NukeJockey
HAF X Build Log
just lift those cases alot,then you dont need to go to the gym...
haha, its not so bad.
The 932 was heavier than the X and so was the Raven.
I have a 932, thats why I have "The Guns from Hell" on each arm. lol
Bang Bang
thats good so i wont break my back lifting it....ill just strain some muscules instead....
Edited by jdog
Just ordered the following from The Kool Room and PCCG.
The Kool Room
ENZOTECH ROTARY 90 BARB  x4 	$10.40
Primoflex Clear 1/2ID 3/4OD  x15(feet) 	$3.30
MAYHEM CANDY RED 5ml 	MAYHEM CANDY RED 5ml 	3 	$7.00
KoolRoom Silver 									  x1		  $15.00
Lamptron 7 Spread Lazer Led RED				  x1 	$9.00
Lamptron Dual CCFL 300mm RED 	 	x1 	$12.50
ENZOTECH HIGH FLOW BARB 	 	x6 	$4.40
PCCG
 5 		  Scythe 120mm Gentle Typhoon 1850rpm Fan 	$120.00
  1 		  EK-CoolStream RAD XT 360 	$95.00
  1 		  NZXT Sentry 2 LCD Fan Controller 	$49.00
  1 		  EK-Multioption RES X2 - 250 Advanced 	$69.00
  2 		  Swiftech MCW80 Universal GPU Waterblock 	$118.00
So look for some updates to this build log in the near future!
Edited by nukejockey
Nice, looking forward to some more piccy's. And just a quick question: Are gentle typhoon one of the best? I also heard the high end S-Flex range is as good and better then the typhoons for around the same? Anyway you probably wouldn't notice a temp difference.
Better put some pics up Nukey
GTs are quieter than the S-Flexs and most Scythe fans are hard to get atm so you take what you can.
Yeah I'll get some pics up, probably wont get around to until after Xmas though!
Should have a new DSLR by then aswell, so will get some nice piccys going.
Dasa has informed me that the GTs are louder than S-Flexs but the GTs move more air per db than any other fan :P
nice pics.
its good to see someone else taking advantage of all the space in these haf cases and mounting a couple of rads.
although im afraid i need something bigger im now up to 7 hdd's and a ssd as well as my w/c loop.
i was thinking of a lian-li 343b theyre huge.
+1 wish we all lived closer....... modathon!!!!
Ooh, nice order! Should be good to see how yours goes (since it's looking like you'll be finished far before me :P).
*edit*
Actually, what DSLR? :D
Will be great to see how you go nukey, mine was alot of fun to put together.
By the way, it's a bitch, but you NEED a G80 kit for both blocks, they don't ship with one normally
Yeah, PCCG's description is wrong. See the compatibility chart:
http://www.swiftnets.com/products/mcw80.asp
They should be ok with you adding the mounting plates to the order though.
*edit*
"Finally, to guarantee a safe and stable assembly, a GPU stiffening frame (partl #GTX400) is included that replaces the frame built into the stock cooling solution. This bracket is important to maintain the PCB flat in the immediate area surrounding the GPU. The bracket also serves as an anchor to install the MCW80 waterblock."
http://www.guru3d.com/news/swiftech-mcw80-...tx-480-and-470/
Sounds like you'll need one for it to work ok, and I can't find them for sale in Australia. Might wanna check with PCCG first before comitting to them.
Well it was my fuckup that saved me..
I had my mcw60 for yonks, and forgot the kit on it.
So I ordered a G80 for it, and ordered a MCW80 on it's own.
Turns out, my mcw80 comes without one, cannot mount to 480 without it, and my MCW60 was already using an ancient G80 kit :P I just took no notice previously.
So I had 2 G80 kits, luckily. He's pretty rooted without them
Just ordered 2 of the G80 backplates from Egay, should get them before Xmas hopefully.
Frunjy - Canon EOS 500D, I've been wanting to get into photography for a while but haven't been able to afford it, until now ^.^
Just Added 2x 92mm Scythe S-Flex 2000rpm fans to the order, they're for sitting over the GPUs to passively cool them, hopefully I can find a way to mount them without them looking dodgy.
I reckon you can cable-tie the fans to the end of the PCB through those round holes at all four corners of the board (most GPUs have them). You can see them in this shot:
http://www.atomicmpc.com.au/Gallery/170368...y-guide.aspx/20
I laughed when I saw you said 'passively cooled', passive generally means quiet :P But then I realised you just meant you weren't bothering with heatsinks and the like. Should look pretty awesome with the scythes though, especially if you get four 92mm fan grilles, spray paint them black, and attach them to both sides of the fans!
Brain fart! I'd just woken up lol, it should read "They're for sitting over the GTX480s as I can't passively cool them" -.-
/facepalm
this is going to be very very awesome man. sucks using egay! Hopefully I find the time to redo my watercooling and put it in my new lian li case ;) though, I might just get a 360 rad and sell my other one :) also, saving for a 580 atm!
cant wait to see how the cooling for the 480's works out dude, like the idea of using the 92mm fans.
Just a quick little update, my order from PCCG arrived last week and my order from The Koolroom arrived today.
2 Swiftech MCW80 GPU blocks.
An EK 360mm rad.
Ek Res.
Heaps of 90 degree angled barbs and straight barbs (only 1 of each in pics, but i have a whole bag full)
Red LED "Laser" lights for the case.
Another Red Cold Cathode (my other ones are orange, hoping the new one is actually red)
3 Red Dye bombs (I ordered 1 :s)
5 Scythe GT 1850rpm fans
A NZXT touch screen fan control (I already have 1, but with the addition of 3 new fans In the case, I may aswell use 1 for the rad fans and 1 for the case fans)
Roughly 5 metres of clear tubing.
Stay tuned for the actual build log (hopefully) next week.
Sorry for the shitty photos, don't have a decent camera yet.
