Bolter01 0 Posted April 10, 2011 Got any pic's of your RIG? I'd like to see your "loop'n'blocks" Share this post Link to post Share on other sites
Dasa 289 Posted April 11, 2011 (edited) found my crysis disk 73.549 Dasa i7 2600K@4.48GHz(w) - SLI GTX480@900/2050(w) heaven 2102 Dasa - i7 2600K@4.48GHz(w) - SLI GTX480@925/21113(w) Edited April 11, 2011 by Dasa Share this post Link to post Share on other sites
smakme7757 41 Posted April 11, 2011 found my crysis disk 73.549 Dasa i7 2600K@4.48GHz(w) - SLI GTX480@900/2050(w) heaven 2102 Dasa - i7 2600K@4.48GHz(w) - SLI GTX480@925/21113(w) Damn nice FPS in Crysis mate top job! Nice heaven score as well! Share this post Link to post Share on other sites
philo-sofa 0 Posted April 11, 2011 @ Bolter - cry havoc and let slip the red dogs of war! All updated! Note: Philo, your heaven run has no AA, it needs to be 4x On a related note, oops sorry and lol. Will have to find some time to re-bench it seems... Share this post Link to post Share on other sites
Dasa 289 Posted April 11, 2011 found my crysis disk 73.549 Dasa i7 2600K@4.48GHz(w) - SLI GTX480@900/2050(w) heaven 2102 Dasa - i7 2600K@4.48GHz(w) - SLI GTX480@925/21113(w) Damn nice FPS in Crysis mate top job! Nice heaven score as well! ta im hoping to get near 80fps in crysis soon its nice to see this thread progressing so well Share this post Link to post Share on other sites
smakme7757 41 Posted April 11, 2011 found my crysis disk 73.549 Dasa i7 2600K@4.48GHz(w) - SLI GTX480@900/2050(w) heaven 2102 Dasa - i7 2600K@4.48GHz(w) - SLI GTX480@925/21113(w) Damn nice FPS in Crysis mate top job! Nice heaven score as well! ta im hoping to get near 80fps in crysis soon its nice to see this thread progressing so well It's progressing very well. I've sent my motherboard back and i'm awaiting the B3 in return so i can't do much until then. Share this post Link to post Share on other sites
Dasa 289 Posted April 11, 2011 It's progressing very well. I've sent my motherboard back and i'm awaiting the B3 in return so i can't do much until then.ah nice i need to do the same somedaywho knows maybe they will make another minor revision i may just keep this twitchy bugger a while longer and maybe i will find a point where i could live without it for a week or so :) Share this post Link to post Share on other sites
supam 0 Posted April 12, 2011 Got any pic's of your RIG? I'd like to see your "loop'n'blocks" http://forums.atomicmpc.com.au/index.php?s...st&p=832307 best i can do, working bush today. Blocks are all EK blocks, rad is a xspc 480, and i've got the integrated xspc laing pump dual bay res. I like the idea of the pump/res combo but due to the design it took like 2 days to bleed the lines. My UD7 is also a pain. Doesn't like cold boots despite being turned well back from what is prime stable. Share this post Link to post Share on other sites
smakme7757 41 Posted April 12, 2011 My UD7 is also a pain. Doesn't like cold boots despite being turned well back from what is prime stable. What BIOS are you using? F7 was the most stable for me and i never got any issues after setting my overclock. F8 has also been released which might even improve on F7...Neither support PLL overvoltage though if you need that. Share this post Link to post Share on other sites
supam 0 Posted April 12, 2011 (edited) My UD7 is also a pain. Doesn't like cold boots despite being turned well back from what is prime stable. What BIOS are you using? F7 was the most stable for me and i never got any issues after setting my overclock. F8 has also been released which might even improve on F7...Neither support PLL overvoltage though if you need that. it's a b3 board, different bios. F2 bios, I tried the F3 beta bios but it was worse. Just checked and an offical F3 has been release, I might give it a go. The description of the F3 bios is "Solve press reset button cause system abnormal" so if my Engrish deciphering is right it might address my problem ;) Edited April 12, 2011 by supam Share this post Link to post Share on other sites
NukeJockey 4 Posted April 12, 2011 Got any pic's of your RIG? I'd like to see your "loop'n'blocks" http://forums.atomicmpc.com.au/index.php?s...st&p=832307 best i can do, working bush today. Blocks are all EK blocks, rad is a xspc 480, and i've got the integrated xspc laing pump dual bay res. I like the idea of the pump/res combo but due to the design it took like 2 days to bleed the lines. My UD7 is also a pain. Doesn't like cold boots despite being turned well back from what is prime stable. Mine took less than 12 hours, using the dual bay res with a DDC and an XSPC 240 and an XSPC 360, it was fantastic. Share this post Link to post Share on other sites
supam 0 Posted April 12, 2011 Got any pic's of your RIG? I'd like to see your "loop'n'blocks" http://forums.atomicmpc.com.au/index.php?s...st&p=832307 best i can do, working bush today. Blocks are all EK blocks, rad is a xspc 480, and i've got the integrated xspc laing pump dual bay res. I like the idea of the pump/res combo but due to the design it took like 2 days to bleed the lines. My UD7 is also a pain. Doesn't like cold boots despite being turned well back from what is prime stable. Mine took less than 12 hours, using the dual bay res with a DDC and an XSPC 240 and an XSPC 360, it was fantastic. With this? http://www.xs-pc.com/products/laing-pump-t...r-for-laing-d5/ I'm very surprised because that internal inlet tube is so close to the pump there isn't time for bubbles to rise. Share this post Link to post Share on other sites
NukeJockey 4 Posted April 12, 2011 Nah its a DDC, similar setup to that dual bay res though (I accidentally purchased one of those AGES ago when I meant to just get the dual bay res without pump mounts) theres slightly more room in the DDC bay res though. Share this post Link to post Share on other sites
supam 0 Posted April 12, 2011 (edited) Nah its a DDC, similar setup to that dual bay res though (I accidentally purchased one of those AGES ago when I meant to just get the dual bay res without pump mounts) theres slightly more room in the DDC bay res though. The lower flowrate would make it easier to bleed. I see it still has the internal inlet tube. Mine is also the older revision that doesnt have variable speed control which would make it simpler. Edited April 12, 2011 by supam Share this post Link to post Share on other sites
smakme7757 41 Posted April 12, 2011 Mine bleeds surprisingly quickly actually. But my loop is shoter and has less bits and pieces as i'm not running SLI. Share this post Link to post Share on other sites
Bolter01 0 Posted April 13, 2011 supam - yep that's my Res as well, ur right about the bubbles and inlet, so to start with I sliced a piece of tubing (about 5cm) long length ways and slipped it in side the res to "catch the bubbles" untill most were out. After that it eventually bleeds itself. Share this post Link to post Share on other sites
3dmark master 0 Posted April 14, 2011 Updated! I need to do some benching above 800MHz on these 480's! Share this post Link to post Share on other sites
Morgoth 15 Posted April 14, 2011 Back on my own account now! I've got an MCP355 coming in the mail, see if it's better in this 2 rad 3 block loop than the D5, also I have two more MCW60's, gonna replace my MCW80 on a card Share this post Link to post Share on other sites
NukeJockey 4 Posted April 14, 2011 Back on my own account now! I've got an MCP355 coming in the mail, see if it's better in this 2 rad 3 block loop than the D5, also I have two more MCW60's, gonna replace my MCW80 on a card I can't really check my flow rate, but it seems pretty good with the Laing DDC 3.25 considering I'm using 3 of the most restrictive blocks on the market (Apogee XT and 2 MCW80s) Share this post Link to post Share on other sites
nobody813 17 Posted April 14, 2011 Do you reckon I could bench both my desktop and laptop? Or would that infringe on the 1 per... rule? Share this post Link to post Share on other sites
Morgoth 15 Posted April 14, 2011 You can have both, as long as they are in different class. So you should be fine Share this post Link to post Share on other sites
Jeruselem 794 Posted April 15, 2011 Hey, would it too troublesome to have a netbook section? I know netbook are horrible with these benchmarks but the one I have coming is not your normal netbook. Share this post Link to post Share on other sites
nobody813 17 Posted April 15, 2011 Hey, would it too troublesome to have a netbook section? I know netbook are horrible with these benchmarks but the one I have coming is not your normal netbook.I reckon a modile sction would be good Share this post Link to post Share on other sites
Morgoth 15 Posted April 15, 2011 (edited) Well I decided not to split it all up too much, I mean having 20 classes and 2 entries each is no fun, but like is done with 3dmark, the result will have a label such as #1 Netbook Edited April 15, 2011 by Morgoth Share this post Link to post Share on other sites
Jeruselem 794 Posted April 15, 2011 Well I decided not to split it all up too much, I mean having 20 classes and 2 entries each is no fun, but like is done with 3dmark, the result will have a label such as #1 Netbook That's fine then. I expect it to be on bottom of the list somewhere :D Share this post Link to post Share on other sites
