zigman
A few SSD questions
Hi guys,
My current system is
i5 760 @ 3.8Ghz
Gigabyte ga-p55a-ud3
4GB 1600mhz DDR3 G-Skill ram @ CL6
1TB WD Caviar Black
W7 64bit
So at the moment I am running my Windows off the 1TB HDD and also, on a separate partition, my "Data" drive with all the music, documents and patches etc.
I've been looking at getting an SSD over the last couple months. I've been doing a bit of research and it seems just about the right time to grab one. (as the cost is coming down, performance is increasing and reliability is becoming stable)
I have an OCZ Vertex 3 120GB in my sights. This is a SATA-III SSD. My problem is, my motherboard uses the Marvell 9128 chipset to control the SATA-III. I've read that this does not use the full potential of the 6GB/s speeds of SATA-III as it runs of 1xPCI-e lane, rather than straight to the P55 chipset like the SATA-II ports do.
Should I just buy an older Vertex 2 and run it off the SATA-II ports or wait for the Vertex 3 and run it off the SATA-III port? Given I won't get the full speed of the SATA-III?
My plan is to obviously run W7 off the SSD and just use my 1TB WD for my "Data"
What are your thoughts? I would think going with the Vertex 3 off SATA-III would be the better option. As the SATA-III speed will still be faster than SATA-II. Also I would be getting a better quality SSD with the Vertex 3.
Daniel
Not really. The PCI-e will be enough to load it. Heck, I haven't seen any SSD move beyond 250Mb/s write and 400Mb/s read anyway.
Anyway, you'll be fine as the drop from SATA3 to SATA2 isn't that great. At most, you're only losing 20% speed.
Edited by sora3
Don't be confusing Gb for GB or Mb for MB there sora.
Don't the Vertex 3s run at around 500/500? That's what I read somewhere, and I've been looking around, but not many places stock them.
Whoops, you're right tantryl. Should be MB, not Mb... >>
Harmonic, not really. Most previews of the Vertex 3 has it about the same numbers I quoted. But I do think that'll change later on.
