Amiga4eva
Recommendation for a sound card.
Ok, due to issues I've had getting 5.1 for games etc through either Coax or Optical (SP/DIF) out from the onboard Realtek HD to my Sony home theatre system, I've decided to fork out for a semi-decent sound card and see if that makes a difference (under Vista mind you, which I believe has a host of 5.1 issues anyway).
So - what can you recommend from the list here - http://www.cpl.net.au/ (I chose this place only cause I have a $30 voucher for there to help take the burden off the price).
Want 5.1, good quality audio for games and movies through my PC, going into the setup detailed here - http://forums.atomicmpc.com.au/index.php?showtopic=3421 (and no, I haven't been able to get 5.1 using Coax, Optical or updating Realtek HD drivers, or fucking around in Vista... Just. Won't. Happen).
In regards to the whole SPDIF probs, if you have one, try disabling the HDMI component in Vista, fixed my all my problems.
Soundcard, the Xonar DX is really quite good.
Are you able to tell the difference between onboard 5.1 sound (have a GA-DS3R) and an additional one like the Xonar DX?
What is the cheapest vista compatible sound card? PCI or PCIe?
I have that mobo and it took ages to sort it out.
Basically the azalia codec doesn't output 5.1 through optical/coax, only through analogue. To get 5.1 with movies you need a media player that uses it's own codecs. (such as PowerDVD)
As for games, there is no way to get 5.1 through the digital output:(
A bit of a half done sound output if you ask me.
http://www.gigabyte.com.tw/Support/Motherb...;ProductID=2639
