	0.0	0.4   0   0 c5t4d0
	0.0   37.9	0.0	0.0  0.0  0.2	0.0	4.7   0   5 c5t0d0
	0.0   43.9	0.0	0.1  0.0  0.2	0.0	5.6   0   6 c5t1d0
	0.0   46.9	0.0	0.1  0.0  0.3	0.0	6.4   0   7 c5t2d0
	0.0   42.9	0.0	0.1  0.0  0.3	0.0	6.6   0   7 c5t4d0
	0.0   48.9	0.0	0.1  0.0  0.2	0.1	3.8   0   6 c5t3d0
^C
$ zpool status tank
  pool: tank
 state: DEGRADED
status: One or more devices has been taken offline by the administrator.
		Sufficient replicas exist for the pool to continue functioning in a
		degraded state.
action: Online the device using 'zpool online' or replace the device with
		'zpool replace'.
 scrub: scrub completed after 0h0m with 0 errors on Sun Jul 25 13:44:02 2010
config:
		tank		DEGRADED	 0	 0	 0
		  raidz1-0  DEGRADED	 0	 0	 0
			c5t2d0  ONLINE	   0	 0	 0
			c5t0d0  ONLINE	   0	 0	 0
			c5t1d0  ONLINE	   0	 0	 0
			c5t4d0  OFFLINE	  0	 0	 0
		Run began: Tue Jul 27 10:42:01 2010
		Record Size 4 KB
		Min process = 5
		Max process = 5
		Children see throughput for  5 initial writers  =  824090.63 KB/sec
		Parent sees throughput for  5 initial writers   =  191510.58 KB/sec
		Min throughput per process					  =  120306.12 KB/sec
		Max throughput per process					  =  201707.50 KB/sec
		Avg throughput per process					  =  164818.13 KB/sec
		Min xfer										=   59684.00 KB
		Children see throughput for  5 rewriters		=  684519.17 KB/sec
		Parent sees throughput for  5 rewriters		 =  206027.82 KB/sec
		Min throughput per process					  =  125154.66 KB/sec
		Max throughput per process					  =  143915.62 KB/sec
		Avg throughput per process					  =  136903.83 KB/sec
		Min xfer										=   87808.00 KB
		Children see throughput for  5 readers		  = 1253449.16 KB/sec
		Parent sees throughput for  5 readers		   = 1230956.67 KB/sec
		Min throughput per process					  =   67375.10 KB/sec
		Max throughput per process					  =  317046.47 KB/sec
		Avg throughput per process					  =  250689.83 KB/sec
		Min xfer										=   22064.00 KB
		Children see throughput for 5 re-readers		= 1925334.93 KB/sec
		Parent sees throughput for 5 re-readers		 = 1886582.70 KB/sec
		Min throughput per process					  =   55774.65 KB/sec
		Max throughput per process					  =  481399.91 KB/sec
		Avg throughput per process					  =  385066.99 KB/sec
		Min xfer										=	9576.00 KB
		Children see throughput for 5 reverse readers   = 1657621.67 KB/sec
		Parent sees throughput for 5 reverse readers	= 1613765.37 KB/sec
		Min throughput per process					  =  113667.48 KB/sec
		Max throughput per process					  =  407724.59 KB/sec
		Avg throughput per process					  =  331524.33 KB/sec
		Min xfer										=   29016.00 KB
		Children see throughput for 5 stride readers	= 1675901.88 KB/sec
		Parent sees throughput for 5 stride readers	 = 1582057.05 KB/sec
		Min throughput per process					  =  195357.84 KB/sec
		Max throughput per process					  =  413063.09 KB/sec
		Avg throughput per process					  =  335180.38 KB/sec
		Min xfer										=   37952.00 KB
		Children see throughput for 5 random readers	= 1281509.39 KB/sec
		Parent sees throughput for 5 random readers	 = 1235974.21 KB/sec
		Min throughput per process					  =  213653.38 KB/sec
		Max throughput per process					  =  297562.00 KB/sec
		Avg throughput per process					  =  256301.88 KB/sec
		Min xfer										=   71388.00 KB
		Children see throughput for 5 mixed workload	= 1141600.07 KB/sec
		Parent sees throughput for 5 mixed workload	 =  311051.36 KB/sec
		Min throughput per process					  =  130590.70 KB/sec
		Max throughput per process					  =  316213.38 KB/sec
		Avg throughput per process					  =  228320.01 KB/sec
		Min xfer										=   43088.00 KB
		Children see throughput for 5 random writers	=  789674.57 KB/sec
		Parent sees throughput for 5 random writers	 =  176409.93 KB/sec
		Min throughput per process					  =   57418.18 KB/sec
		Max throughput per process					  =  211553.20 KB/sec
		Avg throughput per process					  =  157934.91 KB/sec
		Min xfer										=   24908.00 KB
"  Initial write "  824090.63
"		Rewrite "  684519.17
"		   Read " 1253449.16
"		Re-read " 1925334.93
"   Reverse Read " 1657621.67
"	Stride read " 1675901.88
"	Random read " 1281509.39
" Mixed workload " 1141600.07
"   Random write "  789674.57
	0.0	0.1	0.0	0.0  0.0  0.0	0.3	4.3   0   0 c5t0d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.4	4.5   0   0 c5t1d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.5	4.7   0   0 c5t2d0
	0.0	0.1	0.0	0.0  0.0  0.0	0.0   18.9   0   0 c5t4d0
	0.0	0.0	0.0	0.0  0.0  0.0	5.2	5.8   0   0 c5t3d0
	0.0  481.4	0.0   35.7  0.0  2.7	0.0	5.6   0  33 c5t0d0
	0.0  551.3	0.0   35.7  0.0  2.9	0.0	5.3   0  36 c5t1d0
	0.0  547.4	0.0   35.7  0.0  3.0	0.0	5.5   0  36 c5t2d0
	0.0   55.9	0.0	0.2  0.0  0.2	0.0	3.8   0   6 c5t3d0
   78.9  429.3	0.1   35.6  0.0  2.5	0.0	4.9   1  28 c5t0d0
   78.9  430.3	0.1   35.6  0.0  2.7	0.0	5.2   0  29 c5t1d0
   78.9  431.3	0.1   35.6  0.0  2.6	0.0	5.2   0  29 c5t2d0
	0.0 1279.9	0.0  105.4  0.0  7.3	0.0	5.7   1  81 c5t0d0
	0.0 1282.9	0.0  105.4  0.0  7.7	0.0	6.0   1  82 c5t1d0
	0.0 1277.9	0.0  105.3  0.0  7.8	0.0	6.1   1  81 c5t2d0
	0.0  372.1	0.0   24.3  0.0  1.8	0.0	4.8   0  24 c5t0d0
	0.0  407.0	0.0   24.3  0.0  2.0	0.0	4.9   1  26 c5t1d0
	0.0  409.0	0.0   24.4  0.0  2.1	0.0	5.1   1  27 c5t2d0
	0.0   48.9	0.0	0.1  0.0  0.2	0.0	3.3   0   6 c5t3d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0   18.6   0   2 c5t0d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0   15.8   0   2 c5t1d0
	1.0	0.0	0.0	0.0  0.0  0.0	0.0   19.4   0   2 c5t2d0
	0.0   46.6	0.0	0.1  0.0  0.2	0.0	4.1   0   6 c5t3d0
	0.0   54.3	0.0	0.1  0.0  0.2	0.0	4.1   0   6 c5t3d0
	0.0   51.9	0.0	0.1  0.0  0.2	0.0	3.6   0   5 c5t3d0
	0.0   52.3	0.0	0.1  0.0  0.2	0.0	4.1   0   6 c5t3d0
	0.0   52.9	0.0	0.1  0.0  0.2	0.0	4.7   0   7 c5t3d0
	0.0  380.0	0.0   31.1  0.0  2.1	0.0	5.5   0  22 c5t0d0
	0.0  376.0	0.0   30.6  0.0  2.1	0.0	5.7   0  22 c5t1d0
	0.0  317.2	0.0   25.7  0.0  2.1	0.0	6.7   0  22 c5t2d0
	0.0  542.5	0.0   40.2  0.0  2.9	0.0	5.3   0  35 c5t0d0
	0.0  570.5	0.0   40.8  0.0  3.2	0.0	5.6   0  37 c5t1d0
	0.0  625.7	0.0   45.7  0.0  4.0	0.0	6.3   1  47 c5t2d0
	0.0   56.2	0.0	0.1  0.0  0.2	0.0	3.6   0   6 c5t3d0
	0.0  673.5	0.0   54.2  0.0  3.8	0.0	5.6   1  40 c5t0d0
	0.0  677.6	0.0   54.4  0.0  3.8	0.0	5.6   1  40 c5t1d0
	0.0  661.4	0.0   54.3  0.0  4.1	0.0	6.2   1  43 c5t2d0
	0.0 1328.8	0.0  109.9  0.0  7.6	0.0	5.7   1  84 c5t0d0
	0.0 1330.8	0.0  109.7  0.0  7.9	0.0	5.9   1  83 c5t1d0
	0.0 1327.8	0.0  109.9  0.0  8.1	0.0	6.1   2  85 c5t2d0
	0.0  253.9	0.0   14.5  0.0  1.2	0.0	4.6   0  18 c5t0d0
	0.0  286.7	0.0   14.6  0.0  1.4	0.0	4.9   0  21 c5t1d0
	0.0  287.7	0.0   14.4  0.0  1.5	0.0	5.2   0  21 c5t2d0
	0.0   56.5	0.0	0.1  0.0  0.2	0.0	4.3   0   6 c5t3d0
	0.0   53.9	0.0	0.1  0.0  0.2	0.0	4.1   0   6 c5t3d0
	0.0   37.4	0.0	0.0  0.0  0.2	0.0	4.4   0   5 c5t0d0
	0.0   43.4	0.0	0.1  0.0  0.2	0.0	5.6   0   7 c5t1d0
	0.0   45.5	0.0	0.1  0.0  0.3	0.0	6.2   0   7 c5t2d0
^C
