3dmark master
^Nice results, I bet you could get a higher score around 15k with a bit more OC
Thanks gamble :-) Started playing around with some voltage tweaks, so should see some improved results in the near future. Still haven't hit the 15k mark yet.
Upped the core volt to 1.2 and the mem volt to 1.55 and got this:
3DMark 11
Dual GPU - ATI
P14799 - i7 3770K @ 4.5GHz (a) - 2x 7950 @ 1100/1500 (a)
The card is still rock stable and the temps are not a problem, should be some more o/c to be had!
Just did an Extreme run with the above settings and got x5668:
3DMark 11 Extreme result
Hahaha, success! Just cracked 15k :-)
3DMark 11
Dual GPU - ATI
P15226 - i7 3770K @ 4.5GHz (a) - 2x 7950 @ 1150/1550 (a)
3DMark 11 result
Edited by Kenno
P14822 - Gamble - 3770k 5.0ghz / EVGA SC GTX Titan 1215c, 6200m
Kenno - I tried to beat you but that is the best I can do lol. I tried to beat Dasa's score in Valley and Heaven too, but that is all she's got.
Im using a custom bios allowing me to clock up to around 1215mhz in Valley and Heaven with the memory at 6800mhz. 3dmark11 is much more touchy with memory and can only go up to 6200mhz, it also downclocks in spots with 3dmark11 on the core since its hitting 115% on the power. I probably deleted 30 3dmark, Heaven and Valley saves each, to get to this. All ran at 5ghz on the cpu.
Edited by gamble
i know your pushing a lot harder than me but for a single gpu to get so close to 7970 cf is rather awesome nice work
10358 - Gamble - 3770k 5.0ghz / EVGA SC GTX Titan 1202c, 6400m
I ran it at 1202mhz, must have forgot to raise it. Might try it again. CPU get really hot at 5ghz on air! Have to be careful. Anyone else post some results of FireStrike, I'd like to compare.
Edited by gamble
tried to run it at 5ghz but after saving and exiting bios i get into windows to find it still at 4.3ghz although the v had gone up to 1.5v as requested
look back in bios yep 5ghz try set 4.6ghz in windows with software hard lock
just a few days ago i was running it stable at 4.7ghz 1.375v now the bios has gone and spat the dummy again
P15307 - Gamble - 3770k 5.0ghz / EVGA SC GTX Titan 1202c, 6600m
New bios, Im on like my 20th one lol. I have a bios tweaker and have been experimenting some.
Edit:
P15379 Gamble - 3770k 5.0ghz / EVGA SC GTX Titan 1215c, 6600m
^Just passed my best with SLI GTX 670 overclocked by 11 points. Note, I had a 2500k then running @ 5ghz but with blck used some. Graphics score for SLI GTX 670 was 20025, GTX Titan is 17248.
Edited by gamble
here you go gamble for comparison
2600k@5ghz
2133 9-10-10-24-1t
single 7970@1200\7200 1200mv
Ice Storm http://www.3dmark.com/is/372765
Score 171574
Graphics Score 346002
Physics Score 62065
Cloud Gate http://www.3dmark.com/cg/335076
Score 27052
Graphics Score 58077
Physics Score 9427
Fire Strike http://www.3dmark.com/fs/3489768
Score 8416
Graphics Score 9327
Physics Score 12810
Combined Score 3747
fire strike detailed scores
gamble
3DMark Score10358 3DMarks Graphics Score11815 Physics Score12406 Combined Score4768 Graphics Test 156.6 FPS Graphics Test 247.0 FPS Physics Test39.4 FPS Combined Test22.2 FPS
dasa
3DMark Score8416 3DMarks Graphics Score9327 Physics Score12810 Combined Score3747 Graphics Test 143.7 FPS Graphics Test 237.8 FPS Physics Test40.7 FPS Combined Test17.4 FPS
my cpu actually seems a little faster maybe thanks to the ram
Awesome thanks Dasa, dam good score. Can you run one more test with both cards at stock, cpu and ram at the same as above?
it seems im getting some variance in results and fire strike graphic test 2 is scoring much lower than it has in the past
ice storm and cloud gate seem consistent though
ran the gpu at 7970 ghz speeds 1100\6000
Ice Storm Score 188927 Graphics Score 444776 Physics Score 62698 http://www.3dmark.com/is/375813
Cloud Gate Score 32173 Graphics Score 103586 Physics Score 9427 http://www.3dmark.com/cg/337753
first run was with 104.2 bclk x48 second was at 100x50 first run for the above tests was faster but not with firestrike although the variance seems to be on the gpu side
Fire Strike Score 10168 Graphics Score 13977 Physics Score 12667 Combined Score 3045 http://www.3dmark.com/fs/351692
Fire Strike Score 10494 Graphics Score 13888 Physics Score 12550 Combined Score 3409 http://www.3dmark.com/fs/351656
here is a old run at 4.3ghz ht off and the gpu clocked 1050\1400 graphics test 2 and combined test are higher but the rest are lower
Fire Strike Score 10803 Graphics Score 15215 Physics Score 7883 Combined Score 4125 http://www.3dmark.com/fs/54350
maybe a problem with 13.3 beta3 and crossfire i guess as the 13.3 beta3 seems to have improved single card performance from what i can find
I really appreciate you posting that info. I was trying to see if an OC Titan could possibly match stock CF Hd 7970s but dont look like that could happen unless maybe with another 100-200mhz on the core. Theres some hard mods but the vrms appear weak on these.
im enjoying myself aslong as my cpu doesnt play up due to the 1.5v im feeding it
looks like you have beaten 7970 at the original reference clocks in 3dm11 http://www.3dmark.com/3dm11/6363126
2600k@5ghz 48x104.2
2222mhz 9-10-10-24-1t latency limit 5
I apologise for my absence, I've been in a busy and hectic time in my life recently, I've given Gamble the password to the account so he can also update while I'm not so active.
Thanks morgoth and hope to see you overclocking here again soon!
Im going to add a few benchmarks and update here in the next few weeks. Any benchmark additions/suggestions welcome!
Updated to post #442. Will add more within the next week. Some have updated scores later than #442.
I think we should add:
Unigine Valley 1.0 - Extreme HD Preset
Catzilla - When officially released
Crysis 2 - Maybe?
3dMark - FireStorm
Also, if you upgrade to a new card, Ill keep your old card score for reference to others.
Thanks!
EDIT:
Updated! Still need some FireStrike and Valley 1.0 runs!
Will update every other week or as needed!
Edited by gamble
So yeah the 1.1 patch for 3DMark finally gave us SLI guys a proper reflection of performance vs AMDs cards.
*edited the correct format
Firestrike
Single
P3383 Modzy - 2500k 4.6ghz(W) / EVGA GTX460 1Gb 980mhz/2300mhz(A) - 3DMark
SLI
P5205 Modzy - 2500k 4.6ghz(W) / 2x EVGA GTX460 1Gb 980mhz/2320mhz(A) - 3DMark
P5380 Modzy - 2500k 4.7ghz(W) / 2x EVGA GTX460 1Gb 980mhz/2300mhz(A) - 3DMark
Managed to get my second card much closer to my main card for the first time. #1 @980/2300 @ 1.087v, #2 @970/2275 @1.150v. Previously i was limited to 930/2100 on the #2 card due to overheating when upping the voltage above the normal vcap. This time i opened my window and forces tassies cold winter air into the case. haha that fixed it!
Edited by Modz
Great, good runs guys, will update here after we have a few more runs! Please use the format like Nuke! ^^
I'm also up for adding Metro last light benchmark if it gets enough popularity.
