Trekker
z5500 d problems
i was playing around with a few things..
notice that on my input part on the little screen says stereo 1
but i have the 3 cords in the back in..
i cannot remember should it have 5.1 or something .. sound card is.. and is working find tested with 2 sound cards.
i have no 5.1
can someone take a pick of theres if they are using the 3 cords and in 5.1 sound thanks
does all of that..
i had a sound card die on me..
had a then was running of on board now back to a xfi..
but on the input option on the screen on the control unit only shows..
optical
coaxal
setero 1
stereo 2
stereo 3
i have clickon on everything. that i know of ..was wondering if my z5500 is comething wrong.
Behind the controller unit...
make sure the switch is set to 6 channel mode.
Not at home so I can't check mine, but IIRC the '6 Channel Direct' option should then replace the stereo input modes or appear after the stereo 3 option.
Edited by mark84
Don't go to the xfi control panel go to windows control panel then sound etc,
also make sure all other audio drivers are uninstalled and that yo have a fresh install of the xfi drivers.
lol, I was going to post that if you hadnt :)
considering that windows will down mix to stereo and the xfi will up mix to 5.1 what is the point of that switch?
Three separate stereo sources can be plugged in and switched between. Switch on the Dolby Pro Logic II and you can listen in 'surround sound' from up to three devices. Perhaps handy for multiple devices in a lounge room setting.
