3dmark master
Radeon VII
2000 core
1126mv
+20 Power
1000 mem
100% fan
J max 97c
ambient ~25c
Graphics Score
30 827
http://www.3dmark.com/fs/18622210
2010MHz even up to 1200mv crashes
Auto OC = instant blue screen
Graphics score was ~200 lower with 1168mv
Actual clock speed was ~1900-1980
22,378
Graphics Score    32,319
http://www.3dmark.com/fs/18631627
2045 core
1166mv (Fixed it was crashing instantly over 2000MHz with 2d v at default as it didn't ramp up quick enough)
+20 Power (peak power use 489w at wall)
1200 mem
J max 108c in Graphics test one thermal throttled to 1950-2000MHz while graphics test 2 ran 2000-2045MHz
Ambient ~10c
Superposition:  (1080p Extreme)
6173
2000 core 1138mv
1200 mem
100c J max
So just ahead of gambles 1080ti but it seems the 2080 does really well in this test.
Great results!  Looks like that card has lots of potential.   Look forward to seeing more 🙂
After the new board I was able to run my ram at it's rated speed of 3466 but it requires 1.58v so running it at 3266 16-16-16-36 1T.
Did a compare of the last few cards below.  I know your 1070 was a better OC'er but threw it up mine as well.  This is with my 2080 running as has much as it will go +165 (1995 to 2085c) / +1300 8300m.  Power limit is what holds it back, the temps with fan at 70% never hit over 67c so I dont think water would help out much for gaming or benching.  Especially since it runs sub 60c for much of the bench runs as they are short.  I can game at this setting but run around +70 2000c/+1000 8000m for daily as there just isn't much gain past that it seems.
FireStrike:  https://www.3dmark.com/compare/fs/18631627/fs/18632700/fs/14716114/fs/13625478/fs/12182486
Graphics Score:
2600x/Rtx2080:  29187
1700x/Gtx1080 Ti:  29677
1700x/RX56(flashed to 64):  22098
1700x/Gtx1070:  19865
TimeSpy: https://www.3dmark.com/compare/spy/6510932/spy/3321791/spy/2719676/spy/1480735
Graphics Score:
2600x/Rtx2080:  11975
1700x/Gtx1080 Ti:  10418
1700x/RX56(flashed to 64):  7203
1700x/Gtx1070:  6340
Superposition:  7555
I think I am close to having my 24\7 stable OC dialed in using MorePowerVII_77+ and quiet fan\pump curves that keep the GPU under 70C hot spot.
2100 Core 1202mV 1230 Mem
The increased SOC from this powerplay profile is what let's me hit 2100MHz the next step up (EvenMorePowerVII_1293++) only brought with it another 25MHz.
MorePowerVII_77+ https://www.overclock.net/forum/67-amd/1633446-preliminary-view-amd-vega-bios-131.html
+77%(+20%) max power limit, 400A TDC Core (330A), 66A TDC SoC (50A)
1193mV SoC (1168mV), max HBM 1300MHz (1200MHz)
Heaven Extreme: 4237
Valley HD Extreme: 5770
Superposition 1080P Extreme: 6528
Superposition 4K Optimized: 9013
FireStrike: 22,836 - Graphics Score 33,409 - Physics Score 14,455 - Combined Score 9121 http://www.3dmark.com/fs/19456389
FireStrike Extreme: 13,686 - Graphics Score 16,027 - Physics Score 14,445 - Combined Score 6296 http://www.3dmark.com/fs/19456438
FireStrike Ultra: 7697 - Graphics Score 8039 - Physics Score 14,424 - Combined Score 3602 http://www.3dmark.com/fs/19456461
TimeSpy: 9390 Graphics Score 10,479  CPU Score 5911 http://www.3dmark.com/spy/7309743
I didn't appreciate just how much of it is finding the right v for the set clock speed and just how much slower more v can be even with a higher set clock.
2175MHz core set for both the below
179FPS graphics test 1 1238mV <Crashed test 2 This would have mostly been running 2100MHz+
172FPS graphics test 1 1243mV <This would have been around 2050-2125MHz
FireStrike 23,333 Graphics Score 34,436 http://www.3dmark.com/fs/19496909
Edit:
Tried again this morning with the window open at 3c ambient so junction maxed out at 60c but didn't do any better
Got in a run set at 2221MHz 1271mV 1287MHz mem but only scored 34,353
Peak power use from the wall was 559w
Swapped back to 2100MHz 1212mV and it doesn't matter if power limit is at 0% or 99% the max power use from the wall remains at 509w in firestrike.
While I have seen up to 30% power limit affect clocks in other programs power use never went much over 500w.
For comparison
Firestrike grapics test 1
Max power use from wall
Stock 1143mV 367w
Undervolted 1001mV 315w
I did get sick of 100% fan speed though so these two will be ~20w lower due to that.
Chernobylite is a new early access game built on the Unreal engine with a benchmark.
This is at Ultra 3440x1440
Game has some promises and it will be interesting to see how it develops as they add extra content.
  • Yes Sir! Very atomic! 1
Looks like you need to buy it and even then you don't get much more than a demo for $40 at this stage.
As for the game it is fairly short just a few maps they will add more but it will never be a large game with just a few quick missions.
A fair bit of the outdoors FPS drops lower than it does in the benchmark.
New score with 7700K@5.1GHz -1AVX 1.375v, 4x8GB 3600c14, RadeonVII 2150-core 1275-mem.
http://www.3dmark.com/fs/20952799
24 408
  • Graphics Score 33732
  • Physics Score 16205
  • Combined Score 10 549
GPU score is a little lower with newer drivers the clock speed is more stable with less dips but cant hit the same highs although I am sure I could do better if I found the sweat spot for v vs clock again.
Here is a userbenchmark run at the same settings
UserBenchmarks: Game 119%, Desk 105%, Work 84%
CPU: Intel Core i7-7700K - 109.4%
GPU: AMD Radeon-VII - 138.5%
SSD: Samsung 970 Evo NVMe PCIe M.2 1TB - 284.8%
SSD: SanDisk Ultra II 960GB - 108.1%
HDD: WD Green 3TB (2011) - 47.4%
RAM: G.SKILL F4-3200C14-8GVR F4-3200C14-8GFX F4-3200C14-8GVR F4-3200C14-8GFX 32GB - 127.5%
MBD: Asus MAXIMUS VIII GENE
[IMG]
Nice score, AMD seems to like this bench.  Core clock is up there! How's temps at high clocks on gpu/cpu?
Edited by gamble
With pump at 100% the GPU tops out around 70c Junction thanks to the Storm G5.
CPU runs ~60c at 5GHz 1.35v Prime 95 thanks to delid with liquid metal under the IHS and I was only feeding it 1.375v for 5.1GHz so there is probably room to push higher assuming it hasn't just hit a wall which from memory it may have.
Although due to AVX -1 it is running 100MHz less in Prime95.
Also had a crack at superposition which favors Nvidia using the settings there running over at OCAU
https://forums.overclockers.com.au/threads/unigine-superposition.1219642/page-19
superposition%205.1ghz%203600c14%20power
Not sure how good it is as everyone on OCAU seems to be using 2080Ti and getting 30k in Superposition but there is a lot of old 1080Ti tests where they are a few thousand points higher so it seems to favor Nvidia a fair bit unlike Firestrike.
The memory test on Userbenchmark is fairly good.
Mate upgraded to a 9700K when I was helping him build a custom loop so I swapped him for my 6700K for his 7700K. Same IPC but can run 5GHz 24\7 with less v than the 6700K needed to do 4.6GHz.
However the 6700K was able to hit higher RAM frequency but at least the 7700K can manage very tight RAM timings ok.
Still have yet to go back to OC it and take a decent picture but after a lot of teething problems his system is running well.
I'm think of going hard tubes next...   ^ It looks great.  I do like the ease of use on flex tubes so not sure yet.  I like the open case but I think it might be somewhat loud, no?
It is only as loud as the parts you put in it so as long as you have no HDD or coil whine... a D5 pump is nice and quiet at low RPM and with enough rads you can run the fans around 0-1000RPM depending on load.
Airflow over parts may not be so good so when pushing high overclocks for benchmarking you may want to aim a large fan at the case.
Hard tubing isn't great for someone that changes gear a lot as you need to redo the tubes every time you change a part since GPU cores and CPU locations move around and they usually still hold water when draining making it more difficult to get apart without making a mess.
Downloading Cryengine Neon Noir Ray Tracing Benchmark which doesn't require the Nvidia RT cores.
Ultra detail 1080p
Very high detail 1080p
The benchmark does seem to favor Nvidia with 1080 TI getting 10k at ultra and 2080 Ti getting 15k
I managed to remember the details for this account!
Thank you for all those who looked after and posted in this and the prior threads. For me personally I thoroughly enjoyed posting in this and the Super Pi thread; pushing my PC to its limits to try and get as high as I could on the leader board. While I never managed to keep up with most here, was awesome fun nonetheless, and I certainly will miss it.
Bench on!
- nobody813
