3dmark master
maybe its time to think about adding crysis 2 results to the list
http://www.overclock.net/t/991016/crysis-2...ew-dx11-version
probably with the third timedemo or like stalker add together the average of all three
the timedemoes seem a little easy going though i was getting ~70fps with one gpu at 1920x1080 and enabling aa didnt make much difference
I got a HD 5870 yesterday, so while it is rather old compared to what most of you guys are running, I'll at least be able to run all the benchmarks now. Plus it'll be interesting to see how newer drivers effect this older card
still only using 580 sli but heres mine 3dmark 11
p13480
http://www.3dmark.com/3dm11/4922541
i7 3930k @ 4400mhz,re4, 580gtx dcu11 sli @897mhz core, 16gb ripjaw z 2133mhz,wc,xspc h1+
vantage:p46094
http://www.3dmark.com/3dmv/4401941
i7 3930k @ 4400mhz,re4, 580gtx dcu11 sli @832mhz core, 16gb ripjaw z 2133mhz, wc, xspc h1+
thanx:)
Edited by asus_gtx580sli
just installed a his 7970
gave it a run on stock cooling at 1150\7000 with my old 7970 and the 2600k at 4.3
P16152 //www.3dmark.com/3dm11/5182706
not a bad start
need to rip my loop apart and make another copper shim to get it on water
seems i need my old card in the first pci-e slot as it has all the dp ports for my monitors and they dont seem to work when the card is in the second slot with crossfire enabled
due to it being triple slot i will have to take off some more of its stock hs to make it fit
edit looks like the new cards limit on air are not that different from the old card on water with both topping out at ~1200mhz although the new card needs the v set higher it seems to have a large amount of v drop if the software is to be believed
it will be interesting to see whether or not it responds well to extra v once on water
Wow some awesome scores there Lads!!
new build and first run with a mild OC on the CPU and GPU
3dmark 11 - Single NvidiA GPU
P5741 DishD - PII 955BE@3.8GHz(a) - GTX570@825/1980(a) - Link
I think that makes it the #1 GTX570 and that was with stock volts, i hope to tweak it a fair bit more, same with the CPU @ stock volts
Edited by dishd
Very nice work there DishD. It's unlikely I'll be able to do it, but you're my benchmark now :-P
EDIT: I just ran through mine, and I doubt I'll ever be able to compete with my hardware
This is at stock
3DMark 11 - Single GPU ATI
P4341 nobody813 - X6 1090T@3.2GHz (a) - HD5870@850/1200 (a)
I will give it another run possibly later today
Edited by nobody813
Set CPU up to 4.0Ghz ;)
3dmark11 - Single Nvidia GPU
P5789 DishD - PII 955BE@4.0Ghz(a) - GTX570@825/1980(a) - Link
DishD, your graphics driver is not approved :-/
yer 310 is still in Beta :(
Unigine Heaven 3.0
Single GPU
1215 DishD PII 955BE@4.0Ghz(a) - GTX570@800/1975(a)
Edited by dishd
some 7970 dual gpu scores
cranked up the cpu clock to see how they go
P17703 Dasa i7 2600K@5050MHz(w) - CF 7970@1225/1850(w\a)
can probably reach 18k with a little work but these cards are not exactly good overclockers so im not expecting much more than that
although i still need to get the new card on water to know what it is really capable of
infront of xyzzy frobozz for now which is strangely satisfying :) even if it doesnt last
heaven
3799 Dasa i7 2600K@4300MHz(w) - CF 7970@1200/1800(w\a)
Guest xyzzy frobozz
P17703 Dasa i7 2600K@5050MHz(w) - CF 7970DC2T@1225/1850(w\a)
heaven
3799 Dasa i7 2600K@4300MHz(w) - CF 7970DC2T@1200/1800(w\a)
Right!
Back to the clocks then!
Right!
hehe good stuff :)
Nice work Dasa, i've been thinking about grabbing another 7970 too but I haven't really needed it for anything recently.. I might wait another 6 months or so and see how much cheaper they get if/when 8970 comes out.
It's surprising the way total scores are calculated, so I mostly just look at graphics score for multi card, 22k is very nice :)
fair plan and what i was intending to do till i grabbed more monitors and since i wanted farcry 3 anyway that made the upgrade only $350
although they probably wont get much cheaper they may drop a bit more
you may decide to sell the 7970 and grab a 8970 ;)
Guest xyzzy frobozz
I have really fond memories of the 5870s!
Haha yeah. I really should look and see how well everyone here went with these, and I'll hopefully get a few tips along the way :-P
P5993 DishD - PII 955BE@4.0Ghz(a) - GTX570@875/2000(a) Link
Yes still with 310 beta drivers, but a nice bump in score with a slight bump in GPU volts.
Edit:
P6109 DishD - PII 955BE@4.0Ghz(a) - GTX570@900/2010(a) Link
Edited by dishd
Now with FM Approved drivers
P6228 DishD - PII 955BE@4.0Ghz(a) - GTX570@930/2030(a) Link
Edited by dishd
heaven
Been gone for awhile nice to see some new runs. Dasa nice freaking scores, can you break 18k? Did you get on water? Maybe try to flop the slots? I bet you can get it, your not far at all.
maybe
not on water yet snuck a post into an inapropriate place with resons why http://forums.atomicmpc.com.au/index.php?s...0&start=100
a pic and some info on upgrade plans http://forums.atomicmpc.com.au/index.php?s...733&st=1340
flop the slots? old card is in the primary slot now as it has 3 dp ports that i need
Gotcha didnt notice the ports, sometimes when I switch slots with the fastest card as the primary gives a higher score.
interesting to know may be worth a try if the new card ends up overclocking better
just got a note from pccg to say i have a replacement psu on the way
