te0p
overclocking GTX9800 best way to do it?
I have a GTX9800 and want to overclock it a bit. it is reported that i can get quite a bit more out of it.
That said i downloaded Nvdias Ntune or as it is titled after i installed it Nvidia monitor.
Only problem is when i go to run Nvidia Monitor i get a blue screen of death just by strating the application, not even using it.
is there any other software that is beter? I lost the page i had open when i got the BSOD it was for a programe from MSI for overclocking?
any input welcome.
use msi afterburner
on water i was able to get my 8800gt from 650mhz to stable at 860mhz with a bit of extra v
Yeah MSI after burner is what use now days but I used EVGA precision for my Dual 9800gxt's and my miss's current 9800gx2.
I'll see if I can find my max clocks around some where for you Te0p.
After burner worked a treat....did some searching and most people got up around 800mhz
I have it on 813mhx from 740mhz and memory from 1100mhz to 1200mhz.
I had no problems so could take it higher.
If you have some max clocks for that would be great and i will try them out.
