3dmark master
So, I sold the RX 56 only because of the crazy prices they are going for used. I bought a Asus Strix GTX 1080Ti OC from that which was nearly a wash, I think I paid $10 bucks after fees on ebay. Few results below, I dont have my cpu clocked up but at my daily 4ghz. There is one bad, well kinda strange thing about this card... It clocks without changing anything up to 1924-1949mhz at stock. If I up the power limit to 120% it stays closer to the 1949mhz and if I up the voltage all the way up to 1.093v it usually is around 1962 to 1949mhz. Great right, should OC like a boss?? Nope! I can only get about +20 from there and will not hit 2000mhz. Now, I really dont mind since it is a high OC right from the box without having to do anything but its strange that I cant really push it anymore and really it is not even worth running it at +20... The cooler is unreal though. It runs up to 40% at the highest I have seen, cant hear it at all and has not hit over 69c yet even when gaming or benching. Still playing with the ram but it hit 12000 no problem and wanted to run some benches. I dont think Ill be able to catch Mark84 :( even if I push the cpu and ram more but still happy with the results over the RX 56.. Still looking at Dasa scores its hard to believe he pushed his to those great scores too considering its a GTX 1070. Ill probably try to up the cpu some just because Id like to hit 20k/10k in FS/TimeSpy.
FireStrike: 19606 - https://www.3dmark.com/fs/14708608
TimeSpy: 9837 - https://www.3dmark.com/spy/3146034
For those curious on Superposition, I ran this with the RX 56 and RX 64 bios for the below:
Performance - 1080p Extreme preset - DirectX
RX56: 3299
RX56(RX64 bios): 3809
1080ti Ram OC: 6052
1080ti: 5840
Edited by gamble
wonder why ryzen does so badly in the combined score my 6700k is 60% faster yet your 30% faster in both gpu and physic tests
sure its probably single threaded but still the difference shouldn't be that much
Maybe because yours is running 800mhz higher... Still piss poor combined score for sure. There's a bios update for my board but they took out OC option for some reason and supposed another bios coming to fix vulnerability.
Edit: Found this similar setup, combined score looks much better than mine but looks like he/she ran near the same clocks but higher ram frequency... Maybe I'll try to flash the bios on mb again, possibly it didn't take well. https://www.3dmark.com/fs/13060141
Edited by gamble
what speed is your ram running? sora3 managed .11fps more than you in the combined test with 2666 ram
You need to update your bio now ;)
Currently, at 2933... Looking at previous scores I remember saying "I dont know how I got this score" with the RX 56 as it was much higher than most of my other scores even rerunning over and over trying to reproduce. But, my combined score was high and other runs it was low... strange stuff, Ill dig in more soon.
Yea will update sig now thanks for the reminder!
Thx Dasa, it has to be something with that. I installed Ryzen power plan last year and when I looked it wasn't even there anymore but there has been some major updates lately. When I re-download it, it wouldn't downclock the cores on either Ryzen balance or performance modes. Only win 10 balance would drop the clocks down when not being used. Looking at resource management I do not have any parked cores. I ran out of time but it just seems like poor optimization on Futuremark side but to be fair it's been out a long time now. Looking at all the charts if I put parked at 50% it should yield better results... I need to read more since I'm still confused on how it work and why.
like you say there has been a lot of updates that were supposed to fix a lot of these issues so that link i provided may not be relevant anymore but his scores do seem to be in the ballpark of where you are and where you should be
To be honest, I have no idea why now I can get nearly 21k with the exact same setting.... I changed nothing in the bios. The card is running at the clocks as before. My combined score jumped to 6767... I do not see an option for parked cores and how to set this as the screenshots showed in those posts. I can set min/max on the processors though. Using Ryzen balance would fail when I get to the physic test, the same is true using win10 High performance. Then I went back to win10 balanced and bam, 21k score. Possibly, it was just luck of the core threads and where they landed. Still think for a benching program they would try to make this better for all cpus.
20929 - https://www.3dmark.com/3dm/24679858?
compare - https://www.3dmark.com/compare/fs/14708608/fs/14723706#
Ill give it a few more runs to see if this is repeatable.
Edit: No, it is not repeatable meaning 50% of the time it will run great and other times I will get my 1st score with the same combined.... so annoying but glad you mentioned.
Edited by gamble
guess that could be it with the two groups of cores and the high latency interface between them
I opened a ticket with support, just to ask, below is their official rep reply. Basically, what we thought on the core threads and how win10 assigned them can impact performance:
Subject: Ryzen and Combined Score Inconsistent
Me:
"FireStrike with Ryzen is inconsistent on combined score. Same setting but will yield different results each time I run this. Several others in forums have noted the same issue. It seems like FS is not optimized for Ryzen. Please let me know when the patch will come out to address this. Ryzen2 coming soon so everyone will be running these benchmarks."
Rep:
"More like Ryzen is not optimized for all applications. This is how Ryzen works on any number of games etc. We have no plans to change the test in any way as changing it would invalidate all existing benchmark scores. It is quite accurate test for older DX11 games that do not have specific code paths for Ryzen - basically the result depends on which core Windows happens to put the benchmark vs. where video driver process is. Core-to-Core communication can be fast or slow, depending on that.
Beyond that, Time Spy and Time Spy Extreme are better tests for modern hardware."
Anyone using Superposition benchmark? Ive been using Performance - 1080p Extreme preset - DirectX.
Edited by gamble
gave it a quick run
Superposition_Benchmark_v1.0_4012_151630
2.9 Gig download - but they do have a torrent which is handy. Might queue it up overnight.
Posted (edited)
Basemark GPU
Vulkan 5712
OpenGL bc7 5781
OpenGL astc 5681
OpenGL etc2 5558
Basemark Web
desktop using Windows 10.0
Firefox 61.0 score: 829.87
CSS Capabilities
56.79%
HTML5 Capabilities
92.07%
Page Load and Responsiveness Capabilities
91.13%
Resize Capabilities
75.97%
system fairly much same as tag except cpu at 4.5ghz ram at 3733c16
Got it here, will install later and give a run.
Posted (edited)
running at stock on cpu, using Official Test:
Vulkan: 9132
OpenGL bc7: 4388
OpenGL astc: 4404
OpenGL etc2: 4369
Basemark Web:
desktop using Windows 10.0 with Chrome 67.0.3396.87 score:848.04
CSS Capabilities57.75%
HTML5 Capabilities96.58%
Page Load and Responsiveness Capabilities89.39%
Resize Capabilities75.97%
kinda strange results looking at Dasa's. Ill set my cpu to 4ghz and try again.
Edit:
@4ghz
Vulkan: 8921
OpenGL bc7: 5513
OpenGL astc: 5637
OpenGL etc2: 5522
Edited by gamble
I feel ripped off considering the 2.8 Gig download. The actual test is just some slideshow, and the experience mode is short and lame.
For some reason the compare on powerboard function just opens up a webpage that's blank. Maybe it's an OS thing.
i7-4790 24 Gig, Win7 Ultimate, GTX 960
Overall score 1821
yeah i was a bit disappointed to
i gave this photshop benchmark a few runs
https://www.pugetsystems.com/labs/articles/Puget-Systems-Adobe-Photoshop-CC-Benchmark-1132/
the gains from ram are not as big as some other software but 3200 ram still looks to be decent value for the performance boost it provides
2133c15 to 3866c16 percentage increase
Overall Score 9.5%
General Score 14.5%
Filter Score 12.2%
Photomerge Score 4.3%
GPU Score 19%
eb106f9873cf97cffa0485df9a52c910285bd53c
Yea that bench sucked.... If you go to I think it was custom it will do full screen.
