How will these speakers work as rear replacements on Pioneer VSX-519V
Im wondering how best to try hook these up to the amp or if its likely to do any damage to anything
Pioneer Todoroki 5.1 Ch Home Theatre System
http://www.pioneer.com.au/au/products/arch...9V-K/index.html
FTC power output
. . . . . . . . . . . . . . . . . . . . . . . . . . . .65 W + 65 W
(STEREO, 20 Hz to 20 kHz, 8 Ω, 0.2 %)
Rated power output (Front, Center, Surround)
. . . . . . . . .125 W per channel (1 kHz, 6 Ω, 1 %)
Maximum power output (Front, Center, Surround)
. . . . . . . .150 W per channel (1 kHz, 6 Ω, 10 %)
Total Harmonic Distortion
. . . . . . 0.06 % (20 Hz to 20 kHz, 8 Ω, 85 W/ch)
Guaranteed speaker impedance
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . 6 Ω to 16 Ω
Input (Sensitivity/Impedance)
LINE . . . . . . . . . . . . . . . . . . . . . . 200 mV/47 kΩ
Output (Level/Impedance)
REC . . . . . . . . . . . . . . . . . . . . . . . 200 mV/330 Ω
ZONE 2 . . . . . . . . . . . . . . . . . . . . . 200 mV/1 kΩ
Signal-to-Noise Ratio
(IHF, short circuited, A network)
LINE . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 98 dB
http://www.jbhifionline.com.au/hi-fi-home-...receiver/462779
Sound input to it is via hdmi from the pc
Current rear speakers are some cheap ~4" with a 120w 8ohm sticker on them
I have a panasonic sa-ak28 not getting used at the moment
Its speakers are dual wired looks to have something around 2" high 5" mid and 8" sub in each and there sticker says 6hom 60w high 140w low
thanks
edit
or maybe i should put them to the front and move those tower speakers to the rear...
